mulletmaster
- Nov 23, 2004
Hello guys -
I had recently bought a A64 system and I have noticed my procesor is running pretty hot, making it almost impossible to overclock.
These are the specs of my system (The ones that would effect the tempeture):
-Thermaltake SILENT BOOST
http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-036&depa=1
-GIGABYTE "GA-K8NS PRO"
http://www.newegg.com/app/ViewProductDesc.asp?description=13-128-241&depa=0
-Lian-Li 12-Bay Silver Aluminum Case
http://www.newegg.com/app/viewproductdesc.asp?description=11-112-024&DEPA=0
And heres my CPU-Z information for my CPU:
Im using Motherboard Monitor to monitor my CPU temp.
The highest I have seen the temp go up to is 70 degrees celcius (This was when I was playing Counter-Strike: Source). And it normaly idles around 55 degrees.
My concerns is, that I would like to be able to OC this chip in the future, but at the looks of it im already running dangeriously hot now.
What might be the problem with it running so hot? Is it becuase its a Clawhammer core? Or maybe my case is way to small (2 fans on front blowing are in, 1 in back going out, 1 on top going out). Or possibly that heatsink is a pile of junk.
Oh, and just to throw this in there, my video card (BFG 6800 GT OC) idles around 56 degrees.
Could anyone help me out and decypher what is wrong here?
