velusip
- Jan 24, 2005
http://usa.asus.com/products/mb/socketa/a7v400-mx/overview.htm#
My experiences with this motherboard have been reasonable, but there are a few issues I must address and a few things I must ask:
1. The Manual is printed wrong! Make sure to download the updated copy: http://usa.asus.com/support/downloa...=28&m_id=1&f_name=e1817_a7v400-mx.pdf~zaqwedc
2. Pay extra special attention to your DIP Switch settings. I have fried a processor because the original printed manual is wrong! See Issue #1.
3. This is not an overclocking board. However, if you have a decent vid card, memory, and loads of cooling, you might be able to get a 166MHz FSB proc up to 200MHz (this is your only option).
4. mATX with mounts all around! (Chipset and processor cooling mounts at your disposal.)
And now for some questions:
1. Has anyone ever tried forcing a Zalman 7000 (or variant) HSF into a mATX case by bending a bunch of the copper/aluminium blades aside or around your PSU?
In my world, there is no such thing as idle temp. So I get a constant 63 degrees celcius with an AMD 2800+ XP (Barton core), with one case fan running and 65 degrees celcius without the casefan. My intentions are to make a very quiet machine. This proves difficult with the case I have (lots of breathing holes, very metalic reverberations). I'm wondering if I should buy an older Zalman flower or the newer Zalman 7000 (and bend it to fix).
Any ideas?
p.s. My gpu is an ATI 9250 which runs way too hot, anyone have a nice Gforce card they wanna sell?
Any ideas?
