Source : http://www.hwupgrade.it/articoli/1193/index.html
For gamers and dual core ( Thinking unreal 3 + here ): GDC 2005
Pirox - no BW leeching please. Leave them as inline links.
TechHead
No comment.GS: Do you imagine this will give you a large cost-reduction advantage over Intel?
JS: It's going to give us a cost-reduction advantage. The other thing, too, is it gives us a huge performance advantage. Just think of it conceptually. They've got two dies, they've got the two Hershey bar squares on there. Then they've got to put something else, some other piece of logic to arbitrate, so that when an application comes in it says, OK, die 0, die 1, die 0, die 1, etc. I haven't seen it, but I can't wait to get my hands on it. They'll have a package, they'll have some little pieces of silicon, and they'll have the two die cut together and stuck on the package, and that's how it'll look, right?
We're not going to have that. The way things happen is that requests come in, and this system request interface will arbitrate, and the caches are going to communicate. The communication for the CPU to check to see if this cache is using the information or not, that's all at the speed of the processor. There's no front-side bus. It's not going across the front-side bus and checking and then coming out and back. It's right there. It's natively there, and it's going to be a huge performance benefit, and that's on top of our natural AMD 64 performance benefit. I think Intel is going to be grossly disappointing. I think for anyone who's buying it for what they think they can get out of it, they're not going to get what they expect. And I think with our case, they're going to get more than they expect.
TechHead
