A7N8X-E OC'ing w/ XP 2500
Vearl21
Hey Guys
I am running A7N8X-E with XP 2500 with one stick of Corsair XMS Series with 2-3-3-6 Timings.. Single Channel
The problem I face is some instability issues when I do 400 FSB(200 mhz for single channel) than 166.. Any one doing the same set up what timings are you using?
I am using the Auto Timings at 2-3-3-7 because it seems to be stable... 3DMark01 Score: 6316
That seems horrible to me
Video Card is ATI 9600 PRO SE
Any pointers would be appreciated
Thanks
Try starting from stock clock, but reinstall your nforce2 drivers again but also reinstall direct x. Start at cas 2 7-3-3 again but manually sync your ram in expert settings @ 100% of your FSB. In other words run at 166/166. Make sure A/A and A/F is off on the ATI card, set to 1024x768 @ 32 Bit and 85 Htz on the monitor It should be about 9500 now. If so now bump it up in stages and test. You may also have to raise vcore.
Additionally the Asus A7N8X-E will boot 15 seconds fater if you make sure parallel ports and serial ports are disabled if your not using them. Remember if you OC to set AGP Feq to 66, this locks down AGP/PCI to 66/33. Set AGP apeture to at least 128 also. Good luck-
A/A and A/F = Anti Aliasing and Anisotropic filerting. When you use them you get "jaggies" and other things smoothed out in games, but ... it gives our system a big hit in benchmarks, naturally. So you should just go to Direct 3D tab and Open G/L tabe and set the properties to defaults and make sure you don't have A/A and A/F activated. Usually when someone has unusually low scores for thier setup that is the culprit, or one of the culprits. Right click on your scree and go to properties/settings/advanced. You'll find it on the Direct 3D tab and Open G/L tab. Use the default button to reset them both. DO a google search for both Anti Aliasing and Anisotropic Filtering and you can read the benefits of both, which your card will do well.
I have check boxes for application preferences for AA and AF.. I unchecked them and set AA at 2x.. Resolution at performance and AF at 2x same thing for Open GL.. Is that right?
