I'm posting my current attempt at overclocking this aging cpu in order to get any kind of feedback or advice you guys have to offer.
I am using the machine in my sig (if you want any more detailed information about it, just ask), Prime 95 with "In-Place Large FFT" torture test, CPUZ, Speedfan 4.28 to read temperatures, and Clockgen 1.0.4.6 to change FSB in WindowsXP.
1:
Bios:
Vcore=1.450V
Vram=2.75V
HT Freq=800MHz
Ram Timings=2.5-4-4-8-2T
CPU Multiplier=11
CPUZ reads Vcore=1.464
Max Stable Clocks:
Fsb=218
Ram=218
CPU=2397.6
Temps:
Idle=36
Load=51
Analysis: Loosening the ram timings has given me a small increase of 197.6MHz at reasonable temperatures.
2:
Bios:
No changes, except Ram:CPU ratio set to 166:200
Max Stable Clocks:
FSB=218
Ram=171.26
CPU=2397.6
Temps:
Idle=36
Load=50
Analysis: Lowering the ram speed has no effect on max overclock, therefore, the CPU is limiting the max overclock, not the ram.
3:
Bios:
No changes, except Vcore=1.475
CPUZ reads Vcore=1.488
Max Stable Clocks:
FSB=218.7
Ram=171.86
CPU=2406
Temps:
Idle=36
Load=54
Analysis: Increasing the Vcore gave a small boost in CPU max overclock, 8.4MHz difference. Load temperatures may be getting too high.
I'm not sure how much farther I should safely go. I am using the stock cooler, but I'm having trouble finding the optimal/max temperatures and voltages for this chip.
Should I try upping the chipset voltage?
I am open to the option of buying an aftermarket CPU cooler.
Any suggestions, comments or words of advice are welcome.
1:
Bios:
Vcore=1.450V
Vram=2.75V
HT Freq=800MHz
CPU Multiplier=11
Max Stable Clocks:
Fsb=218
Ram=218
CPU=2397.6
Temps:
Idle=36
Load=51
2:
Bios:
Max Stable Clocks:
FSB=218
Ram=171.26
CPU=2397.6
Temps:
Idle=36
Load=50
3:
Bios:
Max Stable Clocks:
FSB=218.7
Ram=171.86
CPU=2406
Temps:
Idle=36
Load=54
