A7N8X-E Deluxe
luigi2000
This board may not be much of an OCer, but A7N8X-E is loaded, stable and prices are outstanding. Here is my motherboad upgrade experience...
On Monday, 2/2/2004, I performed a motherboard and processor upgrade from Asus A7V with a Duron CPU to Asus A7N8X-E with a Barton 2500+ CPU. This required using Windows 2000 Setup to install the correct HAL and motherboard drivers. This was followed by re-installation of SP4, DirectX 9.0b and hotfixes.
Because I had modified the partition letters after the original installation, the trick in this case was to get the operating system to assign the same letter to the system partition. I have not found this info anywhere else. I had to disconnect a second ide and a scsi drive to make this happen. Knowing this going into the project would have saved me hours.
In the aftermath, I examined the system log. There are four Windows File Protection information entries. The descriptions read...
"File replacement was attempted on the protected system file ks------.ax. This file was restored to the original version to maintain system stability. The file version of the system file is 5.0.2134.1."
The DirectX plug-in files named in the descriptions are ksinterf.ax, ksdata.ax, ksvpintf.ax and ksclockf.ax. The file modification dates are 12/2/1999. Using DirectX Diagnostic Tool notes "No problems found." Also these files are not in the long list of DirectX files.
Then I installed the NForce 3.13 motherboard drivers...
The Gainward GF4 4800SE paired with the original A7V mobo with Duron@1300 had scored 7000 in 3DMark2001 using 44.65 video driver. NForce 3.13 installed 53.03 video driver. With this driver the Gainward GF4 A7N8X-E combination scored 11400 in 3DMark2001. Dropping back to the 44.65 video driver, this combination scored 12400 in 3DMark2001. No OC was applied in these tests.
Later I find a great big problem...
Trying to burn DVD with known good Nero 5.5.10.42 installation, Pioneer DVR-A04 and Ritek G04 DVD-R media results in dvd driver hang (tight loop). I am using the nForce 3.13 motherboard drivers. No blue screen but Service Manager reports in the event log: Event 7011, "Timeout (30000 milliseconds) waiting for a transaction response from the service."
On the first IDE channel are two WD 1200JB 120GB hard drives working fine in UDMA-5 (100) mode. The second IDE channel has both Pioneer DVD-RW burner as master and Toshiba DVD-ROM reader as slave currently set to UDMA-2 (33) mode.
I had performed dozens of proper dvd burns with my old A7V motherboard without a problem using the same peripherals.
The above problem exists with the current A7N8X-E bios version 1008. This is the latest bios version.
A local vendor reports that this problem is a known issue on A7N8X-E with a DVD burner and a DVD reader on the same IDE channel. Later an Asus phone technician says this is not true.
I tried the vendor's suggestion of using the DVD burner alone on the IDE channel. I burned four dvd-r discs with the same material. The driver does not hang in a tight loop; however the Nero verify function reports that the transferred data is corrupted. The file compare utility FC shows that the corruption is duplicated exactly on all the burned discs.
I find out that I can revert to the default Microsoft Dual Channel IDE drivers easily through the facility of Device Manager. The burns now work! This fixes a nasty problem. If your OS is Windows 2000 then stay away from the NForce SPP/IGP IDE driver contained in the NForce 3.13 motherboard drivers.
If you're paying attention, then it's always something.
