A64 3200+ 90nm Overclock Problems...
Matrix333
im trying to overclock my A64 3200+ 90nm processor but every time i go to the 'HT Frequency' in the bios there are no options inside the window and my bios locks up so i have to reboot. ive tried reflashing my bios and it didnt help...
Please help!
here is my new system:
Athlon64 3200+ 90nm
MSI K8N Neo2 Platnium BIOSv1.3
2x512MB Corsair XMS XL 3200+ Platnium TwinX
Thermalright 948U All-Copper Heatsink
Vantec Stealth 92mm CPU Fan
ThermalTake 480w Purepower W0020+PFC
Gigabyte GeForce 6800GT @ 400/1100
if i get this problem fixed, i am thinking of trying this overclock:
VCore 1.5v
Mem 1.7v
FSB 250x10 = 2.5GHz
HTT 4x
Memory Timings 2-2-2-5-2T @ 208MHz
then maybe try pushing it a little higher...
what do you think?
It is a known issue with that motherboard. I have the same problem.
Use the +/- keys on your numeric keypad to adjust the value. There could be a different way but I haven't heard of one. Let me know of your overclock success.
so instead of pushing ENTER to open up the options....
i should just select it and press - ?
ill give it a try, i hope it works!
worked great!
thanks for the advice
i am now running at those speeds i was shooting for:
VCore 1.6v
Mem 2.7v
FSB 250x10 = 2.5GHz
HTT 4x
i had to up the vcore to 1.6 in order to achieve those results
i may try to push it a little higher
i was hoping my memory could run at 500MHz, but i could only get the FSB up to 225 at 1:1 which kind of sux....i should have gotten the balistix memory i was originally going to buy.
EDIT: and my idle temp only went up 2 degrees! from 36 to 38
btw, if a computer is brand new....does it overclock less than it will once it is broken in?
Nice, I can't get mine to overclock at all.
And no, the only thing that "breaks in" is the cpu thermal compound.
Matrix333 said:
worked great!
VCore 1.6v
Mem 2.7v
FSB 250x10 = 2.5GHz
HTT 4x
Did you up your memory timings when trying to run 1:1? Try again at 3-3-3-6.
btw, what would make a benchmark freeze for a few seconds in the middle of the benchmark...killing my score?
CPU?
Memory?
GFX (core or mem) ?
i dont think it is the GFX, because before I overclocked my CPU it worked fine at 400/1100
weird...i cant oc my GFX at all otherwise it keeps freezing in the benchmarks...
i updated my GFX firmware so it runs at 1.4v instead of 1.3v
do i need to up the agp voltage in the mobo bios as well?
hmmm
i think it is because FastWrites is on...
but when i turn it off and hit apply, it just turns it back on...
i cant get the damn thing off!
i forgot to turn fastwrites off in the mobo bios after i reflashed my bios
so i got that off
now i can run it at 400/1100
with fastwrites on, i was able to complete aquamark3 ONE TIME without any hiccups and i got 69,658
with fastwrites off i can only get 67,788
i can run my ram at DDR500 speeds at 2.5-3-3-7-2T on all benchmarks
but while running Prime95 it always gets an error within the first 4 tests
same with 2.5-3-3-10-2T
i thought this stuff can run at DDR500 speeds at 2.5-3-3-7-2T according to the anandtech review :mad:
it runs Memtest just fine though...
HTT is at 4x250 = 1000 so that cant be the problem
so is it the processor? 2.5GHz @ 1.6v
I have the same probs. I have the OCZ R2's and cannot get anand's results either. I have a PCP+C psu so i doubt its a power issue. I got a DDr booster and will try 2.9v but the booster wont fit with the sticks in the bottom 2 slots, so i have to mod the booster so it will clear. I had the XL at first, and at anands settings, the XL crashed in the first 5 minutes. The OCZ r2 runs for 2 hours before crapping out in prime. I think its a heat issue wit the cpu. I got a water cooling kit going in the rig in about 2 weeks. If i find anything ill make a post about it.
mine passes every benchmark and hardcore gaming flawlessly
it even runs memtest for 15+ hours with no errors
but Prime95....it will get an error within 15 minutes everytime
so i dont know...
Drop HTT to 3
Put memorry to 2.5-3-3-8-1T
drop multi instead of 10 to 9
set it to 295.
From there slowely tighten the timins.
