A7S333 won't go into bios
t60
I was at my friend's house earlier, and his computer decided not to boot at all. I decided to try and go into the bios, but it doesn't work. When pressing the delete key, it hangs. When pressing the tab key to view the post screen, it hangs.
Not sure what the problem was, so I decided to stick in a floppy disk and see if it would give me some sort of an error, but it just hung again.
I pulled out every component, but the CPU and motherboard. Nothing works, I get the same problems mentioned above. I would love to flash the bios, but seeing how I can't even get into the bios or the post screen without the motherboard getting all screwy, that won't be happening.
I've resetted the CMOS properly as well.
I'm wondering if there are any other things I can do to troubleshoot this, before purchasing another board.
Any suggestions would be great.
