Well after spending the ENTIRE day with my new build here is what I've found along with a couple general questions. My rig will run at 2.4ghz, rock solid stable with very nice temps. I use the 10x multiplier, the RAM is running at 1:1, had to increase voltage to 3.0 and change timings to 3-4-4-8. My system will boot and run at 2.5 but fails prime 95 after about 1 minute. I tried bumping the memory voltage up to 3.2v and things get better.... 4 minute failure. If I give the proc anymore than 1.56v it runs VERY hot. I actually even got the system to boot @ 2.6ghz today. The limitation does not seem to be my processor, it appears to be the RAM. For some reason the system really does not agree well with memory dividers. Everytime I use them it becomes unstable. The best it does at 2.5 is if I give the memory 3.2v and relax timings to 3-4-4-8. Even if I relax the timings to 3-5-5-10, the system actually gets worse. If I change a jumper on the mobo I can up the voltage to the memory more. My DFI will actually give up to 4v I think. Should I give the memory anymore than 3.2v? Any help would be appreciated guys. Here is my rig:
DFI n4 Ultra D
3200 Winchester
2x512mb OCZ Platinum Rev 2 3200
PCP&C 510 Deluxe SLI power supply
BFG 7800gt (460core, 1200ram)
All on plenty of air cooling
DFI n4 Ultra D
3200 Winchester
