Does anyone know if I can make the onboard video card on the A7N266-VM work even with another video card in the AGP? I want to run dual monitors but the onboard shuts off when I use the AGP... why does it do that and how can I stop it?
The A7N266-VM doesn't do dual. It detects if there is something in the AGP and then it disables the onboard video. Not sure but the only boards that do dual video are build for it, like some of the Shuttle boards and the new P4 board from ATI; the onboard video drops into PCI mode when it detects an AGP card, Shuttle boards have dual CRT connectors.
Maybe you could add a cheap PCI vid card and get dual VGA. I know Asus makes an AGP add-on card so you can get DVI and TV-out from the A7N266-VM but probably anything stuck in the AGP slot would deactivate the onboard. The add-on is available at NewEgg if you're interested. Yeah the Shuttle MN31N supports dual-VGA, I tried it on one of mine for a month, it worked fine. Also Epox 8RGA+ does and Leadtek and Albatron make ATX boards with the second VGA on an add-in PCI bracket.
