ninethreeeleven said:High, my room temp is around or under 20C and my idle is 38-42C. Give more specs and we should be able to fiure it out.
My load in Prime95 torture test will occasionally spike to 50C but thats really rare and it usually is around 45C.
A64 3700+ Clawhammer + Coolermaster Hyper6
EDIT, damn your room is hot 86F My balls would fall off at that temp.
well, what really matters is the middle, as that's where most of the heat is transferredhmm... said:oops. but then I put tranfered the fingernail part back to the missing area. i hope that did do much, because the entire surface is quite big
