A7N8X-Deluxe V2.0 Problems...
Nemesis999
Every time I try to install the audio drivers for the onboard audio one of 2 things happen.
The first time, both my DVD burner and CD Burner failed to recognize until I finally rolledback the system.
After I rolled back I installed them again. The audio simply didn't work. No conflicts in the hardware list, reports that the device is working. But no sound.
The audio definately works because I just formatted yesterday and it was working before. I just can't remember how I got the audio drivers to work in the first place.
Any help would be appreciated.
i assume your installing the NForce Driverset for the audio correct???
if so then i would try using a previous version mebe its jes a version conflict.
the drivers off the CD or from the latest download off of Asus's site?
If it's the CD try getting the new ones off ASUS, if it's a recently dl, then try the CD.
EWW dont use those old NForce Drivers... stick with what Nvidia puts out.. they have fixed a lot of issues from those oldies... check out the new ones they might be your solution
I've tried the newest downloads from NVidia.com, right now I'm trying the older audio drivers (3.17) since, according to the notes...
"Adds support for audio with the ASUS A7N8X Deluxe product"
Hopefully that'll fix it. I know there's some way to get the newest drivers to work, I did it before, but I also remember it being a pain in the ass.
u could try doing the install in SafeMode... that might be the solution
u try installin in safe mode i do know that some Anti-Virus programs can cause some problems with NVidia Installs... it is possible...
Safe mode = no luck.
BUT!
I figured out an order that works.
1) Windows install
2) Network Drivers install (for adapter 1)
3) DirectX 9.0b
4) NVidia NForce 4.24 drivers (audio only)
5) Video drivers
6) Balance of NForce 4.24 driver pack.
That now gets super-glued to the inside of the side panel of the case. :D
hehe. i also have an ASUS A7N8X Deluxe but never experienced those type of problemes. well, at least you got it working.
