A request for a hyperthreading benchmark.
Discussion in 'Intel Processors' started by Raghar, Mar 22, 2013.
  1. Raghar
    Raghar Limp Gawd
    209
    Jun 23, 2012
    I wrote a small program that should test certain stuff on hyperthreaded CPUs, and I need few people who would run it.
    https://mega.co.nz/#!QJgXSTjL!berfU1KkBqBqrtTSQA1-Uh762A4yIVWgMvZYOyghkoY
    The required steps are:
    Turn off hyperthreading and run pack4C.
    Turn on hyperthreading and run pack8C.
    It create two html files, and I guess the first 10 lines in each file are important.
    If you have only two core CPU, use pack without hyperthreading, and pack4C for test with hyperthreading.
    It requires 64 bit Java. http://java.com/en/download/manual.jsp
  2. drescherjm
    drescherjm [H]ardForum Junkie
    14,448
    Nov 19, 2008
    Is this supposed to work on 12 threaded processors like the i7 970?
  3. Raghar
    Raghar Limp Gawd
    209
    Jun 23, 2012
    I can modify it, but this version wouldn't have enough memory/cache conflicts to provide correct data.
  4. drescherjm
    14,448
    Nov 19, 2008
    I will see if I have time to try it on a 4core / 8 thread CPU then..
  5. Gunter.
    Gunter. n00b
    9
    Mar 4, 2013
  6. DejaWiz
    DejaWiz Oracle of Unfortunate Truths
    18,973
    Apr 15, 2005
    I'll try this tonight when I get home from work.
  7. Raghar
    Raghar Limp Gawd
    209
    Jun 23, 2012
    Thanks.
    Eclipse compiled and saved a version of pack4C with additional info before I copied it. So there is version of pack4C without that additional info. Can you rerun pack4C? (You might also try to run pack as a control sample.)
    Inside is also 6 and 12 core version for these who have more cores and feel adventurous.
  8. drescherjm
    14,448
    Nov 19, 2008
    pack8c.cmd - 8 thread i7 Q740
    http://pastebin.com/2w5d2xKW
    Ahh. It looks like I can not turn HT off or at least I can not find the option in the BIOS.
  9. Raghar
    Raghar Limp Gawd
    209
    Jun 23, 2012
    Thanks.
    BTW it doesn't matter if you can't turn off HT in BIOS, OS should balance threads to real cores anyway. (Well, it should in theory.) Pack4C should still give some data, just not as accurate as without HT.
    Now I need only 5 more testers to get proper statistic data and to be able to remove possible flukes (caused by power management, or hidden CPU defects)
    Also I need two desktop users to run pack.cmd as well as other benchmarks to establish base to be able to do proper scaling.
  10. defaultluser
    defaultluser [H]ardForum Junkie
    12,460
    Jan 14, 2006
    Core i3 2100t, 2c/4t
    pack (2 core):
    Code:
     62733665 4179871
     12718824 4179871
     61043131 4179871
     21900993 4179871
     19729325 4179871
     27719335 4179871
     26474629 4179871
     28799832 4179871
     24393277 4179871
     18657040 4179871
     18673871 4179871
     18670587 4179871
     23642021 4179871
     26137590 4179871
     25938486 4179871
     28077311 4179871
     27539937 4179871
     20545856 4179871
     18930448 4179871
     18889395 4179871
     25632236 4179871
     31226023 4179871
     31150487 4179871
     20001503 4179871
     24754538 4179871
     18672229 4179871
     18765418 4179871
     18766239 4179871
     28517392 4179871
     33821760 4179871
     35703597 4179871
     28739896 4179871
     29192292 4179871
     26767332 4179871
     26786217 4179871
     19033900 4179871
     18721491 4179871
     18678797 4179871
     18663197 4179871
     25377301 4179871
     24785327 4179871
     26938931 4179871
     19298687 4179871
     18689061 4179871
     18659913 4179871
     18785944 4179871
     25067767 4179871
     18657860 4179871
     27423759 4179871
     31112719 4179871
     31160339 4179871
     23132562 4179871
     18686598 4179871
     18657450 4179871
     21855835 4179871
     18689060 4179871
     18690702 4179871
     24456499 4179871
     21352534 4179871
     25201597 4179871
     18664839 4179871
     18660734 4179871
     18651292 4179871
     22532377 4179871
     21160820 4179871
     18669766 4179871
     18663197 4179871
     18705892 4179871
     18740376 4179871
     18909511 4179871
     18665250 4179871
     18684955 4179871
     24594434 4179871
     29771540 4179871
     19325782 4179871
     20061849 4179871
     28662306 4179871
     18686597 4179871
     18865585 4179871
     24963494 4179871
     18664429 4179871
     18665660 4179871
     18653345 4179871
     18684955 4179871
     18674282 4179871
     18658271 4179871
     18660323 4179871
     18659913 4179871
     18658682 4179871
     18670177 4179871
     18663197 4179871
     18656629 4179871
     18657860 4179871
     18653345 4179871
     18658272 4179871
     18653345 4179871
     18669766 4179871
     25319007 4179871
     18749407 4179871
     18672229 4179871
     18662787 4179871
     18677566 4179871
     18661556 4179871
     18660324 4179871
     18663197 4179871
     18648008 4179871
     18673871 4179871
     18665661 4179871
     18654166 4179871
     18664018 4179871
     18643903 4179871
     18668123 4179871
     18657860 4179871
     18661145 4179871
     18660735 4179871
     18655397 4179871
     18663608 4179871
     18658271 4179871
     18653756 4179871
     18651292 4179871
     18669766 4179871
     18668124 4179871
     18661555 4179871
     18652113 4179871
     24708149 4179871
     18673461 4179871
     18722723 4179871
     18749407 4179871
     19491222 4179871
     19462075 4179871
     21200640 4179871
     20182543 4179871
     20032702 4179871
     24447056 4179871
     18851217 4179871
     20138617 4179871
     29913170 4179871
     18709176 4179871
     18675513 4179871
     18678387 4179871
     18666482 4179871
     18699734 4179871
     18690703 4179871
     18667714 4179871
     18662377 4179871
     18666071 4179871
     20190754 4179871
     23742188 4179871
     31022814 4179871
     20266290 4179871
     18661966 4179871
     18671408 4179871
     18659914 4179871
     20894390 4179871
     20430088 4179871
     18666892 4179871
     18657861 4179871
     24908074 4179871
     18662787 4179871
     18668124 4179871
     18694808 4179871
     18711639 4179871
     21852551 4179871
     21880466 4179871
     18673051 4179871
     18656629 4179871
     18659913 4179871
     18656218 4179871
     18657450 4179871
     18687418 4179871
     18657040 4179871
     18653756 4179871
     18658682 4179871
     18657040 4179871
     25791109 4179871
     18668945 4179871
     18657040 4179871
     18657860 4179871
     18670177 4179871
     18668945 4179871
     18660734 4179871
     18680850 4179871
     18758438 4179871
     18660734 4179871
     18664429 4179871
     18673050 4179871
     18669766 4179871
     18666481 4179871
     18648830 4179871
     18661144 4179871
     18659502 4179871
     18660735 4179871
     18668534 4179871
     18652934 4179871
     18652935 4179871
     18656629 4179871
     18661556 4179871
     18674692 4179871
     18654576 4179871
     18652524 4179871
     18657040 4179871
     25285755 4179871
     18738734 4179871
     18696450 4179871
     25144535 4179871
     18669765 4179871
     18669766 4179871
     25063252 4179871
     18675923 4179871
     18697682 4179871
     25086241 4179871
     18668124 4179871
     18666893 4179871
     25238545 4179871
     18806880 4179871
     18728061 4179871
     25344870 4179871
     18711639 4179871
     18674282 4179871
     27992744 4179871
     20870990 4179871
     20218258 4179871
     19063868 4179871
     18688650 4179871
     18658271 4179871
     19322498 4179871
     18835617 4179871
     18663608 4179871
     18775681 4179871
     18703839 4179871
     19489991 4179871
     25275081 4179871
     20203890 4179871
     18769112 4179871
     18735860 4179871
     19092605 4179871
     40461560 4179871
     18822891 4179871
     18778554 4179871
     25290270 4179871
     18765007 4179871
     27877797 4179871
     22097633 4179871
     30414418 4179871
     25975844 4179871
     25899076 4179871
     30223526 4179871
     21333239 4179871
     18754744 4179871
     18757618 4179871
     18785534 4179871
     28466076 4179871
     31483832 4179871
     28672159 4179871
     27286644 4179871
     22530325 4179871
     22756112 4179871
     18668944 4179871
     18692755 4179871
     18791281 4179871
     18673050 4179871
     23844819 4179871
     26320683 4179871
     18686186 4179871
     18700965 4179871
     25240187 4179871
     18671818 4179871
     25133450 4179871
     18717797 4179871
     18765417 4179871
     19686221 4179871
     18991205 4179871
     23383392 4179871
     20274500 4179871
     21889498 4179871
     31608220 4179871
     22192053 4179871
     19553622 4179871
     28925862 4179871
     18736270 4179871
     29353628 4179871
     24449520 4179871
     18655808 4179871
     19948545 4179871
     24043512 4179871
     24097291 4179871
     23655568 4179871
     20012177 4179871
     18705892 4179871
     23646126 4179871
     28011217 4179871
     21268376 4179871
     31790492 4179871
     18678797 4179871
     18675102 4179871
     25277133 4179871
     24867022 4179871
     18662377 4179871
     18863533 4179871
     18932090 4179871
     18722313 4179871
     18769113 4179871
     18819196 4179871
     18739965 4179871
     21878003 4179871
     21922751 4179871
     20109881 4179871
     30063011 4179871
     18661555 4179871
     18657861 4179871
     24828432 4179871
     18682081 4179871
     18672640 4179871
     24740991 4179871
     18834796 4179871
     18697681 4179871
     18762134 4179871
     25039031 4179871
     18691934 4179871
     24708149 4179871
     21602953 4179871
     30822069 4179871
     21708458 4179871
     20122197 4179871
     30171799 4179871
     18810576 4179871
     23659673 4179871
     20127943 4179871
     18719439 4179871
     25290682 4179871
     22913342 4179871
     19304023 4179871
     19040879 4179871
     25393722 4179871
     18660324 4179871
     18676745 4179871
     30143473 4179871
     25776330 4179871
     26454514 4179871
     23741778 4179871
     18814681 4179871
     24551329 4179871
     30449724 4179871
     25696278 4179871
     20806539 4179871
     24896989 4179871
     23900240 4179871
     28081417 4179871
     27239433 4179871
     20531898 4179871
     19383666 4179871
     19501485 4179871
     24877695 4179871
     18682902 4179871
     19161162 4179871
     18741608 4179871
     22055759 4179871
     20578288 4179871
     18728060 4179871
     18792922 4179871
     24733190 4179871
     21226092 4179871
     22667849 4179871
     19490812 4179871
     25302586 4179871
     20363995 4179871
     21329544 4179871
     22700281 4179871
     19686221 4179871
     19600832 4179871
     18670587 4179871
     18659092 4179871
     18909922 4179871
     25176145 4179871
     18660735 4179871
     19032668 4179871
     18663197 4179871
     18666892 4179871
     18670177 4179871
     24848138 4179871
     18662377 4179871
     18677976 4179871
     19232593 4179871
     18728881 4179871
     18662376 4179871
     23460980 4179871
     26476271 4179871
     18667713 4179871
     18659092 4179871
     25177787 4179871
     18666071 4179871
     18662376 4179871
     25198313 4179871
     18659503 4179871
     18675924 4179871
     25495532 4179871
     24715948 4179871
     19878345 4179871
     18864764 4179871
     18723544 4179871
     18795386 4179871
     18667303 4179871
     26722585 4179871
     31489579 4179871
     18670997 4179871
     18666892 4179871
     24754538 4179871
     18662787 4179871
     22756933 4179871
     27837566 4179871
     18709587 4179871
     18691113 4179871
     27803903 4179871
     27187708 4179871
     24509866 4179871
     19032257 4179871
     18704661 4179871
     24556666 4179871
     18786355 4179871
     18665250 4179871
     18778965 4179871
     18671819 4179871
     18667713 4179871
     19284319 4179871
     19182098 4179871
     18666892 4179871
     18668534 4179871
     20059386 4179871
     24286132 4179871
     18750639 4179871
     25369912 4179871
     19111079 4179871
     27244771 4179871
     24059933 4179871
     18800722 4179871
     18874617 4179871
     25634289 4179871
     24261500 4179871
     18660324 4179871
     25399880 4179871
     18679619 4179871
     18670587 4179871
     31117644 4179871
     18959185 4179871
     22337789 4179871
     31565526 4179871
     27678693 4179871
     18718618 4179871
     26813722 4179871
     31656661 4179871
     31618894 4179871
     31703051 4179871
     28716495 4179871
     23534053 4179871
     31542126 4179871
     26526356 4179871
     18711228 4179871
     18667303 4179871
     23894903 4179871
     28803937 4179871
     18664839 4179871
     25653583 4179871
     30466966 4179871
     21769215 4179871
     28333067 4179871
     23884640 4179871
     19692789 4179871
     18648829 4179871
     18682903 4179871
     25915086 4179871
     31697714 4179871
     31634082 4179871
     23740957 4179871
     29243197 4179871
     27688546 4179871
     25243881 4179871
     30974783 4179871
     21296703 4179871
     22636650 4179871
     20853749 4179871
     21549584 4179871
     21917003 4179871
     25108409 4179871
     26971772 4179871
     22889943 4179871
     19313877 4179871
     31635725 4179871
     31625051 4179871
     31638188 4179871
     29993633 4179871
     18684545 4179871
     18705892 4179871
     18721081 4179871
     27989460 4179871
     21983918 4179871
     25289449 4179871
     18661556 4179871
     24588686 4179871
     23285276 4179871
     19172657 4179871
     24899042 4179871
     25046831 4179871
     18827407 4179871
     18673460 4179871
     18670998 4179871
     19616842 4179871
     24467993 4179871
     18704660 4179871
     20095102 4179871
     24096470 4179871
     18768292 4179871
     20675581 4179871
     24799696 4179871
     18757618 4179871
     21769215 4179871
     22542229 4179871
     20776570 4179871
     23475348 4179871
     21683826 4179871
     18872975 4179871
     18675514 4179871
     26939752 4179871
     23292665 4179871
     18716566 4179871
     21017137 4179871
     28854021 4179871
     22997089 4179871
     20596761 4179871
     18691523 4179871
     22841911 4179871
     20672707 4179871
     18667714 4179871
     18794975 4179871
     18666892 4179871
     18659503 4179871
     18733397 4179871
     21259346 4179871
     30102422 4179871
     29117576 4179871
     19986724 4179871
     26451640 4179871
     31373401 4179871
     29757172 4179871
     22001160 4179871
     21735962 4179871
     20186648 4179871
     29724740 4179871
     22157570 4179871
     21620606 4179871
     18727649 4179871
     18670997 4179871
     24321846 4179871
     19063868 4179871
     18675103 4179871
     24279152 4179871
     31501484 4179871
     25750467 4179871
     26662649 4179871
     23421980 4179871
     29515374 4179871
     31510516 4179871
     32053637 4179871
     20393142 4179871
     21731857 4179871
     31616019 4179871
     31557726 4179871
     31384485 4179871
     31208781 4179871
     31085213 4179871
     31256402 4179871
     31290475 4179871
     31265023 4179871
     21412881 4179871
     31048266 4179871
     31067972 4179871
     31259686 4179871
     31161981 4179871
     31076182 4179871
     31246960 4179871
     31044571 4179871
     28085932 4179871
     27353970 4179871
     18667303 4179871
     18721081 4179871
     30411546 4179871
     19397623 4179871
     18729292 4179871
     23813209 4179871
     26012791 4179871
     18742429 4179871
     18691934 4179871
     18693987 4179871
     18692345 4179871
     18714923 4179871
     18795385 4179871
     18781838 4179871
     31179224 4179871
     19058531 4179871
     18925111 4179871
     18706303 4179871
    4 core:
    Code:
     63928697 4179871
     180064838 4179871
     106652239 4179871
     6549485 4179871
     6514590 4179871
     6514179 4179871
     6515411 4179871
     6510895 4179871
     6643904 4179871
     6515411 4179871
     6512948 4179871
     6513768 4179871
     6510074 4179871
     6526905 4179871
     6512126 4179871
     6525674 4179871
     6511305 4179871
     6518285 4179871
     6533474 4179871
     6512127 4179871
     6600389 4179871
     6511717 4179871
