A64 3200+ (nc) OC + Voltage question...
krizzle
Well, I can push it to about 2.53 (11x230) but it tends to get a bit unstable... my question is, what should the VCore be increased to? Stock is 1.500v, so if I increace fsb by 30, what should I increace VCore to? I'm fairly new to voltage changing, so I could truly use some advice.
Plus, how come is it that if I set the multiplier to 9, fsb to 250, making it run at almost stock speed of 2.2ghz, it works in Bios but won't boot windows???
My ram can handle 250mhz, and my propertly installed Koolance Exos runs the CPU at about 28-32c (my room is cold) max. I don't trust the mobo's temp reading, it has trouble with newcastles. Should I increase VDDR? for that as well?
Thanks for your help
