Oddeiga said:I reapplied the thermal compound on my cpu, but it runs at 82C idle, anyone know what i can do to lower that?
your Zalman didn't fit?! that sucks...hopefully you can still return it to newegg?Oddeiga said:My Zalman hsf didnt fit. I figured this out after i took off the stock hsf, so i had to reapply arctic silver 5 on the stock hsf. I used the link you provided before and i applied and reapplied the as after cleaning it off with Isopropyl Alcohol (91%).