     6775272 4179871
     6513769 4179871
     6513769 4179871
     6531011 4179871
     6512126 4179871
     6524853 4179871
     6516232 4179871
     6553179 4179871
     6513769 4179871
     6510485 4179871
     6696862 4179871
     6513768 4179871
     7053606 4179871
     6515411 4179871
     6586842 4179871
     6514179 4179871
     6515000 4179871
     6513358 4179871
     6515001 4179871
     6530190 4179871
     6515001 4179871
     6552769 4179871
     16206628 4179871
     6588074 4179871
     6509253 4179871
     6547843 4179871
     6511716 4179871
     6576579 4179871
     6514179 4179871
     6520337 4179871
     6517874 4179871
     6513769 4179871
     6520748 4179871
     6512126 4179871
     6534295 4179871
     6516232 4179871
     6512537 4179871
     6513358 4179871
     6514590 4179871
     6517053 4179871
     6512948 4179871
     6508842 4179871
     6511717 4179871
     6508022 4179871
     6517874 4179871
     6510485 4179871
     6512127 4179871
     6513358 4179871
     6511716 4179871
     6531422 4179871
     6513358 4179871
     6531832 4179871
     6508021 4179871
     6516232 4179871
     6509664 4179871
     6508843 4179871
     6521569 4179871
     6514180 4179871
     6514590 4179871
     6512947 4179871
     6513358 4179871
     6510485 4179871
     6510895 4179871
     6520748 4179871
     6510074 4179871
     6519516 4179871
     6512948 4179871
     6510074 4179871
     43876701 4179871
     27550611 4179871
     7767096 4179871
     6514590 4179871
     10725735 4179871
     7318805 4179871
     7083985 4179871
     6520337 4179871
     6512537 4179871
     7365604 4179871
     7409530 4179871
     39117917 4179871
     6919776 4179871
     6508021 4179871
     7303205 4179871
     8111935 4179871
     6515822 4179871
     6527316 4179871
     6516642 4179871
     6512948 4179871
     7165269 4179871
     6518284 4179871
     6626663 4179871
     6511716 4179871
     6524032 4179871
     6512947 4179871
     6507611 4179871
     6484211 4179871
     6510485 4179871
     26034548 4179871
     6516642 4179871
     6568779 4179871
     6452601 4179871
     6516643 4179871
     6514179 4179871
     6543327 4179871
     6509253 4179871
     6511716 4179871
     6512947 4179871
     6513768 4179871
     6513769 4179871
     6510895 4179871
     6508432 4179871
     6805240 4179871
     6516232 4179871
     6668536 4179871
     6514590 4179871
     6526495 4179871
     6604084 4179871
     6511716 4179871
     6591768 4179871
     6510484 4179871
     6513769 4179871
     6509663 4179871
     6522389 4179871
     6513768 4179871
     6510485 4179871
     7368067 4179871
     6512538 4179871
     6608189 4179871
     6517053 4179871
     6531422 4179871
     6512127 4179871
     6512126 4179871
     6969860 4179871
     6512127 4179871
     9792205 4179871
     6520337 4179871
     6538401 4179871
     6513358 4179871
     6528958 4179871
     6512947 4179871
     6839314 4179871
     6512948 4179871
     6550305 4179871
     6519926 4179871
     6512538 4179871
     6513768 4179871
     6510484 4179871
     6513768 4179871
     9811090 4179871
     6513769 4179871
     6512537 4179871
     6511716 4179871
     6517053 4179871
     6513358 4179871
     14015666 4179871
     6520338 4179871
     6688241 4179871
     6515822 4179871
     6527727 4179871
     6516232 4179871
     6728883 4179871
     6515821 4179871
     6515411 4179871
     6637746 4179871
     6512537 4179871
     6517874 4179871
     6511306 4179871
     6547842 4179871
     6510485 4179871
     6512948 4179871
     6519105 4179871
     6514590 4179871
     6544558 4179871
     6513769 4179871
     6515411 4179871
     6519926 4179871
     6513358 4179871
     6512127 4179871
     6510895 4179871
     6565084 4179871
     6515821 4179871
     6507611 4179871
     6517874 4179871
     6511306 4179871
     6517874 4179871
     6510895 4179871
     6548663 4179871
     6516232 4179871
     6510895 4179871
     6523621 4179871
     6512126 4179871
     6517874 4179871
     6514590 4179871
     6513358 4179871
     6517463 4179871
     6511306 4179871
     6535116 4179871
     6514179 4179871
     6514179 4179871
     6512948 4179871
     6512537 4179871
     6817966 4179871
     6513768 4179871
     6536348 4179871
     6514590 4179871
     6523622 4179871
     6510484 4179871
     6515411 4179871
     6521569 4179871
     6514589 4179871
     6516643 4179871
     6511306 4179871
     6510074 4179871
     6985871 4179871
     6513358 4179871
     6519927 4179871
     6514589 4179871
     6535937 4179871
     6513358 4179871
     6793745 4179871
     6550716 4179871
     6513768 4179871
     6522390 4179871
     6515411 4179871
     6541684 4179871
     6510074 4179871
     6513359 4179871
     6515411 4179871
     6510895 4179871
     6544558 4179871
     6511716 4179871
     7958399 4179871
     6515821 4179871
     6515000 4179871
     6578221 4179871
     6515411 4179871
     6995722 4179871
     6514590 4179871
     6520337 4179871
     6511306 4179871
     6510074 4179871
     6567547 4179871
     6510074 4179871
     6512948 4179871
     6508842 4179871
     6529779 4179871
     6512537 4179871
     6512538 4179871
     6520747 4179871
     6510074 4179871
     6519516 4179871
     6514179 4179871
     6515001 4179871
     6507611 4179871
     6510485 4179871
     6527316 4179871
     6511717 4179871
     6513769 4179871
     6510895 4179871
     6507610 4179871
     6564674 4179871
     6509253 4179871
     6534706 4179871
     6510895 4179871
     7967431 4179871
     6514589 4179871
     6512537 4179871
     6528547 4179871
     6510485 4179871
     6534706 4179871
     6513359 4179871
     6517053 4179871
     6515821 4179871
     6512127 4179871
     6526495 4179871
     6512127 4179871
     6512537 4179871
     6509253 4179871
     6531832 4179871
     6512127 4179871
     6511305 4179871
     6535527 4179871
     6512537 4179871
     6521568 4179871
     6512127 4179871
     6514179 4179871
     6511306 4179871
     6511306 4179871
     6551126 4179871
     6511716 4179871
     6579862 4179871
     6516642 4179871
     6515000 4179871
     6526495 4179871
     6514590 4179871
     6544968 4179871
     6509663 4179871
     6536348 4179871
     6510484 4179871
     6785125 4179871
     6558516 4179871
     6512537 4179871
     6521569 4179871
     6514180 4179871
     6514590 4179871
     6512537 4179871
     6509663 4179871
     13828058 4179871
     7419383 4179871
     6514180 4179871
     6545790 4179871
     6513769 4179871
     6513769 4179871
     6531421 4179871
     6508432 4179871
     6524853 4179871
     6510895 4179871
     6512948 4179871
     6514179 4179871
     6513769 4179871
     6521158 4179871
     6515822 4179871
     6516643 4179871
     6508021 4179871
     6507200 4179871
     6529779 4179871
     6510074 4179871
     6532653 4179871
     6514590 4179871
     26331767 4179871
     6518285 4179871
     6534295 4179871
     6510895 4179871
     6512537 4179871
     6588073 4179871
     6515411 4179871
     6521569 4179871
     6513358 4179871
     6766650 4179871
     6514179 4179871
     6511306 4179871
     8564331 4179871
     6514179 4179871
     6525263 4179871
     6510895 4179871
     9828742 4179871
     6514589 4179871
     16163112 4179871
     6595052 4179871
     6515001 4179871
     6617220 4179871
     6516232 4179871
     7319215 4179871
     6519516 4179871
     6515821 4179871
     6557695 4179871
     6509663 4179871
     6579042 4179871
     6511717 4179871
     7361499 4179871
     6898019 4179871
     6519105 4179871
     21790972 4179871
     6875440 4179871
     6531832 4179871
     6517463 4179871
     26590807 4179871
     6806061 4179871
     6509253 4179871
     7657486 4179871
     8253565 4179871
     6521569 4179871
     8001914 4179871
     7160753 4179871
     6522800 4179871
     6623789 4179871
     6510895 4179871
     7019944 4179871
     6512537 4179871
     6748588 4179871
     6515000 4179871
     6937428 4179871
     6516232 4179871
     6510485 4179871
     13234851 4179871
     6520747 4179871
     6516232 4179871
     6990797 4179871
     6622968 4179871
     6509253 4179871
     6530600 4179871
     6512948 4179871
     6515821 4179871
     6511306 4179871
     8237966 4179871
     7311825 4179871
     6542505 4179871
     6516231 4179871
     6515822 4179871
     6512127 4179871
     6509253 4179871
     8951865 4179871
     6514589 4179871
     6507611 4179871
     6511717 4179871
     6513358 4179871
     6521158 4179871
     6517464 4179871
     6917312 4179871
     6513768 4179871
     6514590 4179871
     6510074 4179871
     6511717 4179871
     6493653 4179871
     6552358 4179871
     7086448 4179871
     6515821 4179871
     6524442 4179871
     6514590 4179871
     6511716 4179871
     6790461 4179871
     6509253 4179871
     6541684 4179871
     6519105 4179871
     6509253 4179871
     6512127 4179871
     6511305 4179871
     9211315 4179871
     6514179 4179871
     6639389 4179871
     6516642 4179871
     6521569 4179871
     6512537 4179871
     7975231 4179871
     6514180 4179871
     6512537 4179871
     6535116 4179871
     6515000 4179871
     6514589 4179871
     6515001 4179871
     7505182 4179871
     6512126 4179871
     6512948 4179871
     6553179 4179871
     6611063 4179871
     11812389 4179871
     6609421 4179871
     6514180 4179871
     6653757 4179871
     6534706 4179871
     6512538 4179871
     7491224 4179871
     6513768 4179871
     6562210 4179871
     6514590 4179871
     6510074 4179871
     6514179 4179871
     6509663 4179871
     7400909 4179871
     6510485 4179871
     6537579 4179871
     6511716 4179871
     6512948 4179871
     6530189 4179871
     6513769 4179871
     7444425 4179871
     6512127 4179871
     6516232 4179871
     6512126 4179871
     6514180 4179871
     6517053 4179871
     6507610 4179871
     7353289 4179871
     6512127 4179871
     6519516 4179871
     6510074 4179871
     6512947 4179871
     6530600 4179871
     6510485 4179871
     6602031 4179871
     6509253 4179871
     6508432 4179871
     6515821 4179871
     6510484 4179871
     6516232 4179871
     6511717 4179871
     8420238 4179871
     65596242 4179871
     6519105 4179871
     53002627 4179871
     17955456 4179871
     6513358 4179871
     6803187 4179871
     6513359 4179871
     53027259 4179871
     8674351 4179871
     7984673 4179871
     7304025 4179871
     7012965 4179871
     6520748 4179871
     6512947 4179871
     52764934 4179871
     6515821 4179871
     6579862 4179871
     65097045 4179871
     6518285 4179871
     7474392 4179871
     6515001 4179871
     6512537 4179871
     6512127 4179871
     6512127 4179871
     52759597 4179871
     6518284 4179871
     7387772 4179871
     6513769 4179871
     6512127 4179871
     6515822 4179871
     6513359 4179871
     52744408 4179871
     6522800 4179871
     6975196 4179871
     6517053 4179871
     6514589 4179871
     6513769 4179871
     6512538 4179871
     52821586 4179871
     6519516 4179871
     7055249 4179871
     6515000 4179871
     6510485 4179871
     37468436 4179871
     9392356 4179871
     6733398 4179871
     6613936 4179871
     6541684 4179871
     12688446 4179871
     6515411 4179871
     6512127 4179871
     6517463 4179871
     6512538 4179871
     6745715 4179871
     6513769 4179871
     7200985 4179871
     6510484 4179871
     6512948 4179871
     6529779 4179871
     6512947 4179871
     6549484 4179871
     6513769 4179871
     7181690 4179871
     6519106 4179871
     6516642 4179871
     6519106 4179871
     6507611 4179871
     7838937 4179871
     6512537 4179871
     7238753 4179871
     6515000 4179871
     6513769 4179871
     6513769 4179871
     6514180 4179871
     23286097 4179871
     6515411 4179871
     6544558 4179871
     6511716 4179871
     6521158 4179871
     6512538 4179871
     6513769 4179871
     6931271 4179871
     6515410 4179871
     13883889 4179871
     6559337 4179871
     6513768 4179871
     6511716 4179871
     10786082 4179871
     6543327 4179871
     6844240 4179871
     6514590 4179871
    HYPERTHREADING DISABLED:
    pack 2 core:
    Code:
     61802755 4179871
     13924474 4179871
     24778247 4179871
     7215323 4179871
     7237491 4179871
     7172218 4179871
     7242417 4179871
     7162365 4179871
     7169755 4179871
     7216144 4179871
     7164418 4179871
     7230512 4179871
     7213270 4179871
     7204649 4179871
     7173860 4179871
     7212449 4179871
     7222302 4179871
     7213270 4179871
     7170987 4179871
     7203828 4179871
     7216144 4179871
     7207113 4179871
     7208344 4179871
     7212038 4179871
     7154976 4179871
     7183302 4179871
     7255554 4179871
     7169344 4179871
     7160313 4179871
     7182071 4179871
     7158261 4179871
     7219839 4179871
     7161545 4179871
     7164829 4179871
     7157850 4179871
     7154155 4179871
     7161955 4179871
     7154976 4179871
     12427713 4179871
     7564266 4179871
     7163597 4179871
     7479289 4179871
     7261712 4179871
     7206702 4179871
     7173449 4179871
     7162366 4179871
     7317953 4179871
     7163597 4179871
     7196029 4179871
     7157850 4179871
     7187818 4179871
     7179607 4179871
     7226407 4179871
     7248575 4179871
     7275669 4179871
     7294964 4179871
     7282649 4179871
     7157850 4179871
     7174681 4179871
     7224765 4179871
     7209576 4179871
     7154976 4179871
     7212449 4179871
     8446887 4179871
     7159492 4179871
     7211628 4179871
     7216965 4179871
     7158260 4179871
     7157439 4179871
     7175913 4179871
     7156618 4179871
     7184123 4179871
     7150871 4179871
     7211218 4179871
     7154155 4179871
     7152102 4179871
     7164008 4179871
     7152514 4179871
     7166060 4179871
     7150050 4179871
     7248575 4179871
     7187818 4179871
     7181661 4179871
     7152513 4179871
     7179607 4179871
     7158261 4179871
     7161134 4179871
     7156207 4179871
     7154566 4179871
     7216555 4179871
     7158671 4179871
     7258018 4179871
     7160724 4179871
     7164828 4179871
     7159902 4179871
     47175880 4179871
     7247344 4179871
     8184564 4179871
     28495517 4179871
     8207964 4179871
     7307280 4179871
     7194797 4179871
     7172629 4179871
     7181660 4179871
     35290876 4179871
     7201776 4179871
     7254733 4179871
     7159082 4179871
     7175092 4179871
     7170987 4179871
     7433310 4179871
     7175502 4179871
     7164008 4179871
     7175913 4179871
     7167703 4179871
     7153745 4179871
     7157440 4179871
     9329097 4179871
     7166471 4179871
     7186586 4179871
     7160724 4179871
     7188639 4179871
     7158260 4179871
     7330680 4179871
     7161134 4179871
     7168934 4179871
     7161955 4179871
     7172628 4179871
     7155387 4179871
     7161545 4179871
     7274849 4179871
     7228459 4179871
     7161134 4179871
     7207934 4179871
     7164829 4179871
     7157850 4179871
     7383637 4179871
     7161544 4179871
     7190692 4179871
     7161956 4179871
     7169756 4179871
     7154566 4179871
     7282237 4179871
     7161955 4179871
     7186587 4179871
     7155797 4179871
     7160724 4179871
     7161135 4179871
     7154977 4179871
     7281827 4179871
     7157029 4179871
     7169344 4179871
     7154566 4179871
     7241186 4179871
     7159082 4179871
     7228870 4179871
     7159493 4179871
     7162776 4179871
     7160314 4179871
     7179197 4179871
     7160313 4179871
     7187408 4179871
     7156208 4179871
     7153334 4179871
     11480640 4179871
     7405394 4179871
     7160723 4179871
     7245702 4179871
     7215734 4179871
     7210396 4179871
     7169755 4179871
     7164008 4179871
     7367626 4179871
     7174271 4179871
     7239954 4179871
     7168113 4179871
     7164418 4179871
     7157850 4179871
     7538404 4179871
     7278544 4179871
     53481488 4179871
     7161955 4179871
     7194796 4179871
     7223533 4179871
     7161134 4179871
     7159082 4179871
     7158671 4179871
     53791842 4179871
     7166060 4179871
     8046629 4179871
     7166061 4179871
     7274438 4179871
     7159081 4179871
     7209576 4179871
     7155387 4179871
     7325342 4179871
     7193154 4179871
