I just installed my new AMD A64 3000+ (NewCastle CG Revision) on a Chaintech
VNF3-250 (NForce3) motherboard with 512 Meg CL2.5 DDR3200 Corsair Value Select Memory. I'm new to oc'ing CPUs so I don't know all that much about it, but I have been oc'ing videocards for a couple of years with good success.
I go into the bios and change the CPU Frequency to 210 mhz (CPU @ 2100mhz) and it works perfect, I move it up to 215 (CPU @ 2150) and I get random crashes while benchmarking. Most ppl with the same setup seem to be getting the CPU overclocks of 2200mhz-2400mhz.
It seems like moving up the CPU frequency also moves up my memory frequency, which I believe is causing my problem. I know it's not the best overclocking memory and most ppl are only able to run it @ 210mhz, but it's what I have and I won't have the money to buy better RAM for a while.
I've read about people running the processor at 250mhz, but keeping the RAM at 200mhz or 210mhz through some sort of multiplier/ratio, but I've been looking around for an hour now and can't find anything mentioning how to do this.
Any suggestions on what I can do to get a higher overclock??
