A7N8X-VM all crap?
rool
Hello, I've been lurking around here for some time and though that I might get some help now that I've run into some tought problems.
Just got my second A7N8X-VM/400 to build myself a htpc.
The previous one I bought when building a pc for a friend didn't want to shut down and the memory gave me thousands of errors. Turned out it was totally borked and I got a new one after 3 months of RMA-procedures.
I then thought I've had all the bad luck one can have with one specific motherboard model but noooo, the one I got now had some other, not smaller, problems. First thing is that I get random reboots which probably is related to the integrated graphics in some way because they always happen when something initiates. Second thing is when doing certain things like opening advanced settings for graphic adapter or playing a movie the screen starts filling up with horizontal lines of different colors. After a while they all turn purple and the box reboots.
Is it just that the board is all junk or have I missed something?
I have installed all drivers, the newest ones for graphic and motherboard from nvidia.com.
I have tested different memory modules, Corsair pc2700 and Twinmos pc3200, both separate and together.
(Other hardware in the setup is an xp2500+, qtec 550W psu, dvd-rom and a 40gb hd).
As I ran the memory in dual channel mode the effects of the horizontal lines got much less intensive and I got by quite a long time before the box rebooted.
I then tried to turn the hardware acceleration off entirely and then the problems all disappeared. This is how I run the system now and everything lags.
Any suggestions?
I just put one of these in a PC I built for my Mom and it seems to be a very good board (other than the holes for the heatsink aren't cut out) . I chose it because I use an A7N8X-Deluxe.
Loaded windows fine, installed nforce drivers and drivers for the onboard geforce4 MX, no problems. Did you check all the settings in the BIOS? There are some settings for the onboard video in there that might help. Other than that I don't know.
what were the cpu and memory?
Because the nforce IGP doesn't like 128mb of video memory going to it or 400mhz fsb.