     7191103 4179871
     7164829 4179871
     7162776 4179871
     9650125 4179871
     7172218 4179871
     7213270 4179871
     7166471 4179871
     7155387 4179871
     7165650 4179871
     27136281 4179871
     7382405 4179871
     7386100 4179871
     7700149 4179871
     7205881 4179871
     9016281 4179871
     7184534 4179871
     7309743 4179871
     7160724 4179871
     7190692 4179871
     8268721 4179871
     7170166 4179871
     7179607 4179871
     7160313 4179871
     8145154 4179871
     7214092 4179871
     7203828 4179871
     7440699 4179871
     7334784 4179871
     7160313 4179871
     53370647 4179871
     7172218 4179871
     7304406 4179871
     7174681 4179871
     7366395 4179871
     7167702 4179871
     7264996 4179871
     7167703 4179871
     7168523 4179871
     7641444 4179871
     7696454 4179871
     7220250 4179871
     7159903 4179871
     7203829 4179871
     7160314 4179871
     7260070 4179871
     7168934 4179871
     7347511 4179871
     7170165 4179871
     25544690 4179871
     7699738 4179871
     7199312 4179871
     8476444 4179871
     7196439 4179871
     7162366 4179871
     8121754 4179871
     7182891 4179871
     7403342 4179871
     7176323 4179871
     7171397 4179871
     7154976 4179871
     8141048 4179871
     7250217 4179871
     7741201 4179871
     7202186 4179871
     8535149 4179871
     7180428 4179871
     9517116 4179871
     7165239 4179871
     7425921 4179871
     7165240 4179871
     7333553 4179871
     7694812 4179871
     8648042 4179871
     7161955 4179871
     7357363 4179871
     7168523 4179871
     7306458 4179871
     7678391 4179871
     7204239 4179871
     11671942 4179871
     7252680 4179871
     7618455 4179871
     7379942 4179871
     7231333 4179871
     21127480 4179871
     7274027 4179871
     7728064 4179871
     7690706 4179871
     7167292 4179871
     7899662 4179871
     8151722 4179871
     7198081 4179871
     7703433 4179871
     7203008 4179871
     7198491 4179871
     7736275 4179871
     7177555 4179871
     7526499 4179871
     7181660 4179871
     7164829 4179871
     7162366 4179871
     7600392 4179871
     7165240 4179871
     7726422 4179871
     7778558 4179871
     7352848 4179871
     7168934 4179871
     10149729 4179871
     7170987 4179871
     7694401 4179871
     7200134 4179871
     9050353 4179871
     7189049 4179871
     8004345 4179871
     7168113 4179871
     20372531 4179871
     7566729 4179871
     7205471 4179871
     23258496 4179871
     8266668 4179871
     10597198 4179871
     7621329 4179871
     7181660 4179871
     7722317 4179871
     7158671 4179871
     8483423 4179871
     7792105 4179871
     7182481 4179871
     7208344 4179871
     7193154 4179871
     7157850 4179871
     7163187 4179871
     8303204 4179871
     7167292 4179871
     7177966 4179871
     7160314 4179871
     7182071 4179871
     7167292 4179871
     7412374 4179871
     7732580 4179871
     7214913 4179871
     7163187 4179871
     7171397 4179871
     7154155 4179871
     8533097 4179871
     7609834 4179871
     7173039 4179871
     7168934 4179871
     7228049 4179871
     7156618 4179871
     7163597 4179871
     8239573 4179871
     7165650 4179871
     7204239 4179871
     7162366 4179871
     7207933 4179871
     7168113 4179871
     7539634 4179871
     7182892 4179871
     7347101 4179871
     7158671 4179871
     7177145 4179871
     7160313 4179871
     7407447 4179871
     7721906 4179871
     7185355 4179871
     7195618 4179871
     7184534 4179871
     7159082 4179871
     7166471 4179871
     7382815 4179871
     7176323 4179871
     7185355 4179871
     7150871 4179871
     8754778 4179871
     7174271 4179871
     7296606 4179871
     7686602 4179871
     7213271 4179871
     7159492 4179871
     9594294 4179871
     7185766 4179871
     7366805 4179871
     7170576 4179871
     7175502 4179871
     7182892 4179871
     8050323 4179871
     7160313 4179871
     7737506 4179871
     7210397 4179871
     7345458 4179871
     7172629 4179871
     7881188 4179871
     7171397 4179871
     7748180 4179871
     7206702 4179871
     7185355 4179871
     7169755 4179871
     7158260 4179871
     10323790 4179871
     7189049 4179871
     7161545 4179871
     7160723 4179871
     7167292 4179871
     7152513 4179871
     8650506 4179871
     7208344 4179871
     11184244 4179871
     7242828 4179871
     7634465 4179871
     11265937 4179871
     7186997 4179871
     7179197 4179871
     7163187 4179871
     8519960 4179871
     7793748 4179871
     7265817 4179871
     7161134 4179871
     7354490 4179871
     7173039 4179871
     7730527 4179871
     7843420 4179871
     7223533 4179871
     7158671 4179871
     7196029 4179871
     7161955 4179871
     7170986 4179871
     8003113 4179871
     7155798 4179871
     7184534 4179871
     7164419 4179871
     7176734 4179871
     7161545 4179871
     7356953 4179871
     7722316 4179871
     7201776 4179871
     7159082 4179871
     7180429 4179871
     7170987 4179871
     7268281 4179871
     7167292 4179871
     8405014 4179871
     7182892 4179871
     7169344 4179871
     7163598 4179871
     7166060 4179871
     8077007 4179871
     7161955 4179871
     7232154 4179871
     7151692 4179871
     7180018 4179871
     7166881 4179871
     10296696 4179871
     7156618 4179871
     7354490 4179871
     7158671 4179871
     7283469 4179871
     7682085 4179871
     7242828 4179871
     7213681 4179871
     7181250 4179871
     7165650 4179871
     7329448 4179871
     7163597 4179871
     7173039 4179871
     7164008 4179871
     7174682 4179871
     7166060 4179871
     7156208 4179871
     7403342 4179871
     7685781 4179871
     7188229 4179871
     7201775 4179871
     7185765 4179871
     7159492 4179871
     7191923 4179871
     7154156 4179871
     18884803 4179871
     7202597 4179871
     7156208 4179871
     22728924 4179871
     8118881 4179871
     8636958 4179871
     7163186 4179871
     7218607 4179871
     7157440 4179871
     7217786 4179871
     7163186 4179871
     7224765 4179871
     7563445 4179871
     7206702 4179871
     7160313 4179871
     7230102 4179871
     7168934 4179871
     7163597 4179871
     7220660 4179871
     7154155 4179871
     7183303 4179871
     7162366 4179871
     7166060 4179871
     7162776 4179871
     7157440 4179871
     7166470 4179871
     7178786 4179871
     7159492 4179871
     7162776 4179871
     7150871 4179871
     7157850 4179871
     8420614 4179871
     7157850 4179871
     7161955 4179871
     7157850 4179871
     7369268 4179871
     7156208 4179871
     8021586 4179871
     7162365 4179871
     7205471 4179871
     7164008 4179871
     7200544 4179871
     7156618 4179871
     7218197 4179871
     7162366 4179871
     7165650 4179871
     7157849 4179871
     7159081 4179871
     7161955 4179871
     7151692 4179871
     7467384 4179871
     12043464 4179871
     7167702 4179871
     7180018 4179871
     7157439 4179871
     7733812 4179871
     7169755 4179871
     7171398 4179871
     7159492 4179871
     7188639 4179871
     7158261 4179871
     11371031 4179871
     7538814 4179871
     7515004 4179871
     7160313 4179871
     7292501 4179871
     7170166 4179871
     7197260 4179871
     7168113 4179871
     7200544 4179871
     7162776 4179871
     7163187 4179871
     7156618 4179871
     7415247 4179871
     7168113 4179871
     7164829 4179871
     7169755 4179871
     7167703 4179871
     7191513 4179871
     7159492 4179871
     7714927 4179871
     7166061 4179871
     7609424 4179871
     7253091 4179871
     7200955 4179871
     7209576 4179871
     7181250 4179871
     7171397 4179871
     7229691 4179871
     7167292 4179871
     7212038 4179871
     7223123 4179871
     7169345 4179871
     7221070 4179871
     7162776 4179871
     7229691 4179871
     7154976 4179871
     7178787 4179871
     7216554 4179871
     8398034 4179871
     7166061 4179871
     7187407 4179871
     7222712 4179871
     7218607 4179871
     7356542 4179871
     7430847 4179871
     7161134 4179871
     7230512 4179871
     7229280 4179871
     7367216 4179871
     7166882 4179871
     7154566 4179871
     7171808 4179871
     7152924 4179871
     7196029 4179871
     7152513 4179871
     7152924 4179871
     7153334 4179871
     7171397 4179871
     7155387 4179871
     7160313 4179871
     7160313 4179871
     7154976 4179871
     7157850 4179871
     7149229 4179871
     7174270 4179871
    pack 4 core:
    Code:
     180140456 4179871
     184151660 4179871
     279724721 4179871
     171467372 4179871
     221547280 4179871
     199773639 4179871
     189424396 4179871
     192476211 4179871
     179820660 4179871
     187077446 4179871
     186496968 4179871
     187289685 4179871
     187161602 4179871
     186859869 4179871
     158755168 4179871
     183992378 4179871
     187375484 4179871
     171342573 4179871
     187095919 4179871
     186896816 4179871
     202890317 4179871
     187021614 4179871
     186985899 4179871
     187086477 4179871
     187092634 4179871
     187529840 4179871
     139839166 4179871
     156023969 4179871
     171526076 4179871
     187169813 4179871
     186995751 4179871
     155935707 4179871
     149649805 4179871
     164355910 4179871
     165343625 4179871
     159835250 4179871
     171822883 4179871
     173125467 4179871
     185517054 4179871
     171379520 4179871
     172453033 4179871
     185998595 4179871
     171547013 4179871
     187151750 4179871
     171659085 4179871
     186891069 4179871
     156244009 4179871
     186845501 4179871
     187082782 4179871
     171928387 4179871
     172420191 4179871
     185808524 4179871
     187221538 4179871
     187148055 4179871
     187000678 4179871
     171785116 4179871
     188665342 4179871
     169664362 4179871
     172013776 4179871
     186613967 4179871
     187346337 4179871
     173428843 4179871
     169712393 4179871
     186983436 4179871
     172931701 4179871
     185578632 4179871
     187141076 4179871
     187228107 4179871
     171676737 4179871
     186555673 4179871
     171561791 4179871
     187054867 4179871
     187067182 4179871
     182450459 4179871
     176494616 4179871
     186691145 4179871
     172897217 4179871
     170234165 4179871
     187233854 4179871
     157164398 4179871
     170358964 4179871
     186848374 4179871
     171669758 4179871
     187019562 4179871
     171505550 4179871
     155904918 4179871
     187141487 4179871
     187089351 4179871
     171670990 4179871
     187077445 4179871
     187042962 4179871
     187153392 4179871
     171493645 4179871
     187151339 4179871
     171643896 4179871
     171435761 4179871
     171753915 4179871
     186654198 4179871
     187036803 4179871
     187301590 4179871
     171249795 4179871
     187141486 4179871
     172845081 4179871
     154695112 4179871
     171454646 4179871
     188386597 4179871
     185861892 4179871
     171517045 4179871
     145258458 4179871
     166580936 4179871
     187252738 4179871
     186982615 4179871
     171541265 4179871
     171575339 4179871
     171496929 4179871
     187027772 4179871
     187133276 4179871
     187120140 4179871
     171527718 4179871
     171447667 4179871
     171630349 4179871
     186960857 4179871
     187171865 4179871
     171403741 4179871
     171696442 4179871
     171637327 4179871
     171046588 4179871
     187108235 4179871
     187118908 4179871
     187071698 4179871
     171539213 4179871
     155911897 4179871
     187132045 4179871
     177825116 4179871
     180692196 4179871
     187146823 4179871
     160683387 4179871
     183637277 4179871
     185860250 4179871
     187187465 4179871
     171511298 4179871
     171565897 4179871
     156099095 4179871
     186924321 4179871
     187047478 4179871
     187104129 4179871
     187102898 4179871
     187120139 4179871
     171519097 4179871
     187125476 4179871
     171559739 4179871
     187060204 4179871
     187118497 4179871
     171550297 4179871
     187121371 4179871
     171636506 4179871
     174846373 4179871
     162453555 4179871
     147394400 4179871
     170137282 4179871
     149603826 4179871
     135882150 4179871
     127984952 4179871
     178851829 4179871
     171551939 4179871
     129573669 4179871
     135545934 4179871
     144230102 4179871
     143650857 4179871
     135826320 4179871
     137260271 4179871
     171433299 4179871
     142692289 4179871
     169133968 4179871
     172760924 4179871
     170280143 4179871
     171473529 4179871
     187122193 4179871
     171742421 4179871
     156860201 4179871
     185654168 4179871
     187049530 4179871
     171743653 4179871
     186895994 4179871
     172268710 4179871
     186422253 4179871
     171511297 4179871
     171478866 4179871
     171669759 4179871
     186938689 4179871
     171810977 4179871
     186868490 4179871
     187004783 4179871
     171668527 4179871
     187057330 4179871
     190319333 4179871
     152617053 4179871
     155892602 4179871
     187120140 4179871
     171860241 4179871
     171170154 4179871
     187136560 4179871
     171691927 4179871
     171322458 4179871
     171517045 4179871
     187110698 4179871
     172824965 4179871
     170386469 4179871
     186888605 4179871
     187164475 4179871
     187043783 4179871
     187133276 4179871
     171878714 4179871
     171048640 4179871
     187115213 4179871
     187032698 4179871
     171567539 4179871
     171573286 4179871
     187043783 4179871
     171513350 4179871
     171436172 4179871
     144414837 4179871
     136145295 4179871
     155914361 4179871
     187292969 4179871
     171354068 4179871
     187086888 4179871
     179078437 4179871
     179582147 4179871
     171636917 4179871
     186983435 4179871
     171569181 4179871
     171583549 4179871
     171679201 4179871
     186861100 4179871
     187018331 4179871
     171856956 4179871
     186869721 4179871
     190800052 4179871
     171120481 4179871
     184190249 4179871
     186641061 4179871
     155925445 4179871
     171519507 4179871
     187111108 4179871
     171558917 4179871
     171593812 4179871
     187032288 4179871
     171553581 4179871
     155921749 4179871
     171474351 4179871
     171503497 4179871
     171556455 4179871
     187090582 4179871
     171535518 4179871
     187127118 4179871
     155875361 4179871
     187126297 4179871
     187174329 4179871
     159934596 4179871
     167430305 4179871
     171530181 4179871
     171130333 4179871
     187164886 4179871
     171501034 4179871
     155912308 4179871
     171514171 4179871
     179270972 4179871
     163808275 4179871
     171508424 4179871
     172111480 4179871
     155260810 4179871
     186962910 4179871
     171551118 4179871
     156049011 4179871
     187001089 4179871
     187178844 4179871
     171489129 4179871
     187080729 4179871
     171628706 4179871
     171673864 4179871
     233859636 4179871
     218369434 4179871
     202505658 4179871
     172033481 4179871
     170936568 4179871
     171588886 4179871
     171429193 4179871
     171395941 4179871
     155948434 4179871
     186953468 4179871
     187106593 4179871
     171489951 4179871
     187148465 4179871
     171732158 4179871
     186948542 4179871
     186898048 4179871
     171555634 4179871
     187463335 4179871
     171528128 4179871
     156711592 4179871
     185986279 4179871
     171302341 4179871
     186954699 4179871
     171820009 4179871
     187002731 4179871
     171739547 4179871
     171366794 4179871
     171257185 4179871
     171621727 4179871
     171521150 4179871
     171357352 4179871
     171153323 4179871
     187006014 4179871
     186960857 4179871
     187094276 4179871
     171794557 4179871
     171289206 4179871
     187199780 4179871
     188172716 4179871
     185864355 4179871
     171549066 4179871
     171558508 4179871
     186986309 4179871
     172320845 4179871
     186333991 4179871
     155954181 4179871
     171535518 4179871
     162467923 4179871
     180488988 4179871
     234005780 4179871
     218253667 4179871
     249500498 4179871
     202951073 4179871
     186848785 4179871
     219830479 4179871
     214164874 4179871
     236821958 4179871
     264876986 4179871
     280669741 4179871
     265120424 4179871
