A Shot in the Dark!
nibble-1
I've been asked by a company I used to work for, if I could look at the Raid configuration of one of their clients. It is using a HighPoint RocketRaid 2720 card, but one of the sas - sata cables was faulty, which has caused one disk in the array to be missing and another to be degraded; the other 4 disks are okay. The array is set to disabled.
Searching on the web, I have seen that there was a small piece of software from HighPoint called raidtool.exe, however the last reference to it is many years ago. I can't find a downloadable copy, and so was wondering if anyone had a copy of it still buried in their archived bits of utility software. Before deleting the array and recreating it, I was going to see if this might get the array back to critical, and from there try a recovery process.
Thanks for any help in advance
You can find the software you are looking for here. You didn't mention what RAID level you had the array set to, but by losing 2 drives unless it was a RAID 6, or a RAID10 variant AND the RIGHT 2 drives failed you are likely SOL. This card is over a decade old now and long EOL'd. Suggest to your client that they upgrade. It was a shit card 10 years ago, it has not improved with age.
