A second 8800GTX or 260?
john8msu
See my system specs in signature. Main application for the near future is just World of Warcraft. With the new expansion, I'm not running at quite the FPS I would like to.
Should I upgrade to a single, newer card like the 260 or go SLI? I can't seem to find a good deal on an 8800GTX anywhere. Is it okay to run a 9800GTX with an 8800GTX?
Thanks.
You cannot run a 9800GTX in SLI with an 8800GTX, since they use different GPUs. Since you can't seem to find another 8800GTX either, it would seem that your best option is a new card.
Your monitor, I think you mean Dell 2405W? Should just sell the 8800GTX card and grab a GTX 260 (216)
I would go with SLI since it would be cheaper and the only game that you really play is WoW. I don't think you can find a new 8800GTX anymore, although I think people are selling their old 8800gtx for relatively cheap. I remember seeing some go for ~$80-100 in the F/S section.
well from all the stuff ive read the 260 is a really nice card and is a good upgrade from the 8800 series cards, even the gtx. its faster, cooler and quieter. im sure you could recoup some of your money by selling off that 8800gtx. i have an 8800gt and im planning on picking up a 260 in the next month or so unless something else better for the buck pops up.
I am in the process of this upgrade, as we speak.. On release day, I purchased an 8800GTS 640mb card. Skip ahead a few years now, I purchased my XFX GTX 260 (216) BLACK EDITION video card. It should be quite a substantial boost in performance..
Yeah...dumping the 8800gtx sounds like the best bet. Looks like I should be able to score $100-$125 for the old card. With the deals going on now I can get into the new one for about $100 out of pocket. Not bad.
if you can find a used 8800GTX for cheap its not a bad option. but outside of that (I sold mine for 150) sell the card and buy an "old" GTX260, or they have a great deal on a 4870 1gb for 220 AR. Another options is that if your willing to use cash back you can get a GTX280 for under 300. A lot of nice deals right now if you look in the hot deals forum
So I jumped on a decent deal and bought a GTX 260 core 216 a few days ago. :D
I did it without thinking too much though. I have an older mobo, EVGA 122-CK-NF68-T1 LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard (link). Doesn't mention any support of PCI Express 2.0. Can I still run it on that board? Will there be a decrease in performance?
Its backwards compatible. Your 680i will suffice.
So what's the point/difference with the 2.0 cards out there now if the mobo doesn't have to support it?
Because for boards that do support it, they have double the bandwidth available than they would have in a 1.0 or 1.1 slot. It's not a big deal now, but in the future as cards require more bandwidth, there will be a performance hit from running them on non-2.0 boards.
Okay that makes sense. So basically the GTX 260 isn't going to be pushing the bandwidth limit of the 1.0 bus.
I take it the same is true for SLI? Two different slots = two different buses I assume. So I wouldn't be gimped if I picked up a second card at some point....right?
Right. Each of your PCI-E slots has 16 lanes, which is plenty for these cards even at 1.0 bandwidth.
I was in your shoes last summer (have an 8800 GTX). I'm really glad I chose a factory OC'd GTX 260. Performance is great and I don't have to mess with SLI.
Same here on the 8800GTX upgrade. It's a very confusing time at the moment for upgrades. the 260 will end up being my choice (2 of them I think) that is unless the 280 come way down in price in a month (doubtful)
I have the same 680i motherbaord as well. It is still a solid board. Still in debate whether to get an i7 or just pop a quad core + 260(s) on to this board.
Like I said above, it's still all a gray area. choosing an upgrade never used to be this difficult. Might be because only get to upgrde every 18 months now instead of every 8. :(
