hi there, i built a system according to a past review of this site:
Prescott 2.4, Asus p4p800se, kingston 512*2 DDR... stuff and a radeon 9600xt in an Aopen 350W case
anyway, i've enough of stock fan's noise!
my first concern is to eliminate this noise, then, as we know 2.4 is capable of performing well @3.3 with stock fan, but for further OC, ie 3.7GHz, i also prefer the CPU fan to be able to perform well
to sum up, i'm a newbie when the issue is cooling, etc. i've limited budget, water cooling isn't an option. plus many fans, including good Zalmans are incompatible w. my asus mobo (size is an issue)
so, i wish some of you who have a similar configuration to give me some product advices?
thanks in advance
thanks in advance
