A64 running at 61 celsius... some advice?
bluehorizon
My A64 is running at 61 celsius idle... I'm not sure what the problem is (I am running a MSI K7N2 Neo Plat, which I hear has some problems reading temps w/ current bios). I'm using a thermaltake Silent Boost heatsink with a thermaltake smart fan II running at 4000 rpms. I used Arctic Silver 5 thermal paste and lapped the heatsink so much that I can see my reflection in it.
I have two thermaltake smart fan IIs for exhaust running at about 3500 rpms and two side fans, plus a 120mm intake fan infront of the case (thermaltake XaserIII skull case).
I'm not sure what's wrong! One thing worth mentioning; I can wiggle the heatsink VERY SLIGHTLY if I try. Though, it doesn't move around in the case, and it IS tight, but since it's so big it's pretty heavy, so I think that's normal.
Any suggestions/ideas/advice?
Thanks...
btw, stupid question but, should the fan on the heatsink be blowing down into the sink, or drawing hot air out away from the sink (blowing out)? I have it blowing out, but I wasn't 100% sure that's the best way.
The heatsink fan should always be blowing ONTO the HSF, never away from. Switch your fan around and you'll see your temps drop immediately.
I'm not familiar with your board, but if it has a Vcore setting make sure it is properly set...too much Vcore can really heat things up...
Also verify that the heatsink is properly installed & adequate thermal interface material is used...
If the heatsink came with pre-applied thermal interface material, make sure you took the cover off the TIM...some people have a DOH moment and forget to take it off...
Later
MD
"I used Arctic Silver 5 thermal paste and lapped the heatsink so much that I can see my reflection in it."
