A64 3700-939 not reaching potential
Axion22
I'm running an Athlon64 3700+ on an asus A8N-E motherboard. I just got a Zalman CNPS 9500cu LED and I want to get my OC on (some more).
The highest I can get it is 221x11 (2431 MHz). I know this chip can do better...
What am I doing wrong?
Also, sometimes the reported clock speed in the BIOS doesn't match what Windows says it is. Sometimes it'll POST 2.43GHz and show up in Windows as 2.22GHz. What's that about?
No divider.
1GB PC3200 Mushkin, dual channel. (512x2)
I hadn't looked that over, I will read it and return if I have any further trouble. Mainly my confusion arises at the memory divider and HT aspects. I will read and return.
I'd say your memory is holding you back. If you ram is only rated to go 400MHz, the lowest memory multiplier (x2) will give you 400MHz at a FSB of 200. Whenever you increase the FSB, your ram will have to work harder and anything above the FSB of 200 will essentially overclock your ram.
At 221 FSB, your ram is trying to run at 442MHz when it's only supposed to go 400
Ok, just to be sure I'm getting this:
daytripper: So setting it to 4x while I'm still under 250MHz FSB should be okay right? Then I'd have to bump it down another notch?
Davinci: So what do you recommend... set this mysterious 'memory divider'? The memory is pretty good, rated at CL3, but I can cheat it a little to 2.5.
My eventual plan is to grab up a X2 4400 or 4600 in the coming weeks and riding this S939 for the rest of the year, so I'm not adverse to a memory overhaul. I already need another GB. Still haven't decided if I should just splurge on a higher rated pair of 1GB modules.
It's not your ram latency that is affecting your overclocking, it's the speed that it's rated at. PC3200 ram is rated to run at 400MHz (which is accomplished by having a bus of 200MHz and a memory multiplier of 2).
Since you're setting the bus higher than 200MHz, your ram might be a little shaky because you're asking it to do more than what it's rated to do.
The lowest ratio you can set your ram to is 2/1 (that I know of anyway), meaning your ram will run twice as fast as your bus.
My suggestion is that you need faster ram
I thought the ratio was 1:2 and would make it the other way around, the RAM would run half the speed. This is where I get confused...
I've gotten up to 1.42 in an effort to get it to boot after 222x11, but right now, getting home and setting a memory divider is my first attempt to defeat this bottleneck. :D
i had issues where my A8N32-SLI would clock my o/c back to stock, found that i had to enable the PID and set it manually with a multi of 11x on my x2 4200+
As for the ram, you need to run a 5/6 divider, My 4x512 DDR400 can run at 440 speeds (220mhz) I had to set the memory limit to 183mhz in the bios with a FSB to 240mhz, and just for precaution i keep my k8 to nb @ 4x (960mhz HTT link)
I'm running 4x512mb Mushkin value all day long at 440 speeds no problem. Make sure for testing to keep 3-3-3-8 and command rate at 2T, to see if its stable, then if it makes it then start tightening timings down.
My general guideline to overclocking is that I never force the HTT to go higher than what it's rated for, there is no need really, there is no performance gain, and i also don't run my ram out of spec... Memory issues are a PITA, especially when you're on the fringe of your DIMM's abilities becuase issues can appear at vary random times. So I always bring my HTT multiplier down and use a memory divider when I'm using DDR400 memory. I then simply raise the reference clock until my memory speed is back up to DDR400 or close to it.
Ok, after a couple hours, here is what I ended up with.
Thanks a ton guys for helping me work out understanding all the numbers being flung around. I ended up at 5:6, 166MHz. I kept getting confused over the fact that some people talk in terms of memory clocks before the multiplier and others, after the fact. :eek:
My earlier problems were a combination of HT link and RAM limits, I've come to realize.
Again, thanks.
