OK, I have a winchester 3000+, defaults at 9x200. I have it running at 2.4ghz. I set the ddr400 ram to run at 166, then set the HTT to 3x265, which makes the ram end up at 220mhz. Stable as a rock. What I want to know is, I know the chip has its own mem controller on-board and it can run async, which it is, with the ram. Do I get more performance from a higher HTT or more FSB on the ram? I know, I should be happy to get 600mhz OC this easily and just leave it alone, but you know the sickness, once you start, you're obsessed.