     246708542 4179871
     207837509 4179871
     191903944 4179871
     195612184 4179871
     249483256 4179871
     233918340 4179871
     240971507 4179871
     225502242 4179871
     230360762 4179871
     240733815 4179871
     247534101 4179871
     215022454 4179871
     237193479 4179871
     280861044 4179871
     280518258 4179871
     280773603 4179871
     249495161 4179871
     265066235 4179871
     265235781 4179871
     233915876 4179871
     269001082 4179871
     245511872 4179871
     249681949 4179871
     264895869 4179871
     280828202 4179871
     265000963 4179871
     265110162 4179871
     266309294 4179871
     263960702 4179871
     265047762 4179871
     265198423 4179871
     265080603 4179871
     233945845 4179871
     249746400 4179871
     264861796 4179871
     265128634 4179871
     265250149 4179871
     264957037 4179871
     265165171 4179871
     280638542 4179871
     249871199 4179871
     264763682 4179871
     265029699 4179871
     265117551 4179871
     257893196 4179871
     256715821 4179871
     280738709 4179871
     265227570 4179871
     265022720 4179871
     280663173 4179871
     281937020 4179871
     279764952 4179871
     266271115 4179871
     263636800 4179871
     281345869 4179871
     280012907 4179871
     249493930 4179871
     266580649 4179871
     279340472 4179871
     271479811 4179871
     258637061 4179871
     280676309 4179871
     265157371 4179871
     249489825 4179871
     265186929 4179871
     280573269 4179871
     251877007 4179871
     215658351 4179871
     200404609 4179871
     191745483 4179871
     200632859 4179871
     222896253 4179871
     260578827 4179871
     227301146 4179871
     225836817 4179871
     279628249 4179871
     249498446 4179871
     265112214 4179871
     280728035 4179871
     249493109 4179871
     249500909 4179871
     234295609 4179871
     265887279 4179871
     264035827 4179871
     265199245 4179871
     249403616 4179871
     281744486 4179871
     285492135 4179871
     259612460 4179871
     280281798 4179871
     281027305 4179871
     249745169 4179871
     279481282 4179871
     249558792 4179871
     280550689 4179871
     280930422 4179871
     264900385 4179871
     281801959 4179871
     295204659 4179871
     249366668 4179871
     280635668 4179871
     280826149 4179871
     280707920 4179871
     296289257 4179871
     280628689 4179871
     280798645 4179871
     265020667 4179871
     281010473 4179871
     280399207 4179871
     280818350 4179871
     265196371 4179871
     284708861 4179871
     276599422 4179871
     265654923 4179871
     280200926 4179871
     280683289 4179871
     280548637 4179871
     265082656 4179871
     265079372 4179871
     296660368 4179871
     280318335 4179871
     275537814 4179871
     240093812 4179871
     295289638 4179871
     273263115 4179871
     241353702 4179871
     219850595 4179871
     280389355 4179871
     264014480 4179871
     264976742 4179871
     265142182 4179871
     280684930 4179871
     265095383 4179871
     280634026 4179871
     280676720 4179871
     280716129 4179871
     254174284 4179871
     280686983 4179871
     280695194 4179871
     251202930 4179871
     263458634 4179871
     280714898 4179871
     280725161 4179871
     249986966 4179871
     249010336 4179871
     280765803 4179871
     281775275 4179871
     279601975 4179871
     269193207 4179871
     277502568 4179871
     279871687 4179871
     280661531 4179871
     280837644 4179871
     280670152 4179871
     265409431 4179871
     264823207 4179871
     280644289 4179871
     265200066 4179871
     280679593 4179871
     265150803 4179871
     280697657 4179871
     280607342 4179871
     250943070 4179871
     233767678 4179871
     234607606 4179871
     280166853 4179871
     235187262 4179871
     238433664 4179871
     257946975 4179871
     280809729 4179871
     264827722 4179871
     266274810 4179871
     263992722 4179871
     280578194 4179871
     265100719 4179871
     280835181 4179871
     265010815 4179871
     265407379 4179871
     249258291 4179871
     249803873 4179871
     264891764 4179871
     251037490 4179871
     201098801 4179871
     206625239 4179871
     214384914 4179871
     327519667 4179871
     608587203 4179871
     625049519 4179871
     638007625 4179871
     617796428 4179871
     591941795 4179871
     591848196 4179871
     662973069 4179871
     330027953 4179871
     278274349 4179871
     267088053 4179871
     278089615 4179871
     280664404 4179871
     249633918 4179871
     265052278 4179871
     249460267 4179871
     280840517 4179871
     280636900 4179871
     249647464 4179871
     265066646 4179871
     265084709 4179871
     249509529 4179871
     265198013 4179871
     265083888 4179871
     265156140 4179871
     264992341 4179871
     265145877 4179871
     280996515 4179871
     249334237 4179871
     256365646 4179871
     273853444 4179871
     280832718 4179871
     265093330 4179871
     265329380 4179871
     280418912 4179871
     280604878 4179871
     280714898 4179871
     265378232 4179871
     280848317 4179871
     280537143 4179871
     265093330 4179871
     280810549 4179871
     264802270 4179871
     327742991 4179871
     249362974 4179871
     281119262 4179871
     280273177 4179871
     265054741 4179871
     266457082 4179871
     279429556 4179871
     280654141 4179871
     265334306 4179871
     280599131 4179871
     265061719 4179871
     265037499 4179871
     249567824 4179871
     280642236 4179871
     265114677 4179871
     265305159 4179871
     249350658 4179871
     280719825 4179871
     280763750 4179871
     280667688 4179871
     265124940 4179871
     265092098 4179871
     280834360 4179871
     266060519 4179871
     265275191 4179871
     263937302 4179871
     280702583 4179871
     265395885 4179871
     264912290 4179871
     280717772 4179871
     265165992 4179871
    MASSSIVE slowdown on the 4 core test without hyperthreading :D
  11. Zefiris
    Zefiris n00b
    16
    Mar 14, 2013
    intel i7-2630qm 4c8t processor
    pack8C:
    Code:
     83357152 4179871
     12554657 4179871
     10158260 4179871
     10435359 4179871
     10550817 4179871
     9910409 4179871
     10427662 4179871
     10833561 4179871
     10503095 4179871
     9994052 4179871
     10080261 4179871
     9961725 4179871
     10133628 4179871
     9937607 4179871
     10072564 4179871
     9920673 4179871
     10082827 4179871
     9901686 4179871
     10067946 4179871
     9991487 4179871
     10083853 4179871
     9913488 4179871
     13893971 4179871
     9931449 4179871
     10085906 4179871
     10192128 4179871
     10063327 4179871
     9920672 4179871
     9994566 4179871
     9929909 4179871
     9905278 4179871
     9920672 4179871
     9958646 4179871
     9914515 4179871
     9950948 4179871
     9933501 4179871
     9987895 4179871
     9917080 4179871
     9960184 4179871
     9906304 4179871
     9928370 4179871
     9913488 4179871
     9982764 4179871
     9910923 4179871
     10001750 4179871
     9937093 4179871
     9985842 4179871
     12358121 4179871
     10002777 4179871
     10173654 4179871
     10042289 4179871
     10100274 4179871
     9914515 4179871
     10072051 4179871
     9914515 4179871
     10190075 4179871
     13428546 4179871
     10201877 4179871
     9920160 4179871
     10062814 4179871
     9918107 4179871
     10170062 4179871
     10472819 4179871
     10106945 4179871
     10447161 4179871
     10815088 4179871
     10269612 4179871
     10246521 4179871
     9953000 4179871
     9984303 4179871
     9903225 4179871
     9895015 4179871
     9929396 4179871
     11849593 4179871
     10077695 4179871
     13897050 4179871
     10080262 4179871
     9942224 4179871
     44510378 4179871
     10784812 4179871
     11467811 4179871
     30688761 4179871
     15482160 4179871
     13184801 4179871
     10613935 4179871
     12169283 4179871
     10574935 4179871
     15766957 4179871
     13560938 4179871
     10259349 4179871
     10524133 4179871
     10271152 4179871
     10555948 4179871
     12652667 4179871
     10550817 4179871
     10534396 4179871
     10370189 4179871
     10576474 4179871
     10249599 4179871
     10524647 4179871
     10556462 4179871
     10259350 4179871
     10566211 4179871
     10549278 4179871
     10252679 4179871
     10555435 4179871
     10270126 4179871
     10541581 4179871
     10537476 4179871
     10138247 4179871
     10295783 4179871
     18146934 4179871
     10552870 4179871
     10281415 4179871
     10755563 4179871
     11728490 4179871
     10566725 4179871
     10534909 4179871
     10269099 4179871
     10545686 4179871
     10260889 4179871
     10527726 4179871
     10524647 4179871
     10282441 4179871
     10535936 4179871
     10524133 4179871
     10218811 4179871
     10528752 4179871
     10388150 4179871
     10536449 4179871
     10527212 4179871
     10251653 4179871
     10292704 4179871
     11656136 4179871
     10534396 4179871
     10267560 4179871
     10532857 4179871
     10533884 4179871
     10275771 4179871
     10782247 4179871
     10624197 4179871
     10277310 4179871
     10527726 4179871
     10256784 4179871
     10552870 4179871
     10521055 4179871
     10305020 4179871
     14709362 4179871
     10278336 4179871
     10398412 4179871
     10527726 4179871
     10540042 4179871
     10536962 4179871
     10261916 4179871
     10539015 4179871
     10520028 4179871
     10372755 4179871
     10704761 4179871
     10301428 4179871
     61004978 4179871
     10300915 4179871
     11963511 4179871
     10588790 4179871
     18452770 4179871
     10554922 4179871
     10317336 4179871
     12914373 4179871
     10253705 4179871
     10522594 4179871
     10723748 4179871
     10302455 4179871
     10611881 4179871
     10546199 4179871
     10289625 4179871
     10572882 4179871
     14457406 4179871
     10579041 4179871
     10508226 4179871
     10514896 4179871
     10583145 4179871
     10305019 4179871
     10545686 4179871
     10667301 4179871
     10555436 4179871
     10597514 4179871
     11548889 4179871
     10581606 4179871
     10266021 4179871
     10638053 4179871
     12885636 4179871
     10610342 4179871
     10564672 4179871
     10234719 4179871
     10523621 4179871
     10682182 4179871
     10384557 4179871
     12028681 4179871
     10522594 4179871
     10549278 4179871
     10270126 4179871
     10514897 4179871
     10612908 4179871
     10295783 4179871
     10524134 4179871
     10245494 4179871
     10532344 4179871
     10521568 4179871
     10258837 4179871
     10594948 4179871
     10512332 4179871
     10798667 4179871
     10526700 4179871
     10131063 4179871
     10235231 4179871
     11649978 4179871
     10716050 4179871
     10564159 4179871
     21417219 4179871
     10281415 4179871
     10533883 4179871
     10579040 4179871
     10264995 4179871
     10530292 4179871
     10576475 4179871
     10244469 4179871
     10493858 4179871
     10520541 4179871
     10626763 4179871
     10086933 4179871
     11577112 4179871
     10629842 4179871
     10256270 4179871
     11919381 4179871
     10296809 4179871
     10571856 4179871
     12427909 4179871
     10269613 4179871
     10539015 4179871
     10522081 4179871
     10233692 4179871
     10084880 4179871
     10309125 4179871
     11466272 4179871
     10325033 4179871
     10553383 4179871
     10561593 4179871
     10541067 4179871
     10523107 4179871
     10359926 4179871
     13104237 4179871
     10874613 4179871
     10287060 4179871
     10377886 4179871
     11716687 4179871
     10605724 4179871
     10397899 4179871
     10560567 4179871
     10684749 4179871
     10803799 4179871
     10652933 4179871
     10543120 4179871
     10823812 4179871
     10552357 4179871
     10296810 4179871
     10533370 4179871
     10521054 4179871
     10219837 4179871
     10227021 4179871
     11556073 4179871
     10431767 4179871
     10263455 4179871
     12324767 4179871
     10538502 4179871
     10242416 4179871
     10552870 4179871
     10521567 4179871
     10261402 4179871
     10546199 4179871
     10241390 4179871
     10623684 4179871
     10514384 4179871
     10851008 4179871
     11791094 4179871
     10242929 4179871
     13039581 4179871
     10325546 4179871
     10483595 4179871
     10493345 4179871
     10307585 4179871
     10538502 4179871
     10613934 4179871
     10331191 4179871
     10537475 4179871
     10160826 4179871
     10271152 4179871
     13086790 4179871
     10531317 4179871
     10535422 4179871
     10253192 4179871
     10578528 4179871
     10265507 4179871
     10468713 4179871
     10786352 4179871
     10312204 4179871
     10681156 4179871
     10498990 4179871
     10277823 4179871
     10521568 4179871
     10163904 4179871
     10255244 4179871
     11677688 4179871
     10538501 4179871
     10505660 4179871
     10254731 4179871
     10533883 4179871
     10318875 4179871
     10575962 4179871
     10749919 4179871
     10344532 4179871
     10554410 4179871
     10506687 4179871
     10347098 4179871
     10643697 4179871
     10239337 4179871
     10533370 4179871
     10523107 4179871
     10077182 4179871
     10234719 4179871
     11552994 4179871
     10532857 4179871
     10256270 4179871
     10510791 4179871
     10529778 4179871
     12347858 4179871
     10507713 4179871
     10574422 4179871
     10256271 4179871
     10497963 4179871
     10263455 4179871
     10510792 4179871
     10666275 4179871
     11670505 4179871
     10625737 4179871
     10321441 4179871
     10712459 4179871
     10235232 4179871
     10639592 4179871
     10618040 4179871
     10464095 4179871
     10629842 4179871
     10560567 4179871
     32027562 4179871
     31153673 4179871
     10854088 4179871
     11044978 4179871
     10157234 4179871
     10562107 4179871
     10240876 4179871
     10242929 4179871
     10277823 4179871
     10275770 4179871
     10147997 4179871
     10837153 4179871
     10356335 4179871
     10185457 4179871
     10282442 4179871
     10617527 4179871
     10183403 4179871
     10156721 4179871
     25300204 4179871
     10666275 4179871
     10223430 4179871
     10539528 4179871
     10224456 4179871
     10290652 4179871
     10305020 4179871
     10215219 4179871
     10347098 4179871
     10297836 4179871
     10804825 4179871
     10862810 4179871
     10239850 4179871
     10574422 4179871
     10544659 4179871
     10463069 4179871
     10492319 4179871
     10614447 4179871
     10960309 4179871
     10297322 4179871
     10519515 4179871
     10616500 4179871
     10455885 4179871
     10384044 4179871
     10414321 4179871
     10259350 4179871
     10637539 4179871
     10292192 4179871
     10272178 4179871
     10319388 4179871
     12668576 4179871
     10349150 4179871
     10520029 4179871
     11198408 4179871
     10350690 4179871
     10193154 4179871
     10275257 4179871
     10436899 4179871
     10141326 4179871
     12916939 4179871
     10441517 4179871
     10304507 4179871
     10144918 4179871
     10578014 4179871
     10149536 4179871
     10638052 4179871
     10317336 4179871
     10445109 4179871
     10592896 4179871
     10474359 4179871
     10958256 4179871
     19840832 4179871
     10525673 4179871
     10381992 4179871
     11682819 4179871
     10443056 4179871
     12690128 4179871
     10652934 4179871
     10392768 4179871
     10332216 4179871
     10188022 4179871
     10217785 4179871
     26226947 4179871
     10720156 4179871
     10875126 4179871
     10328624 4179871
     10306559 4179871
     11434456 4179871
     10589816 4179871
     10481029 4179871
     10588790 4179871
     10531831 4179871
     10367623 4179871
     10217271 4179871
     10600592 4179871
     10641132 4179871
     10372242 4179871
     10660631 4179871
     10534397 4179871
     10497963 4179871
     10511305 4179871
     10446135 4179871
     10809956 4179871
     10413294 4179871
     10492831 4179871
     10688340 4179871
     10921309 4179871
     10493345 4179871
     13322324 4179871
     10750432 4179871
     10211114 4179871
     10926441 4179871
     10518489 4179871
     10517975 4179871
     10204442 4179871
     10214706 4179871
     10568264 4179871
