This is my second water-cooled build with the focus of top-tier performance/cooling in a compact case. This machine is used mainly for benching, schoolwork and gaming. The highlight of the build is the water cooling loop. The emphasis is placed on using fittings and adapters instead of tubing to connect in tight spaces while maintaining nice lines. Total tubing used was probably less than 10 inches. Total fittings used was around 40. Had a great experience modding this.
CPU: 4.7ghz i7-4770k
GPU: R9 295x2
RAM: Trident X 2x4GB
MOBO: ASUS Maximus Impact VI
Watercooling:
Aquacomputer 295x2 nickel plexi block with active backplate
Maximus VI impact full cover nickel plexi polished
EK, Enzotech, Bitspower, swiftech bits
If you guys liked this build, head over to Mod of the Month on OCN to show some support by voting!
More pics
GPU: R9 295x2
Watercooling:
More pics
