A
  • Thread starter Deleted member 104402
  • Start date
K10 said:
i'm planning on getting another dell 2405 for a dual monitor setup, and my question is: how much more system resources (cpu, memory, etc.) will a dual setup use versus just one monitor?
Well, if you have the kind of system to drive a dual 2405 setup, then it's likely that you can safely consider the added resources "negligible". I've never seen it cause much of an added load on any of my systems to add any number of displays anyway, and you're probably running a comfortable setup anyway.. so .. happy dualing :)
Windows itself tends to use a few mb for every extra monitor you add.
So far with 8 monitors I'm at 622mb page file usage with a few firefox windows opened and a few other things running
