So this is my first time overclocking any CPU, as I've never had a system good enough to overclock!
I've read all the guides on here (EXTREMELY HELPFUL! THANK YOU HardOCP!) and I have done all my tweaking and nudging. Here are my results from a Reg dump from CPUz:
I'm running an Asus A8n-SLi Premium motherboard with Patriot Extreme DDR 400 memory.
Number of CPUs 1
APIC ID 0
Name AMD Athlon 64 3200+
Code name Venice
Specification AMD Athlon(tm) 64 Processor 3200+
Family/Model/Stepping FF0
Extended Family/Model F/2F
Brand ID 4
Package Socket 939
Core Stepping DH-E3
Technology 0.09µ
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, x86-64
Clock Speed 2208.8 MHz
Clock multiplier x9.0
HTT Bus Frequency 245.4 MHz Ai Booster reports 980 FSB btw.
P-Rating 3200+
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2208.8 MHz (Full)
and my memory
Memory Type DDR
Memory Size 2048 MBytes
Memory Frequency 200.8 MHz (CPU/11)
CAS# 2.0
RAS# to CAS# 3
RAS# Precharge 2
Cycle Time (tRAS) 5
Bank Cycle Time (tRC) 11
DRAM Idle Timer 16
*****EDIT: As requested: My CPU Voltage is 1.45.
Temps are 30C idle, 35-37 load for CPU
MB= 35 idle, 40-45 load
Can you guys please look at this and tell me where I can improve or what I should improve. I know its a very mild OC but I am a newbie and I am taking it slow!
Thanks everyone!!
Number of CPUs 1
APIC ID 0
Code name Venice
Brand ID 4
Package Socket 939
Core Stepping DH-E3
Technology 0.09µ
P-Rating 3200+
and my memory
Memory Type DDR
CAS# 2.0
RAS# to CAS# 3
RAS# Precharge 2
Cycle Time (tRAS) 5
DRAM Idle Timer 16
