Well I'm having mixxed feelings. I went ahead and bought the 3500+ from Monarch for $299 and a K8N Neo2 Platinum from Newegg. I'm using a Zalman 7000A-cu cooler right now, as my XP-120 needs to be lapped badly! It's horrible. However the XP-120 does fit the K8N Neo2 Platinum with no problems.
The processor is a Week 37.
Right now, I'm 24 hour Prime 95 stable at 260x10 for 2.6ghz. Voltage as indicated is 1.57 under load. Below that and it will error in Prime. I can't really get any stability past 2.6, no matter what voltage I throw at the CPU. Whether it's 11x238 or 10x261.. it will error. It will boot into Windows at 2.75 with no problems, but it's not stable. I'm doing all of my testing on my desk, with a spare 300 watt power supply (don't laugh, it's better than the 500 watt Allied I had on it earlier). Man it's nice not working inside of a case! The 12v rail drops to 11.82 as indicated by my Fluke DVOM under load. Not sure if if my main systems PC Power and Cooling 510 Deluxe will help in terms of pushing the CPU a bit further. I'm just running it with a single stick of Kingmax PC-2700, and a old 10gb Maxtor hard drive. 2.6ghz is nothing to complain about. Now that I kind of know the limit of the CPU, I'll be able to screw around with the memory this coming week when my second gig of PCZ 3200 EL Rev.2 shows up.
I was hoping for 2.66 ghz, as that would give me DDR533 with my OCZ 3200 EL Rev.2. I'll have to play around with the memory some, because at some points I'll be running 2gb for some of the stuff that I'm working on. If I can't get 100% stability in Prime95, then I'll have to fall back to slower speeds.
So far, this board has given me no problems at all. Easy to set up, runs good. No blue screens or anything like that. I had some lockups, but that I believe was attributed to my Allied 500 watt test power supply dropping the 12v rail under load to 11.49 volts. So far with this 300 watt Enhance power supply, I've had no lockups. Temps are decent, about 54C under full load, 40C idle.
Not sure it was worth the extra $80 or so over a 3200+ since most of those are hitting the same speeds.
