StellaTerra
- Oct 17, 2008
I had an interesting realization today: Max temps for GPUs are significantly higher than max temps for CPUs, at the same time that temp deltas across water blocks are lower. This means that a GPU loop can stand significantly more than a loop that includes a CPU. So here is how my crazy thought goes:
Let's talk worst case scenarios.
I live in Santa Cruz california. Temps here will never exceed 40 degrees celsius, or if they do I'm going to be too uncomfortable to be playing a video game, so ambient air temps are 40C.
At 1000 RPMs of the yate loon the XSPC RS120 radiator has a water-air temp delta of .094 C/W according to martin's lab. Let's assume that that's a good, but average score under most circumstances with a single-120mm radiator.
Now let's bring out the real crazy. Most people on the forum probably wouldn't recommend a GTX 280 on a single rad loop, but let's say we're out of our freakin skulls, and we put two on it, at stock clock. That's ~200W of heat a piece worst case scenario, so 400W is the number. That's 37.6 temp/air delta. Frying, I know, but wait for it.
Now let's say we're using a Fuxion GFX on each of the cards, which according to martin has a water-gpu delta of always less than 15.
That's 40 + 37.6 + 15 = 92.6. Yes, that's some hot video cards, but here's the thing: They don't crap out until 105C! At absolute worst case scenario a single 120 on ultra low settings is enough to keep two GTX 280s at stock from shutting down. This is possible because the finicky CPU isn't in the loop. I'm not 100% sure that all of these stats apply the same given the extreme temps, but from what I understand the greater deltas should be in the radiators favor. In addition I don't think the GPUs would ever ACTUALLY dump 400W of power into the water.
So here's my final thought: I think you could cool a fairly easily cool an entire stock (or moderately overclocked) system on two 1x120mm fan radiators with two separate loops at nearly silent fan speeds, all from inside the case without doing any modding. Imagine what you could do with higher fan speeds! The key, I think, is keeping the CPU isolated in it's own loop.