     10373782 4179871
     11055241 4179871
     10585198 4179871
     10338374 4179871
     10271152 4179871
     15715642 4179871
     10404057 4179871
     10308612 4179871
     10151588 4179871
     10489752 4179871
     11057806 4179871
     10435359 4179871
     10160312 4179871
     10180325 4179871
     10482055 4179871
     10143379 4179871
     10294757 4179871
     10483082 4179871
     10493858 4179871
     10211627 4179871
     10315283 4179871
     10276284 4179871
     10200338 4179871
     10142352 4179871
     10488727 4179871
     10158259 4179871
     10355821 4179871
     10155694 4179871
     10342480 4179871
     10337861 4179871
     10268586 4179871
     10142352 4179871
     10427148 4179871
     10308098 4179871
     10311691 4179871
     10146970 4179871
     10278850 4179871
     10660631 4179871
     10296297 4179871
     10863837 4179871
     10174681 4179871
     10445622 4179871
     10171088 4179871
     10259350 4179871
     10276797 4179871
     10190588 4179871
     10203417 4179871
     10703222 4179871
     10374294 4179871
     10384044 4179871
     10131063 4179871
     10519002 4179871
     12606484 4179871
     10393281 4179871
     10683722 4179871
     14300896 4179871
     12838427 4179871
     10147483 4179871
     10668328 4179871
     10191614 4179871
     10504634 4179871
     10952611 4179871
     11136831 4179871
     10456398 4179871
     10407136 4179871
     10666276 4179871
     10440491 4179871
     10596487 4179871
     10456398 4179871
     10707840 4179871
     10603672 4179871
     10447161 4179871
     10688341 4179871
     10627276 4179871
     10272179 4179871
     10972111 4179871
     19439551 4179871
     11790068 4179871
     28208208 4179871
     25987307 4179871
     10466661 4179871
     10804312 4179871
     10288599 4179871
     10613421 4179871
     10688341 4179871
     10358900 4179871
     10495397 4179871
     10203417 4179871
     11217396 4179871
     10248574 4179871
     10602645 4179871
     10481542 4179871
     10304507 4179871
     10839206 4179871
     10413294 4179871
     10790457 4179871
     10469740 4179871
     10368650 4179871
     10551331 4179871
     10509766 4179871
     10460504 4179871
     10614961 4179871
     10620092 4179871
     10344019 4179871
     13305904 4179871
     10552357 4179871
     10331703 4179871
     10462556 4179871
     10630355 4179871
     10305019 4179871
     10476410 4179871
     10610343 4179871
     10490779 4179871
     10340940 4179871
     10412780 4179871
     10525673 4179871
     10337861 4179871
     10685775 4179871
     10330164 4179871
     10583659 4179871
     10920796 4179871
     10279876 4179871
     10468714 4179871
     10701169 4179871
     10390202 4179871
     10291164 4179871
     10585198 4179871
     10484108 4179871
     10380453 4179871
     10442030 4179871
     10492832 4179871
     10436899 4179871
     10374807 4179871
     10381992 4179871
    pack4C
    Code:
     19182977 4179871
     20153851 4179871
     11355431 4179871
     22225939 4179871
     20285217 4179871
     10973138 4179871
     11702320 4179871
     10746326 4179871
     10854601 4179871
     11491415 4179871
     11042412 4179871
     11214830 4179871
     16447903 4179871
     12708088 4179871
     19873673 4179871
     17512683 4179871
     12010208 4179871
     14600574 4179871
     10579040 4179871
     10126958 4179871
     9968396 4179871
     22079693 4179871
     19898304 4179871
     22632865 4179871
     11236382 4179871
     22806309 4179871
     25902639 4179871
     25471595 4179871
     17550657 4179871
     19089072 4179871
     10066406 4179871
     23578595 4179871
     26620018 4179871
     11312841 4179871
     10608290 4179871
     18563096 4179871
     11113740 4179871
     10757616 4179871
     12384805 4179871
     11656136 4179871
     10459990 4179871
     17304346 4179871
     21089832 4179871
     23388218 4179871
     14639060 4179871
     12084614 4179871
     20575145 4179871
     10548764 4179871
     19361552 4179871
     23173722 4179871
     18521531 4179871
     10674486 4179871
     11765436 4179871
     10413294 4179871
     16782475 4179871
     10659091 4179871
     14343487 4179871
     24156912 4179871
     18389652 4179871
     20265718 4179871
     22395791 4179871
     21849803 4179871
     24234911 4179871
     16497679 4179871
     16479206 4179871
     24799885 4179871
     25113419 4179871
     24485326 4179871
     22872505 4179871
     10726313 4179871
     20115365 4179871
     10314256 4179871
     10141326 4179871
     10244981 4179871
     10135168 4179871
     24125097 4179871
     10422017 4179871
     24038888 4179871
     10272692 4179871
     10260376 4179871
     14020718 4179871
     21610163 4179871
     14665231 4179871
     23274813 4179871
     17126284 4179871
     15815193 4179871
     10123879 4179871
     13612253 4179871
     23271220 4179871
     19985540 4179871
     11393405 4179871
     10608289 4179871
     10438952 4179871
     9979171 4179871
     9920673 4179871
     9801623 4179871
     9994053 4179871
     14478445 4179871
     9959158 4179871
     11318998 4179871
     9995079 4179871
     10145431 4179871
     14411223 4179871
     10300402 4179871
     11401615 4179871
     10292704 4179871
     10834074 4179871
     18128461 4179871
     9957106 4179871
     10083854 4179871
     9953514 4179871
     9896042 4179871
     12107193 4179871
     11015216 4179871
     10426122 4179871
     12254978 4179871
     10352230 4179871
     10534909 4179871
     23537030 4179871
     14271647 4179871
     10931572 4179871
     21906249 4179871
     10388663 4179871
     10398412 4179871
     14840727 4179871
     10048446 4179871
     10575961 4179871
     10297323 4179871
     10568777 4179871
     11144528 4179871
     13289483 4179871
     10589303 4179871
     11511428 4179871
     22313687 4179871
     14170557 4179871
     17216598 4179871
     17205309 4179871
     10139786 4179871
     10016118 4179871
     10736576 4179871
     25970374 4179871
     15643289 4179871
     21162699 4179871
     19819280 4179871
     10443056 4179871
     10212654 4179871
     16242132 4179871
     20933835 4179871
     22913043 4179871
     21730240 4179871
     11102450 4179871
     11048057 4179871
     16297039 4179871
     15126037 4179871
     10207009 4179871
     22763205 4179871
     22103810 4179871
     21529086 4179871
     10214706 4179871
     10689880 4179871
     10185969 4179871
     10675512 4179871
     20368348 4179871
     16689082 4179871
     10768391 4179871
     11022399 4179871
     10388149 4179871
     15706406 4179871
     11057293 4179871
     9999698 4179871
     21882131 4179871
     21775397 4179871
     19529352 4179871
     19562706 4179871
     21224790 4179871
     11840356 4179871
     22974621 4179871
     13970942 4179871
     19151676 4179871
     19108057 4179871
     15088577 4179871
     18462006 4179871
     13807248 4179871
     11089109 4179871
     10355822 4179871
     15574014 4179871
     22843256 4179871
     9939146 4179871
     10459477 4179871
     10317335 4179871
     26425022 4179871
     11226632 4179871
     10432793 4179871
     10328111 4179871
     21724594 4179871
     13703079 4179871
     20374505 4179871
     24695203 4179871
     23452361 4179871
     10687314 4179871
     10725800 4179871
     10378913 4179871
     10746840 4179871
     10052552 4179871
     14628797 4179871
     21713819 4179871
     23854668 4179871
     15670486 4179871
     10929007 4179871
     9998671 4179871
     10705275 4179871
     17555275 4179871
     18208511 4179871
     9954027 4179871
     17488053 4179871
     10773010 4179871
     10485648 4179871
     10572882 4179871
     22961280 4179871
     16540270 4179871
     11692569 4179871
     21113436 4179871
     22022220 4179871
     10693472 4179871
     10866402 4179871
     10535423 4179871
     24284685 4179871
     11964537 4179871
     10172628 4179871
     11016241 4179871
     12756837 4179871
     11079872 4179871
     10053065 4179871
     23387191 4179871
     21818501 4179871
     26663635 4179871
     25088787 4179871
     13442401 4179871
     12162099 4179871
     12192888 4179871
     11056267 4179871
     10220864 4179871
     10915152 4179871
     10661144 4179871
     10736576 4179871
     10359413 4179871
     10806364 4179871
     11077819 4179871
     10440490 4179871
     15957848 4179871
     15097813 4179871
     18275220 4179871
     13227392 4179871
     9898607 4179871
     10259863 4179871
     14761189 4179871
     21908302 4179871
     11971722 4179871
     17735390 4179871
     12261650 4179871
     10550304 4179871
     10202390 4179871
     10568778 4179871
     10165444 4179871
     19721269 4179871
     21321775 4179871
     10751971 4179871
     10377886 4179871
     21356155 4179871
     10375834 4179871
     10690906 4179871
     10430741 4179871
     10439464 4179871
     10437412 4179871
     11010084 4179871
     10081288 4179871
     10915152 4179871
     10253192 4179871
     10931572 4179871
     10474358 4179871
     18893049 4179871
     16681899 4179871
     9726703 4179871
     10257297 4179871
     9758519 4179871
     10063840 4179871
     9973013 4179871
     10026894 4179871
     9774425 4179871
     10313743 4179871
     9714388 4179871
     18638016 4179871
     27740732 4179871
     10335809 4179871
     11115792 4179871
     20786049 4179871
     19914212 4179871
     10489240 4179871
     19162964 4179871
     18211590 4179871
     15860350 4179871
     10784300 4179871
     18175156 4179871
     21643005 4179871
     20659815 4179871
     10987506 4179871
     11626373 4179871
     10726313 4179871
     10084880 4179871
     10214706 4179871
     24704440 4179871
     16747581 4179871
     16143607 4179871
     25413609 4179871
     21543967 4179871
     13614306 4179871
     15282033 4179871
     10760695 4179871
     10310665 4179871
     10879744 4179871
     10262941 4179871
     10722721 4179871
     10079749 4179871
     10939270 4179871
     10058196 4179871
     14082808 4179871
     10430227 4179871
     10154668 4179871
     10553896 4179871
     17908833 4179871
     9961211 4179871
     10324006 4179871
     15143996 4179871
     18788367 4179871
     21519849 4179871
     18445072 4179871
     22021707 4179871
     19868542 4179871
     10766852 4179871
     10476924 4179871
     10699630 4179871
     15428280 4179871
     19643783 4179871
     15388255 4179871
     19661744 4179871
     10546199 4179871
     10690393 4179871
     10349663 4179871
     11058833 4179871
     10351716 4179871
     11314380 4179871
     16748095 4179871
     16344248 4179871
     21467509 4179871
     10419965 4179871
     10558001 4179871
     11077819 4179871
     22412212 4179871
     21971932 4179871
     19937304 4179871
     10530291 4179871
     18728329 4179871
     10997255 4179871
     10667814 4179871
     10320927 4179871
     9896555 4179871
     12875373 4179871
     13938614 4179871
     9787767 4179871
     14694480 4179871
     13488071 4179871
     10972111 4179871
     10410729 4179871
     11062425 4179871
     26031438 4179871
     10807904 4179871
     10098222 4179871
     10840745 4179871
     10181864 4179871
     10915152 4179871
     10371729 4179871
     10762234 4179871
     20699840 4179871
     14748360 4179871
     15633026 4179871
     10799693 4179871
     10367111 4179871
     10726826 4179871
     17624550 4179871
     19472392 4179871
     10157747 4179871
     18886891 4179871
     10656526 4179871
     10768392 4179871
     9783149 4179871
     10321954 4179871
     9782123 4179871
     10253192 4179871
     24310343 4179871
     10274231 4179871
     9817017 4179871
     10189562 4179871
     9800596 4179871
     10178273 4179871
     19055204 4179871
     23087000 4179871
     23243510 4179871
     20932809 4179871
     9884239 4179871
     9994566 4179871
     10107971 4179871
     10025354 4179871
     13208919 4179871
     12321688 4179871
     14516418 4179871
     20696249 4179871
     10495397 4179871
     12146191 4179871
     28269273 4179871
     10534397 4179871
     10164417 4179871
     10164417 4179871
     9989947 4179871
     14717572 4179871
     19712032 4179871
     18299851 4179871
     16795304 4179871
     23620673 4179871
     10048960 4179871
     16260092 4179871
     11128621 4179871
     21125239 4179871
     10046394 4179871
     10590330 4179871
     10244468 4179871
     16581322 4179871
     22146402 4179871
     18916141 4179871
     12900518 4179871
     10316823 4179871
     17110377 4179871
     14710901 4179871
     18012489 4179871
     15655605 4179871
     17629681 4179871
     24030678 4179871
     19390802 4179871
     21625045 4179871
     10152102 4179871
     19408249 4179871
     16019426 4179871
     11262039 4179871
     11238948 4179871
     10463582 4179871
     10376347 4179871
     14844319 4179871
     22355765 4179871
     18474321 4179871
     13728224 4179871
     16052781 4179871
     21305867 4179871
     10628302 4179871
     10042289 4179871
     16736806 4179871
     21650189 4179871
     10203930 4179871
     19383105 4179871
     10769418 4179871
     21906763 4179871
     22936649 4179871
     15725392 4179871
     25689682 4179871
     12370950 4179871
     22452238 4179871
     14737584 4179871
     17530131 4179871
     10169549 4179871
     10509765 4179871
     10493858 4179871
     21652754 4179871
     11755173 4179871
     21620426 4179871
     26202316 4179871
     16751174 4179871
     22894057 4179871
     11317972 4179871
     12715785 4179871
     10641644 4179871
     10233180 4179871
     10583146 4179871
     12034838 4179871
     25539331 4179871
     10807391 4179871
     17803638 4179871
     18869958 4179871
     19853147 4179871
     23972693 4179871
     13264339 4179871
     23916246 4179871
     10702708 4179871
     10688340 4179871
     10829456 4179871
     15170680 4179871
     17414673 4179871
     21103687 4179871
     11080898 4179871
     10697577 4179871
     14389671 4179871
     15771575 4179871
     11100911 4179871
     19809017 4179871
     9915028 4179871
     12430989 4179871
     16503324 4179871
     24917909 4179871
     22977700 4179871
     16586453 4179871
     14302949 4179871
     17930385 4179871
     13539899 4179871
     10443057 4179871
     25354598 4179871
     17567077 4179871
     25911876 4179871
     10735037 4179871
     20955901 4179871
     22784244 4179871
     19139873 4179871
     19966040 4179871
     15220969 4179871
     10982887 4179871
     10471793 4179871
     25409504 4179871
     23886997 4179871
     10492318 4179871
     21952432 4179871
     10421504 4179871
     21737937 4179871
     13991982 4179871
     18269063 4179871
     22032997 4179871
     10021763 4179871
     10499502 4179871
     10938756 4179871
     10512844 4179871
     23242484 4179871
     16348866 4179871
     10322466 4179871
     18157197 4179871
     20879441 4179871
     13297180 4179871
     10734524 4179871
     10154154 4179871
     12583393 4179871
     20587461 4179871
     10691419 4179871
     10163905 4179871
     10454859 4179871
     10393281 4179871
     21090345 4179871
     10174168 4179871
     10930033 4179871
     10065381 4179871
     12216493 4179871
     10541581 4179871
     20598237 4179871
     21817474 4179871
     11361589 4179871
     21354616 4179871
     19961422 4179871
     19990157 4179871
     11198922 4179871
     19432880 4179871
     10057170 4179871
     23138828 4179871
     10169549 4179871
     20076366 4179871
     10676538 4179871
     10322467 4179871
     13627647 4179871
     12751192 4179871
     18421467 4179871
     17158612 4179871
     16013781 4179871
     22129468 4179871
     9971988 4179871
     10567751 4179871
     13688199 4179871
     19996828 4179871
     22752429 4179871
     22086363 4179871
     20584382 4179871
     22394252 4179871
     23308167 4179871
     22533315 4179871
     10598540 4179871
     16267276 4179871
     19646349 4179871
     10232667 4179871
     18342956 4179871
    Unfortunately there isn't an option that allows me to turn off HT in BIOS. Anyhow, good luck with the experiment. :)
  12. Raghar
    Raghar Limp Gawd
    209
    Jun 23, 2012
    Re: defaultluser
    Man that's just mean.
