a64 3200 owners, plz help
Jared701
what are your temps with stock heat sink, or another heat sink at idle/load? thinking of getting slk948u for my fx, but dont know how well it cools, says it keeps a 3200 at 31 idle and 39 load not overclocked, is that good?
I'm looking forward to an A64 system, once a mobo to my liking becomes available.
A question though, and I suppose this will vary from motherboard mfgr to mfgr.
Is that the temps one would expect?
I won't say the expected, "seems high, cause I don't have an A64 system to compare.....just wondering. :confused:
I'll add my results, but I don't know how useful they will be. I'm running with a Koolance case. I never really looked while it was idle either, under load (Folding) I was getting numbers in the 40-45C range as measured by MBM on the temp diode.
