A64 and PC2700 RAM
MadJack
I am thinking about upgrading to an A64 and have decided to go with the Gigabyte board. I have built a couple of systems for other people so I am going to upgrade my personal system.
I currently have 2G of Kingston PC2700 RAM, in the three A64 systems I have built I have used PC3200 memory, all Corsair. Will the system performance be degraded by using PC2700?
hmm... I would think that maybe you will loose about 3-4 fps but you won't be able to tell the diffference. Frankly though I don't know. I am in the same boat as you. I have 1 gig of 2700 and I am about to order the Chaintech MB and A64 3200. Hope someone else can answer are problem. Maybe someone who is already running a A64 with 2700.
Hey guys i am new here and just got a msi k8t neo with an athlon 64 3000+. i too am only using pc2700 memory. I know that my ram can handle pc3200 speeds though. I can't figure out how to set the fsb/dram value to 1:1. if someone can help me, i will be able to tell you what the difference is. right now, comparing my older a7n8x-x with that ram at 200mhz, a few tests in 3dmark are faster than what i have now. but every other test is no comparison. my old system was a axp2700+ @ 2.3ghz 11.5x200. on an a7n8x-x.
1:1 will only work if you have DDR400 RAM. You stated that you are running DDR333 RAM which uses the 6:5 divider. Your RAM can't handle 1:1 because it is DDR333. Basically you multiply the first number(e.g.-6) by the mhz of your RAM which in this case is 166.5. The you divide that number by the second number(e.g.- 5) which then gives you your FSB that you can run at. 166.5*6/5= 200 which is what your FSB is doing. If you run the 1:1 ratio with 166 then your FSB would be 166 which isn't possible. That in affect you need DDR400 which runs at 200 mhz to use the 1:1 divider. 200*1/1= 200FSB. I hope this helps you.
EDIT-- I saw that your RAM can run at 3200???? Is it or isn't 2700??
it is labeled pc2700. on my last setup of an: a7n8x-x and an athlon xp 2700+ i could easily get it to run at pc3200. i used cpu-z to verify that. I am just trying to figure out how to overclock it back to 200mhz. i have found no options for doing so on the k8t neo. someone please help!
You can not force the ram up. If the SPD on your ram is set to DDR333, then that is what it will run at. Drop your latency as far as your memory will go(and still run stabily). I just switched up to Corsair DDR400, and it was NOT a huge increase over the DDR333 memory, running at a lower latency.