    As expected from Intel.
    So, when you run it two cores HT, scheduler adds both threads on a single core, because why not, when you run 4 threaded version, it works as it should.
    When you disable HT, two threaded version works as it should, but a 4 threaded version is slower on your computer than on my Wolfdale. I have 127 - 192, you have 171 - 265. What's your CPU speed?
    I might want to add AMD Vishera for comparison, just to see scaling on AMD CPUs.
  13. defaultluser
    defaultluser [H]ardForum Junkie
    12,460
    Jan 14, 2006
    2.5 GHz Sandy, no turbo.
  14. Fort_Major
    Fort_Major Limp Gawd
    425
    Apr 22, 2006
    I hope you realize that statistics requires a far larger population than 5 before drawing any sort of conclusion.
  15. WolfpupNX
    WolfpupNX Limp Gawd
    167
    Mar 13, 2007
    Thanks for the help in my other thread - as requested, benchies run:
    Intel 3960X @ Stock (3.3 GHz w/ Turbo to 3.9)
    Pack (HyperThreading OFF)
    Code:
     23473733 4179871
     24375160 4179871
     28787967 4179871
     11951906 4179871
     11931116 4179871
     11918393 4179871
     11934219 4179871
     11941666 4179871
     11931426 4179871
     11918083 4179871
     11910015 4179871
     11903809 4179871
     11932047 4179871
     11916221 4179871
     11909084 4179871
     11905671 4179871
     11905361 4179871
     11924599 4179871
     11910015 4179871
     11913739 4179871
     11923048 4179871
     11910325 4179871
     11910015 4179871
     11912807 4179871
     11946320 4179871
     11920875 4179871
     11919634 4179871
     11899775 4179871
     11900085 4179871
     11901326 4179871
     11901947 4179871
     11918394 4179871
     11967421 4179871
     12350023 4179871
     12039722 4179871
     11906601 4179871
     11896362 4179871
     11930184 4179871
     11897603 4179871
     11905360 4179871
     11897913 4179871
     11895121 4179871
     11899155 4179871
     11924289 4179871
     11902568 4179871
     11935460 4179871
     11918082 4179871
     11918704 4179871
     11920255 4179871
     12325199 4179871
     11981695 4179871
     11916532 4179871
     11927082 4179871
     11914669 4179871
     11911877 4179871
     11921185 4179871
     11912808 4179871
     11918393 4179871
     12394707 4179871
     12383226 4179871
     12626813 4179871
     12064545 4179871
     12049651 4179871
     12077578 4179871
     11969593 4179871
     12387880 4179871
     11910946 4179871
     11915290 4179871
     11946940 4179871
     11908773 4179871
     11916220 4179871
     11942286 4179871
     12424186 4179871
     11975488 4179871
     11965249 4179871
     11915911 4179871
     11906292 4179871
     11913428 4179871
     11914669 4179871
     11906601 4179871
     11900085 4179871
     11902258 4179871
     11912807 4179871
     11912498 4179871
     11900395 4179871
     11900706 4179871
     11933908 4179871
     11898844 4179871
     11904119 4179871
     11902568 4179871
     11922737 4179871
     11898844 4179871
     12396879 4179871
     11943217 4179871
     11927082 4179871
     11911877 4179871
     11919635 4179871
     11914049 4179871
     11916532 4179871
     11934529 4179871
     11936701 4179871
     11963076 4179871
     11915290 4179871
     11928323 4179871
     11901016 4179871
     11905981 4179871
     11905050 4179871
     11928322 4179871
     11911566 4179871
     11905361 4179871
     11957181 4179871
     11986039 4179871
     11915290 4179871
     11901637 4179871
     11906912 4179871
     11903499 4179871
     11921186 4179871
     11907532 4179871
     11912807 4179871
     11911567 4179871
     11926771 4179871
     11900395 4179871
     11949113 4179871
     11903809 4179871
     11912497 4179871
     11920875 4179871
     11903499 4179871
     11904740 4179871
     11903498 4179871
     11937011 4179871
     11907222 4179871
     11933598 4179871
     11918704 4179871
     11904120 4179871
     11914669 4179871
     11935770 4179871
     11932977 4179871
     11914980 4179871
     11937942 4179871
     11908464 4179871
     11904429 4179871
     11917152 4179871
     11905050 4179871
     11918703 4179871
     11914360 4179871
     11921806 4179871
     11902878 4179871
     11912498 4179871
     11908463 4179871
     11935770 4179871
     11922116 4179871
     11930495 4179871
     11898533 4179871
     11911877 4179871
     11920255 4179871
     11906912 4179871
     11938562 4179871
     11945079 4179871
     11906601 4179871
     11916531 4179871
     11920255 4179871
     11921807 4179871
     11907533 4179871
     11905671 4179871
     11930185 4179871
     11923047 4179871
     11936390 4179871
     11910946 4179871
     11934218 4179871
     11908153 4179871
     11906601 4179871
     11900706 4179871
     11901947 4179871
     11905360 4179871
     11918393 4179871
     11907532 4179871
     11933287 4179871
     11920565 4179871
     11897293 4179871
     11904740 4179871
     11924910 4179871
     11919945 4179871
     11923668 4179871
     11904430 4179871
     11908464 4179871
     11909395 4179871
     11898844 4179871
     11918393 4179871
     11904119 4179871
     11904739 4179871
     11961836 4179871
     12041272 4179871
     11908464 4179871
     11917463 4179871
     11934839 4179871
     11923979 4179871
     11920566 4179871
     11905050 4179871
     11904429 4179871
     11906912 4179871
     11902878 4179871
     11905671 4179871
     11928943 4179871
     11905670 4179871
     11906291 4179871
     11931426 4179871
     11939183 4179871
     11901947 4179871
     11914980 4179871
     11935770 4179871
     11939804 4179871
     11906911 4179871
     11928943 4179871
     11927392 4179871
     11914979 4179871
     11927392 4179871
     11912187 4179871
     11909704 4179871
     11905361 4179871
     11910325 4179871
     11941665 4179871
     11905670 4179871
     11904740 4179871
     11900706 4179871
     11916841 4179871
     11903809 4179871
     11904119 4179871
     11933908 4179871
     11901326 4179871
     11924289 4179871
     11934839 4179871
     11905050 4179871
     11906601 4179871
     11913429 4179871
     11918393 4179871
     11911876 4179871
     11905050 4179871
     11909084 4179871
     11901948 4179871
     11905670 4179871
     11904119 4179871
     11906602 4179871
     11922427 4179871
     11900706 4179871
     11926151 4179871
     11997831 4179871
     12370503 4179871
     12375158 4179871
     11951285 4179871
     12374537 4179871
     11909704 4179871
     11904430 4179871
     11896982 4179871
     11899465 4179871
     11898844 4179871
     11899775 4179871
     11897913 4179871
     11901947 4179871
     11913738 4179871
     11907843 4179871
     11908153 4179871
     11906911 4179871
     11901016 4179871
     11905050 4179871
     11897913 4179871
     11902257 4179871
     11896982 4179871
     11900086 4179871
     11902567 4179871
     11902257 4179871
     11902258 4179871
     11903188 4179871
     11902878 4179871
     11899775 4179871
     11932977 4179871
     11937321 4179871
     11902567 4179871
     11901636 4179871
     11905671 4179871
     11921186 4179871
     11920255 4179871
     11928012 4179871
     11905981 4179871
     11904429 4179871
     11905670 4179871
     11904430 4179871
     11931426 4179871
     11900396 4179871
     11901947 4179871
     11895431 4179871
     11905670 4179871
     11957181 4179871
     11910945 4179871
     11906912 4179871
     11906601 4179871
     11907843 4179871
     11898844 4179871
     11901947 4179871
     11957801 4179871
     11918703 4179871
     11917772 4179871
     11918083 4179871
     11917152 4179871
     11914979 4179871
     11914670 4179871
     11915600 4179871
     11914359 4179871
     11920876 4179871
     11907222 4179871
     11914359 4179871
     11917463 4179871
     11903809 4179871
     11911256 4179871
     11912497 4179871
     11922427 4179871
     11912808 4179871
     11937942 4179871
     11902878 4179871
     11905670 4179871
     11902878 4179871
     11913118 4179871
     11919945 4179871
     11915911 4179871
     11920875 4179871
     11915600 4179871
     11928633 4179871
     11902257 4179871
     11903499 4179871
     11907223 4179871
     11904430 4179871
     15902982 4179871
     11914359 4179871
     11914049 4179871
     11937632 4179871
     11910946 4179871
     11914670 4179871
     11912497 4179871
     11913118 4179871
     11916842 4179871
     11901016 4179871
     11921496 4179871
     11933908 4179871
     11907533 4179871
     11908773 4179871
     11901016 4179871
     11896983 4179871
     11896362 4179871
     11896982 4179871
     11901947 4179871
     11903189 4179871
     11901016 4179871
     11902878 4179871
     11904120 4179871
     11904119 4179871
     11920875 4179871
     11904119 4179871
     11907222 4179871
     11900085 4179871
     11927392 4179871
     11904740 4179871
     11926151 4179871
     11904120 4179871
     11897603 4179871
     11905360 4179871
     11901637 4179871
     11901016 4179871
     11930184 4179871
     11900085 4179871
     11900086 4179871
     11902877 4179871
     11897603 4179871
     11907843 4179871
     11923358 4179871
     11902257 4179871
     11897602 4179871
     11896362 4179871
     11897602 4179871
     11895121 4179871
     11899775 4179871
     11901637 4179871
     11911256 4179871
     11905670 4179871
     11908463 4179871
     11933288 4179871
     11904739 4179871
     11908464 4179871
     12565993 4179871
     11921806 4179871
     11939183 4179871
     11977661 4179871
     11918393 4179871
     11927082 4179871
     11905360 4179871
     11932046 4179871
     11926461 4179871
     11950354 4179871
     11941665 4179871
     11902568 4179871
     11898844 4179871
     11910325 4179871
     11902567 4179871
     11901637 4179871
     11914669 4179871
     11901016 4179871
     11928943 4179871
     11905981 4179871
     11934529 4179871
     11927081 4179871
     11930805 4179871
     11902257 4179871
     11905670 4179871
     11902258 4179871
     11907533 4179871
     11994417 4179871
     11929874 4179871
     11917773 4179871
     11925220 4179871
     11932357 4179871
     11909704 4179871
     11906602 4179871
     11905360 4179871
     11907223 4179871
     11936080 4179871
     11907222 4179871
     11905050 4179871
     11928012 4179871
     11907532 4179871
     11907222 4179871
     11909704 4179871
     11908153 4179871
     11913738 4179871
     11910636 4179871
     11905050 4179871
     11905671 4179871
     11909705 4179871
     11911256 4179871
     11900395 4179871
     11918393 4179871
     11920566 4179871
     11928323 4179871
     11943528 4179871
     11913738 4179871
     11946010 4179871
     11934219 4179871
     11905050 4179871
     11903499 4179871
     11903809 4179871
     11919324 4179871
     11918393 4179871
     11916221 4179871
     11912807 4179871
     11914669 4179871
     11913428 4179871
     11916842 4179871
     11899154 4179871
     11895431 4179871
     11900396 4179871
     11897602 4179871
     11902258 4179871
     11960905 4179871
     11901016 4179871
     11897293 4179871
     11904429 4179871
     11903188 4179871
     11931116 4179871
     11924910 4179871
     11899465 4179871
     11936391 4179871
     11909394 4179871
     11917152 4179871
     11900085 4179871
     11914359 4179871
     11927081 4179871
     11913118 4179871
     11907533 4179871
     11923978 4179871
     11895121 4179871
     11919324 4179871
     11895741 4179871
     11902567 4179871
     11917152 4179871
     11909395 4179871
     11932667 4179871
     11925530 4179871
     11903809 4179871
     11905050 4179871
     11916531 4179871
     11918082 4179871
     11910326 4179871
     11917152 4179871
     11901637 4179871
     11905980 4179871
     11903809 4179871
     11951595 4179871
     11912187 4179871
     11908774 4179871
     11912187 4179871
     12049341 4179871
     11925530 4179871
     11928943 4179871
     11930185 4179871
     11917772 4179871
     11928013 4179871
     11912187 4179871
     11940115 4179871
     11949113 4179871
     11904740 4179871
     11901016 4179871
     11901327 4179871
     12227454 4179871
     12153292 4179871
     11910946 4179871
     11902257 4179871
     11901016 4179871
     11903188 4179871
     11898223 4179871
     11907532 4179871
     11902567 4179871
     11905050 4179871
     11934219 4179871
     11900085 4179871
     11904119 4179871
     11901016 4179871
     11904119 4179871
     11901947 4179871
     11918083 4179871
     11939183 4179871
     11912187 4179871
     11912187 4179871
     11903499 4179871
     11904430 4179871
     11905360 4179871
     11901947 4179871
     11906601 4179871
     11919324 4179871
     11910635 4179871
     11907222 4179871
     11911256 4179871
     11924288 4179871
     11906291 4179871
     11901326 4179871
     11905981 4179871
     11904119 4179871
     11902568 4179871
     11906291 4179871
     11925840 4179871
     11896983 4179871
     11935149 4179871
     11897603 4179871
     11902878 4179871
     11911256 4179871
     11902257 4179871
     11919324 4179871
     11936390 4179871
     11922738 4179871
     11910636 4179871
     11933287 4179871
     11900706 4179871
     11914049 4179871
     11909394 4179871
     11908153 4179871
     11908153 4179871
     11909394 4179871
     11908774 4179871
     11901637 4179871
     11932356 4179871
     11905050 4179871
     11944458 4179871
     11912187 4179871
     11901947 4179871
     11899464 4179871
     11906292 4179871
     11928943 4179871
     11936701 4179871
     11905050 4179871
     11901637 4179871
     11917462 4179871
     11916221 4179871
     11907532 4179871
     11902257 4179871
     11938252 4179871
