A7N8X Deluxe Rev 2.0 USB issues
JeffS
Problem: on my MOBO i've discovered that the usb headers that connect to the frontside usb connectors in my case (Chieftec Dragon) are only USB 1, not 2.0 as I was lead to believe. I rechecked the specs on my case, and on my MOBO and it appears they should be USB 2.0. I've updated all the nforce drivers, I'm running bios 1005, and am getting rather frustrated with not being able to make this work.
Background:
I've dug through as many posts as I could find here, as well as googling and searching various other forums to no avail.
Specs in short:
A7N8X deluxe rev 2.0
2500+ @2.2 11x200
1GB
XP Pro SP1a (with all updated drivers, hotfixes, critical updates, etc)
ATI 9500 (latest cat.)
Questions:
could it be the usb connector for the frontside ports?
everything I've read has said that a port is a port, it's the controller that
makes it either 1.1 or 2.0....
Is there a bios setting I need to mess with?
This version of the OS was installed less than a week ago in my anual
system rebuild. (ok, not a question just information)
tangent question:
I bought the board from NewEgg back in august, and I did purchase the extended warrenty from them. Would this board still be rma(able), and would it be worth it. (yes, I would be having regular fits not having my computer for weeks, but I'm curious if it's just a dead board)
Thanks for any help.
-Jeff
The latest BIOS for your board is V1007... maybe you can try looking into that. I have the same case, and would also like to know whether they're USB2.0 or not. I haven't really ever used those front USB ports to know whether they're USB1.1 or 2.0.
The headers below the IDE connectors are USB 2.0, as are the ports on the Chieftec case.
They work just fine when I connect the extra 2 USB ports that fit into the PCI slot. However, I tried to connect the wires that went to my Antec 1040BX case's front USB ports to those pins, and it never worked. I don't know if it's because the front ports are 1.1 and the headers are 2.0, or if I just mixed up some of those little wires.
I did put together a friend's computer, with a A7N8X-E Deluxe and an Antec Sonata case... and since the front USB wires were consolidated into one connector, when I hooked it to the motherboard, the ports worked just fine.
