A7N8X-E Deluxe Posting problems?
Status
Not open for further replies.
VermillionZ
I just bought a brand new Asus A7n8x-e from newegg along with an AMD 3200 400fsb mhz proc.
At the time I am using my stick of 128 megs 266 mhz ddr corsair memory which should work fine for now?
I spent two days checking for flexing issues, grounding, making sure all the contacts were right, jumpers, etc etc...
I still have not been able to get this system to post...
I even tried another powersupply unit.
The bios on this should also give an audio error for no memory or cpu if not installed but no good even that way..
Fear i must contact newegg for an exchange... grrr
Anyone else have this issue with a new a7n8x-e?
Well, I just got one and I had problems, but nothing THAT severe. Sorry.
I just set one up for a friend and would lock up at boot screen if I set graphic apreture to anything over 64 ...never experienced that particular prob on a mobo before
If there is no CPU the board won't do anything. Also I had one of these and the BIOS crapped out after changing Voltage and FSB on the same BIOS save. To get the audio warning you need to have speakers pluged into the back audio port. You can also try just PS, CPU and PC speaker. If it doesn't beep codes its DOA or you CPU is bad. Check the core for cracks.
If I remember it does do something, I have an A7N8X deluxe and after every step I took (my first PC build) I would power on to hear the post reporter say CPU Error! or Memory Error! etc. It even says CPU Fan Failed and won't boot to the OS if the fan is running under (just a guess here) 1200RPM.
I had a problem with my A7N8X Dlx when putting it together and for some weird reason there were no beeps, no voices etc. The mobo light was green and all the fans got power etc. I had to take out PCI cards, RAM etc (I left CPU and HSF in) and then checked all the jumpers. It's important that the internal sound jumpers are set right if you don't have your case plugged in there otherwise you'll get no sound whatsoever, also be sure to have the internal case speaker wire plugged in the correct way. After doing this I reset CMOS (take bettery out, move jumper to 2-3, then 1-2 and reinsert battery) then everything worked (well it said memory error, but it was a good sort of error!)
I've heard about the AGP apeture problem. It only applies to Radeons and as far as I know, there is no fix at present.
I'm running my Radeon 9800 Pro on an A7N8X Deluxe GD2 with it set to 128MB with no problems. Are users having trouble got the BIOS set to use AGP and not PCI?
board will still talk atchya if no cpu in or dead cpu installed
Ah ok I was not thinking about plugging in my pc speakers to the onboard audio connections..
Silly me old school brain matter here thinking Post beep goes through the small pc speaker in the case.. not the external pc speakers?
I think I will try again when I get home..
Thanks guys for the replies.
I tested it last week with just PSU, CPU, memory, and my ATI 9700 still nothing even pulled the 9700 off.. umm
Yep, post beep goes through the cases internal speaker and the Voice Reporter uses your external speakers (via lineout).
its your ram, 400mhz! = 266mhz
if it has a 100/(133/166/200) jumper set it to 100 and see if you get anything
I believe sir you have answered your own question. I dont think your ram will make the jump from 133 to 200 (266 to 400). That is probally why you computer wont start up.
Well I finally figured it out it was thre memory.
This board is backwards compatible to 166/200/266 etc it's a softbios setting I figure because I have looked but there are no jumpers for FSB, CLK, or Mem FSB on this board and I really hate that.
I'm going to be testing my memory in another system later.
i dont think the memory is bad. You are just trying to run 266 memory at 400.
So try to split the difference. You have DDR266 ram and you have a native 400 FSB processor. You can run async at 400/333, by that I mean you may be able to get your ram to run @ DDR333. just raise DRAM to 166. You may have to raise DRAM voltage to 2.6/2.7. Maybe not. You may need to ativate expert settings to do that but it's extremely easy to do. So all you are doing is overclocking your ram from DDR266 to DDR333 (133 to 166). At least it should runa dn won't be so far out of spec from the FSB.
There is only one problem with that.
It's all done in the bios no jumpers for FSB settings for memory or Proc..
No video output since the system is failing post.
Oh I figured out what the issue is btw..
This chipset on this mobo can not support ECC Registered memory.
Just take a guess what my old memory stick is?
Doh
Tested fine on another system.
Doh
I have an A7N8X Dlx which I know is a different motherboard but if my board has jumpers I'm sure yours does too. Look at the quick reference card, there should always be a jumper for compatability reasons, if not resetting CMOS should put the FSB down to 100 anyway.
Status