     11903498 4179871
     11908773 4179871
     11898844 4179871
     11955940 4179871
     11932046 4179871
     11914980 4179871
     11939183 4179871
     11930495 4179871
     11935460 4179871
     11908153 4179871
     11908774 4179871
     11905361 4179871
     11896672 4179871
     11948802 4179871
     11916842 4179871
     11905050 4179871
     11920255 4179871
     11928323 4179871
     11903188 4179871
    Pack6C (Hyperthreading OFF)
    Code:
     24913534 4179871
     41351477 4179871
     4026480 4179871
     4014688 4179871
     4009103 4179871
     4021515 4179871
     4016860 4179871
     4015309 4179871
     4015619 4179871
     4144085 4179871
     4017481 4179871
     4014688 4179871
     4013447 4179871
     4440423 4179871
     4011585 4179871
     4012827 4179871
     4044478 4179871
     4019964 4179871
     4010345 4179871
     4009103 4179871
     4112743 4179871
     4139430 4179871
     4018102 4179871
     4005689 4179871
     4035789 4179871
     4275342 4179871
     4020584 4179871
     4004449 4179871
     4009103 4179871
     4010034 4179871
     4009414 4179871
     4008482 4179871
     4051304 4179871
     4091954 4179871
     4014688 4179871
     4008793 4179871
     4336472 4179871
     4021205 4179871
     4018722 4179871
     4015930 4179871
     4150291 4179871
     4014068 4179871
     4014999 4179871
     4008792 4179871
     4710075 4179871
     4213281 4179871
     4008793 4179871
     4051925 4179871
     4024307 4179871
     4004759 4179871
     4010344 4179871
     4006621 4179871
     4045098 4179871
     4010345 4179871
     4012206 4179871
     4008482 4179871
     4021515 4179871
     4058131 4179871
     4010344 4179871
     4295512 4179871
     4011275 4179871
     4012517 4179871
     4003517 4179871
     4014998 4179871
     4021205 4179871
     4012206 4179871
     4006311 4179871
     4181011 4179871
     4019964 4179871
     4017481 4179871
     4013757 4179871
     4014378 4179871
     4064647 4179871
     4009724 4179871
     4420253 4179871
     4037962 4179871
     4014378 4179871
     4007552 4179871
     4002276 4179871
     4028652 4179871
     4008483 4179871
     4007241 4179871
     4010034 4179871
     4306062 4179871
     4011275 4179871
     4015620 4179871
     4009413 4179871
     4079541 4179871
     4008483 4179871
     4011275 4179871
     4009104 4179871
     4047270 4179871
     4012206 4179871
     4011896 4179871
     4010345 4179871
     4014689 4179871
     4005380 4179871
     4011276 4179871
     4009724 4179871
     4302028 4179871
     4014068 4179871
     4008172 4179871
     4015620 4179871
     4007862 4179871
     4010034 4179871
     4012516 4179871
     4005070 4179871
     4023067 4179871
     4006000 4179871
     4010034 4179871
     4007241 4179871
     4113054 4179871
     4007552 4179871
     4010344 4179871
     4009413 4179871
     4022136 4179871
     4012516 4179871
     4011585 4179871
     4012206 4179871
     4009414 4179871
     4005069 4179871
     4004138 4179871
     4006310 4179871
     4194353 4179871
     4008483 4179871
     4010344 4179871
     4014999 4179871
     4010345 4179871
     4012827 4179871
     4009103 4179871
     4025239 4179871
     4010344 4179871
     4008483 4179871
     4010034 4179871
     4007862 4179871
     4009103 4179871
     4008172 4179871
     4006310 4179871
     4018412 4179871
     4012517 4179871
     4004758 4179871
     4010034 4179871
     4013758 4179871
     4008172 4179871
     4006931 4179871
     4007862 4179871
     4111813 4179871
     4011275 4179871
     4011896 4179871
     4006931 4179871
     4116468 4179871
     4011585 4179871
     4006310 4179871
     4013447 4179871
     4018722 4179871
     4007551 4179871
     4014068 4179871
     4007241 4179871
     4012517 4179871
     4008793 4179871
     4005689 4179871
     4008482 4179871
     4052545 4179871
     4005380 4179871
     4009413 4179871
     4011275 4179871
     4013758 4179871
     4009413 4179871
     4006310 4179871
     4004138 4179871
     4115226 4179871
     4014999 4179871
     4008172 4179871
     4009413 4179871
     4015309 4179871
     4006000 4179871
     4007862 4179871
     4012206 4179871
     4077060 4179871
     4011585 4179871
     4020274 4179871
     4016550 4179871
     4019033 4179871
     4026790 4179871
     4009413 4179871
     4007241 4179871
     4087609 4179871
     4012826 4179871
     4006000 4179871
     4007551 4179871
     4020274 4179871
     4010654 4179871
     4006310 4179871
     4008173 4179871
     4530721 4179871
     4012826 4179871
     4008172 4179871
     4015930 4179871
     4008483 4179871
     4007241 4179871
     4008172 4179871
     4008482 4179871
     4030824 4179871
     4015619 4179871
     4011276 4179871
     4011896 4179871
     4009103 4179871
     4009413 4179871
     4007551 4179871
     4038582 4179871
     5679459 4179871
     35900401 4179871
     4017171 4179871
     4024307 4179871
     4015929 4179871
     4009413 4179871
     4014378 4179871
     4895325 4179871
     4397291 4179871
     4015930 4179871
     4008793 4179871
     4007552 4179871
     4014068 4179871
     4010344 4179871
     4043547 4179871
     7367502 4179871
     4009103 4179871
     4011275 4179871
     4010034 4179871
     4007552 4179871
     4010655 4179871
     4008793 4179871
     4006310 4179871
     11798616 4179871
     5023170 4179871
     4041064 4179871
     4010655 4179871
     4013447 4179871
     4008173 4179871
     4136016 4179871
     4018412 4179871
     4452524 4179871
     4013757 4179871
     4010345 4179871
     4009723 4179871
     4017481 4179871
     4020894 4179871
     4160530 4179871
     4266653 4179871
     4017792 4179871
     4018101 4179871
     4010034 4179871
     4011275 4179871
     4009724 4179871
     4007552 4179871
     17528035 4179871
     4012826 4179871
     4016860 4179871
     4013447 4179871
     11802960 4179871
     4027101 4179871
     4026480 4179871
     4008172 4179871
     4009414 4179871
     4008172 4179871
     4011586 4179871
     4132914 4179871
     4117398 4179871
     4021205 4179871
     4103745 4179871
     4021204 4179871
     4030514 4179871
     4019343 4179871
     4012826 4179871
     4420253 4179871
     4019963 4179871
     4163013 4179871
     4008483 4179871
     4004759 4179871
     4010344 4179871
     4007241 4179871
     4012517 4179871
     4069612 4179871
     4843815 4179871
     4020895 4179871
     4531652 4179871
     4010964 4179871
     4011895 4179871
     4013447 4179871
     4007552 4179871
     4341126 4179871
     4067751 4179871
     8468765 4179871
     4009723 4179871
     4012206 4179871
     4015309 4179871
     4007551 4179871
     4020274 4179871
     4013137 4179871
     4420564 4179871
     4021825 4179871
     4008172 4179871
     4054408 4179871
     4009724 4179871
     4008172 4179871
     4108400 4179871
     4011586 4179871
     4436078 4179871
     4049132 4179871
     4114296 4179871
     4013757 4179871
     4010654 4179871
     4014688 4179871
     4010344 4179871
     4392636 4179871
     4024928 4179871
     4019033 4179871
     4017171 4179871
     33417673 4179871
     4007241 4179871
     4014068 4179871
     4111813 4179871
     4421495 4179871
     11054202 4179871
     4006310 4179871
     4030825 4179871
     4104056 4179871
     4008482 4179871
     4422735 4179871
     4018722 4179871
     4046339 4179871
     4007551 4179871
     4013137 4179871
     4124225 4179871
     4011276 4179871
     4010654 4179871
     4416840 4179871
     4124535 4179871
     4012517 4179871
     4008482 4179871
     4098159 4179871
     4012826 4179871
     4009103 4179871
     4011275 4179871
     4035789 4179871
     4068061 4179871
     4121743 4179871
     4114296 4179871
     4012827 4179871
     4008793 4179871
     4501553 4179871
     4013136 4179871
     4079852 4179871
     4074888 4179871
     4012517 4179871
     4104366 4179871
     4012206 4179871
     4005690 4179871
     4049752 4179871
     4017791 4179871
     4111192 4179871
     4028031 4179871
     4482934 4179871
     4010655 4179871
     4011896 4179871
     4009103 4179871
     4010965 4179871
     4008172 4179871
     4019343 4179871
     4080783 4179871
     4009413 4179871
     4416530 4179871
     4007241 4179871
     4011275 4179871
     4008172 4179871
     4008482 4179871
     4108089 4179871
     4024618 4179871
     4010345 4179871
     4406911 4179871
     4009413 4179871
     4105296 4179871
     4108399 4179871
     4097229 4179871
     4041064 4179871
     4013447 4179871
     4004449 4179871
     4006311 4179871
     4010655 4179871
     4009103 4179871
     4010034 4179871
     4048201 4179871
     4019343 4179871
     4019964 4179871
     4013758 4179871
     4011585 4179871
     4012827 4179871
     4036720 4179871
     4018722 4179871
     4067440 4179871
     4038582 4179871
     4009413 4179871
     4012206 4179871
     4119881 4179871
     4037961 4179871
     4005069 4179871
     4037650 4179871
     4013137 4179871
     4064647 4179871
     4009413 4179871
     4015930 4179871
     4010655 4179871
     4009413 4179871
     4006000 4179871
     4009724 4179871
     4104055 4179871
     4577577 4179871
     4014378 4179871
     4005690 4179871
     4007862 4179871
     4008793 4179871
     4008483 4179871
     4094746 4179871
     4024928 4179871
     5429356 4179871
     7007862 4179871
     4017481 4179871
     4013137 4179871
     4010344 4179871
     4215454 4179871
     7718764 4179871
     4016550 4179871
     4103746 4179871
     4014999 4179871
     4009413 4179871
     4008172 4179871
     4015619 4179871
     27015211 4179871
     4012516 4179871
     4014689 4179871
     4017481 4179871
     4010034 4179871
     4010344 4179871
     4010034 4179871
     4016550 4179871
     13005381 4179871
     4087610 4179871
     4019033 4179871
     4014068 4179871
     4010033 4179871
     4177907 4179871
     4011585 4179871
     4018101 4179871
     30441877 4179871
     4165805 4179871
     4014068 4179871
     4012516 4179871
     4040134 4179871
     4103124 4179871
     4055338 4179871
     4008173 4179871
     4008172 4179871
     4066819 4179871
     4013448 4179871
     4132913 4179871
     24264072 4179871
     4010345 4179871
     4011896 4179871
     4006931 4179871
     4008793 4179871
     4013758 4179871
     4009724 4179871
     4010034 4179871
     4123915 4179871
     4010965 4179871
     4008793 4179871
     4014688 4179871
     4008172 4179871
     4010654 4179871
     4050994 4179871
     4007552 4179871
     4020584 4179871
     24715562 4179871
     4100332 4179871
     4239968 4179871
     4014688 4179871
     4009413 4179871
     4009104 4179871
     4452215 4179871
     4011585 4179871
     4011895 4179871
     4014068 4179871
     4116157 4179871
     4013447 4179871
     4008482 4179871
     4010965 4179871
     4007241 4179871
     4006620 4179871
     4010034 4179871
     4239968 4179871
     4032996 4179871
     4038272 4179871
     4008172 4179871
     4410013 4179871
     4012517 4179871
     4012516 4179871
     4010965 4179871
     4104056 4179871
     4012206 4179871
     4007862 4179871
     4008172 4179871
     4007861 4179871
     4007551 4179871
     4007862 4179871
     4008172 4179871
     4015620 4179871
     4008483 4179871
     4010344 4179871
     4010344 4179871
     4004138 4179871
     4010034 4179871
     4010655 4179871
     4009724 4179871
     4104366 4179871
     4008172 4179871
     4008483 4179871
     10394189 4179871
     4013758 4179871
     4013137 4179871
     4114916 4179871
     4019653 4179871
     4012206 4179871
     4012827 4179871
     4008172 4179871
     4006931 4179871
     4009413 4179871
     4011585 4179871
     4024618 4179871
     4008172 4179871
     4010344 4179871
     4010034 4179871
     4011275 4179871
     4006931 4179871
     4010344 4179871
     4011896 4179871
     4011275 4179871
     4006620 4179871
     4006931 4179871
     4005380 4179871
     4009413 4179871
     4008793 4179871
     4009724 4179871
     4014689 4179871
     4073025 4179871
     4031134 4179871
     4010654 4179871
     4011896 4179871
     4005069 4179871
     4011276 4179871
     4068681 4179871
     4112433 4179871
     4015619 4179871
     4053477 4179871
     4011895 4179871
     4008172 4179871
     4010344 4179871
     4012516 4179871
     24314341 4179871
     4015309 4179871
     4010654 4179871
     4009724 4179871
     4191561 4179871
     4021515 4179871
     4015620 4179871
     4014689 4179871
     4009103 4179871
     11846093 4179871
     4009413 4179871
     4008172 4179871
     4015930 4179871
     4006310 4179871
     4011586 4179871
     4009413 4179871
     4003828 4179871
     17146983 4179871
     4009413 4179871
     4009413 4179871
     4010344 4179871
     4013758 4179871
     4105607 4179871
     4233451 4179871
     4022446 4179871
     25813100 4179871
     4008482 4179871
     4034237 4179871
     4019343 4179871
     4013447 4179871
     4008793 4179871
     4014688 4179871
     4100021 4179871
    Pack12C (HyperThreading ON):
    Code:
     157538381 4179871
     39523998 4179871
     3871939 4179871
     6888066 4179871
     3732613 4179871
     3743784 4179871
     3737888 4179871
     4541879 4179871
     25573786 4179871
     3749060 4179871
     3781330 4179871
     3805844 4179871
     3752163 4179871
     3755265 4179871
     3764574 4179871
     3772643 4179871
     3751231 4179871
     3750921 4179871
     3869456 4179871
     3751232 4179871
     3743474 4179871
     3754955 4179871
     3744715 4179871
     3775435 4179871
     3758679 4179871
     3745336 4179871
     3753714 4179871
     3746577 4179871
     3767057 4179871
     3754335 4179871
     3749680 4179871
     3751852 4179871
