A7N8X-E mystery blank pin header
arb_npx
On my A7N8X-E Deluxe board, I can see a pin header socket without a pin header soldered in them (so just soldered holes) just above the front panel LED connection header (the header with power LED, PC speaker, etc.). Using "toward the expansion card bracket side" as "up", the label above this mystery header is "F_PANEL", and the mystery header is 2x10, with 9 pins (5 on the left, 4 on the right. To the right of it is what appears to be a legend of connectors; going up to down on the left row is HD_LED and RESET, and P_LED and PWRSW. Believe me, if I had a digital camera, I would've taken a picture.
I was wondering if anyone else has checked to see if these are actually connected to something useful, like the HDD_LED channel. The arrangement doesn't quite make sense as labeled, since the power LED connector takes up three pins, and the P_LED is in the 4-pin row with another 2-pin connector. This legend does not agree with the existing front panel connector, but there has to be a reason for Asus printing it on there, even if it's a bad reason.
As for why I'm searching for HDD_LED pin headers, I have an extra status LED to use, and perhaps even the 470nm 3000mcd LED internal lighting array I had going on my old KT7A's HDD LED channel. It was fun to see the case blowhole strobe light blue on HD access, but it's even better if I can do it with a case window.
The blank or unused header that you inquired about is on my A7N8X-E Deluxe board and shows up as unused in both versions of the manual.
