a
  • Thread starter Deleted member 104402
  • Start date
Gimme 10 minutes with a razor blade and I'll sell you my old worn out one, just how you'd like it ;)
give me more than 50% of it and its a deal. As long as u have atleast half of a bill the bank will give u a shiny new one
Nope, three corners at my bank.
buy a func instead, the ratpad wears out after about 6 weeks. Plus with the func you get a tin!
Anyway. I'm 99% sure you can't get an unbadged ratpad cause thats the way they are. The older models (which were 10000000 times better) had one that wore off after a while so they remidied that by removing part of the surface and placing a stupid logo on it. Then they made it 1/3 as thick, which made it flimsy. Then they used a different plastic that wore out really quickly, which made it gay. Just get a func if you havent alreaady ordered anything.
As long as you can read the string of numbers on the bill (Serial number ???), they will accept it.
I vote for Icemat, that is really the long lasting pad, plus you'll always have good gliding.
