a
  • Thread starter Deleted member 104402
  • Start date
what kind of question is that? the damn card isnt even out yet so there has been no benchmarks from legitimate sites. :rolleyes:
if you have looked at ANY of the info for the last week you would know that the 8800gt appears to be a little faster than the 8800gts but not quite as fast as the 8800gtx. for the time being you should be able to draw your own conclusions from that.
Actually from the rumors currently, it's likely to get close to 100% increase in performance. Who knows what it'll really be though.
what the heck are you trying to say? the 8800gt is around 3 times as strong as the 8600gts so thats 200% stronger.
i should return the 8600gts and get the 8800gt instead considering the huge performance increase.
on a side note: the best way to humble your new pc is by running next gen games. :)
even the 8800gt is going to struggle in many games at the native resolution of your 24inch Dell. I cant believe you ever even considered the 8600gts.
lulz, 8600 is terrible for anything over 1280
You will get a huge increase from the 8800gt
but your native resolution is high, I'd actually consider 8800gt's in sli tbh.