     3747818 4179871
     3783813 4179871
     3761161 4179871
     3745956 4179871
     3757128 4179871
     3750921 4179871
     3749059 4179871
     3748129 4179871
     3760851 4179871
     3743474 4179871
     3774505 4179871
     3746267 4179871
     3761471 4179871
     3753714 4179871
     3753404 4179871
     3757747 4179871
     3742853 4179871
     3801500 4179871
     3761782 4179871
     3760230 4179871
     3761161 4179871
     3757438 4179871
     3749680 4179871
     3752783 4179871
     3765195 4179871
     3751542 4179871
     3756506 4179871
     3755886 4179871
     3754956 4179871
     3763954 4179871
     3742543 4179871
     3756507 4179871
     3770470 4179871
     3753714 4179871
     3748749 4179871
     3750611 4179871
     3757438 4179871
     3776676 4179871
     3755576 4179871
     3754955 4179871
     3770470 4179871
     3754645 4179871
     3754955 4179871
     3753094 4179871
     3751542 4179871
     3761161 4179871
     3743784 4179871
     3754334 4179871
     3747508 4179871
     3777607 4179871
     3748128 4179871
     3743474 4179871
     4087908 4179871
     3744405 4179871
     3799328 4179871
     3747818 4179871
     3777917 4179871
     3791571 4179871
     3745336 4179871
     3741301 4179871
     3768608 4179871
     3748439 4179871
     3794363 4179871
     3749991 4179871
     3877524 4179871
     3753404 4179871
     3747198 4179871
     3743474 4179871
     3767057 4179871
     3742854 4179871
     3739750 4179871
     3741612 4179871
     3733855 4179871
     3758058 4179871
     3732923 4179871
     3746267 4179871
     3755886 4179871
     3760540 4179871
     3804603 4179871
     3748128 4179871
     3746887 4179871
     3779468 4179871
     3747818 4179871
     3802121 4179871
     3745956 4179871
     3748439 4179871
     3760540 4179871
     3743474 4179871
     3744095 4179871
     3754335 4179871
     3752163 4179871
     3753714 4179871
     3780089 4179871
     3769540 4179871
     3754024 4179871
     3754335 4179871
     3742543 4179871
     3751232 4179871
     3744716 4179871
     3758368 4179871
     3756197 4179871
     3749680 4179871
     4228785 4179871
     3779468 4179871
     3755265 4179871
     3749060 4179871
     3767987 4179871
     3760851 4179871
     3754334 4179871
     3750300 4179871
     3760851 4179871
     3748749 4179871
     3749369 4179871
     3743784 4179871
     3745956 4179871
     3753093 4179871
     3746267 4179871
     3747198 4179871
     3752783 4179871
     3755266 4179871
     3757127 4179871
     3756197 4179871
     3755886 4179871
     3752472 4179871
     3748129 4179871
     3752163 4179871
     3755886 4179871
     3769539 4179871
     3754955 4179871
     3837495 4179871
     3755265 4179871
     4018401 4179871
     3755265 4179871
     3750922 4179871
     3745336 4179871
     3763333 4179871
     3763333 4179871
     3757438 4179871
     3749370 4179871
     3791260 4179871
     3755886 4179871
     3757748 4179871
     3753714 4179871
     3790950 4179871
     3763023 4179871
     3750611 4179871
     3749369 4179871
     16891557 4179871
     3764575 4179871
     3749991 4179871
     3833461 4179871
     3763023 4179871
     3745336 4179871
     3767367 4179871
     3751852 4179871
     3757748 4179871
     3903900 4179871
     57550017 4179871
     3786296 4179871
     3748439 4179871
     5557185 4179871
     5736849 4179871
     3754334 4179871
     3750300 4179871
     3745025 4179871
     7455917 4179871
     3742853 4179871
     3752472 4179871
     3759299 4179871
     5205303 4179871
     3752163 4179871
     3754335 4179871
     4671275 4179871
     5767259 4179871
     3746267 4179871
     3755576 4179871
     5870899 4179871
     3785985 4179871
     3776366 4179871
     3755886 4179871
     15929003 4179871
     4101872 4179871
     3756507 4179871
     9012389 4179871
     4389831 4179871
     3754335 4179871
     3751853 4179871
     3920346 4179871
     3878144 4179871
     3754955 4179871
     3750301 4179871
     3790640 4179871
     3748749 4179871
     3821980 4179871
     3764264 4179871
     3769850 4179871
     3790329 4179871
     3788158 4179871
     3850217 4179871
     3858906 4179871
     3790640 4179871
     3832531 4179871
     3794053 4179871
     3788778 4179871
     4972266 4179871
     3795915 4179871
     3807396 4179871
     3794984 4179871
     3812671 4179871
     3781951 4179871
     3796225 4179871
     3811119 4179871
     3810809 4179871
     3789088 4179871
     3786606 4179871
     3814223 4179871
     3782572 4179871
     3798397 4179871
     3790950 4179871
     3807706 4179871
     3788157 4179871
     3796535 4179871
     3786295 4179871
     3791571 4179871
     3812671 4179871
     3804603 4179871
     3791571 4179871
     3789399 4179871
     3793122 4179871
     3815154 4179871
     3787227 4179871
     3817946 4179871
     3857664 4179871
     3747507 4179871
     4813703 4179871
     3840908 4179871
     3815153 4179871
     3801500 4179871
     3793122 4179871
     3825704 4179871
     3829117 4179871
     3788778 4179871
     3784123 4179871
     3826945 4179871
     3997300 4179871
     3892419 4179871
     3761782 4179871
     3818567 4179871
     3832841 4179871
     3791571 4179871
     3786295 4179871
     3798708 4179871
     3817326 4179871
     3790330 4179871
     3790329 4179871
     3798087 4179871
     3813912 4179871
     3857044 4179871
     3788157 4179871
     3794984 4179871
     3799949 4179871
     3842771 4179871
     3789089 4179871
     3814843 4179871
     6281117 4179871
     3901728 4179871
     3871938 4179871
     34523493 4179871
     3802121 4179871
     3797156 4179871
     3848356 4179871
     3813913 4179871
     5420341 4179871
     3801811 4179871
     3806775 4179871
     13956418 4179871
     3789709 4179871
     3811740 4179871
     3794364 4179871
     4314428 4179871
     3898935 4179871
     3792812 4179871
     3789399 4179871
     3793743 4179871
     3830979 4179871
     3790639 4179871
     3794053 4179871
     3790950 4179871
     3792812 4179871
     3862319 4179871
     3784744 4179871
     3898934 4179871
     3811120 4179871
     3946411 4179871
     3788468 4179871
     3785986 4179871
     3830669 4179871
     4089770 4179871
     3793433 4179871
     3799639 4179871
     3816084 4179871
     3799328 4179871
     3761162 4179871
     3778538 4179871
     3779158 4179871
     3792501 4179871
     3952927 4179871
     3767988 4179871
     3807086 4179871
     3798087 4179871
     3790019 4179871
     3782882 4179871
     3794984 4179871
     3826945 4179871
     3848977 4179871
     3785675 4179871
     3812050 4179871
     3791881 4179871
     3799018 4179871
     3794364 4179871
     3796536 4179871
     3817326 4179871
     4163312 4179871
     3783813 4179871
     3806155 4179871
     3772022 4179871
     3794984 4179871
     3799018 4179871
     8141683 4179871
     3795604 4179871
     3788468 4179871
     3955100 4179871
     3783503 4179871
     3789089 4179871
     3830358 4179871
     3836875 4179871
     3789709 4179871
     3787227 4179871
     3797776 4179871
     3811430 4179871
     3790639 4179871
     3789088 4179871
     3791881 4179871
     3809568 4179871
     3794054 4179871
     3779779 4179871
     3790950 4179871
     3821359 4179871
     3794053 4179871
     3789089 4179871
     3797776 4179871
     3826324 4179871
     4881659 4179871
     3790950 4179871
     3792502 4179871
     3792811 4179871
     3814533 4179871
     3804913 4179871
     3958513 4179871
     3794984 4179871
     3857665 4179871
     3792501 4179871
     3799639 4179871
     3808637 4179871
     3795915 4179871
     3794673 4179871
     3782262 4179871
     3829117 4179871
     4605180 4179871
     20487638 4179871
     3805534 4179871
     3826014 4179871
     3793743 4179871
     3845563 4179871
     3763334 4179871
     3803983 4179871
     3778849 4179871
     3765815 4179871
     3795915 4179871
     3837805 4179871
     3795605 4179871
     3796225 4179871
     3806155 4179871
     3789088 4179871
     3823842 4179871
     3786295 4179871
     3798087 4179871
     3808327 4179871
     3795295 4179871
     3796845 4179871
     3794674 4179871
     3907313 4179871
     3794053 4179871
     3791260 4179871
     3793433 4179871
     3938653 4179871
     3795604 4179871
     10885367 4179871
     3871008 4179871
     3785675 4179871
     3790950 4179871
     3845563 4179871
     3791261 4179871
     3850838 4179871
     3785985 4179871
     3953858 4179871
     10960771 4179871
     3806775 4179871
     3804603 4179871
     3790950 4179871
     3794984 4179871
     3845563 4179871
     3822912 4179871
     3789399 4179871
     5390863 4179871
     10696704 4179871
     3784744 4179871
     3823221 4179871
     3785055 4179871
     4097218 4179871
     3795915 4179871
     3790019 4179871
     3817947 4179871
     6800561 4179871
     3866043 4179871
     3837806 4179871
     3793122 4179871
     3794053 4179871
     3784123 4179871
     3792501 4179871
     3810188 4179871
     3801500 4179871
     5834284 4179871
     3788778 4179871
     3792812 4179871
     3786917 4179871
     3821359 4179871
     3796846 4179871
     3789088 4179871
     3800569 4179871
     3832220 4179871
     4132902 4179871
     3785985 4179871
     3795605 4179871
     3796226 4179871
     3800569 4179871
     3816705 4179871
     3794984 4179871
     3795604 4179871
     10752247 4179871
     3842770 4179871
     3786295 4179871
     3822600 4179871
     3790330 4179871
     3789709 4179871
     3818877 4179871
     3834703 4179871
     3784124 4179871
     10773969 4179871
     3789399 4179871
     3741922 4179871
     3815464 4179871
     3989232 4179871
     3786296 4179871
     3772953 4179871
     3904830 4179871
     3793433 4179871
     12539273 4179871
     3806465 4179871
     3799328 4179871
     3787226 4179871
     3784123 4179871
     3817326 4179871
     3798087 4179871
     3824463 4179871
     3820118 4179871
     3804603 4179871
     4041053 4179871
     3788157 4179871
     3794053 4179871
     3880007 4179871
     3791261 4179871
     3803672 4179871
     3791881 4179871
     3822601 4179871
     3801500 4179871
     3797467 4179871
     3812360 4179871
     3789709 4179871
     3795294 4179871
     3863561 4179871
     3816395 4179871
     3786916 4179871
     3787227 4179871
     3796225 4179871
     3793122 4179871
     3792812 4179871
     3832531 4179871
     3837496 4179871
     3796225 4179871
     3796225 4179871
     3797777 4179871
     3844943 4179871
     3789709 4179871
     3786916 4179871
     3885902 4179871
     3796846 4179871
     3786295 4179871
     3788158 4179871
     3796846 4179871
     3784744 4179871
     3803362 4179871
     3793743 4179871
     3814222 4179871
     3797156 4179871
     3749680 4179871
     3764264 4179871
     3782572 4179871
     3802121 4179871
     3799328 4179871
     3788157 4179871
     3788778 4179871
     3837185 4179871
     3797777 4179871
     3794984 4179871
     3797467 4179871
     3809258 4179871
     3803362 4179871
     3790950 4179871
     3795914 4179871
     3789709 4179871
     3809878 4179871
     3794673 4179871
     3788778 4179871
     3786916 4179871
     3812982 4179871
     3789399 4179871
     3799948 4179871
     3817016 4179871
     3785675 4179871
     3990473 4179871
     3786917 4179871
     3807706 4179871
     3824773 4179871
     3794053 4179871
     3796226 4179871
     3813292 4179871
     3788778 4179871
     3801190 4179871
     11496350 4179871
     3790640 4179871
     3947342 4179871
     3822290 4179871
     3793432 4179871
     3798707 4179871
     3790019 4179871
     3801190 4179871
     10838821 4179871
     3813602 4179871
     3784744 4179871
     3799328 4179871
     3782882 4179871
     3815154 4179871
     3865423 4179871
     3785055 4179871
     3799949 4179871
     10824859 4179871
     3790019 4179871
    Hope this helps whatever you're trying to do! =oP
  16. Raghar
    Raghar Limp Gawd
    209
    Jun 23, 2012
    Actually it helped a lot, it established a nice base.
    Actually it has perfect score. You used 6 cores, and it's 3x faster than on 2 cores. Looks like non-parallelizable overhead is: 48406.8 ns. (Numbers on the left are nanoseconds, numbers on the right are hashes.)
    The small problem is games that will not check for hyperthreading will run at 0.53455692893 speed. ( 4008172/(2*3749060) ) This test also proven a hyperthreading is basically useless, because it improves things only by about 1/14 in the best case. At least it doesn't hurt on 3960X.
    Actually, statistics requires only one user per CPU type (4-core, 6-core, 2-core combined with Sandy bridge, Ivy bridge) There are no Ivy bridge 6-core CPUs, thus only 5 people. (few more are needed for verification, however number of cores is irrelevant for verification) The only trouble is the interference of power saving features in laptops benchmarks.
    Considering how Intel CPUs look so far, I'd also like to see one AMD Bulldozer, and two Visheras (at least one 6-core).
  17. WolfpupNX
    WolfpupNX Limp Gawd
    167
    Mar 13, 2007
    Cool and interesting. =) I keep hyperthreading enabled just because there's no real reason to disable it and I might see performance gains. Also, while folding, it allows me to fold 12 things at once instead of 6 (though there's no way to know if it actually finishes a greater number in the same timeframe).
  18. -Dragon-
    -Dragon- 2[H]4U
    2,318
    Apr 6, 2007
    This whole test would seem to indicate to me that you don't really understand what hyper threading is for... It's not there to increase performance when you're running a task that's ideal at keeping a CPU pipeline 100% full at all times that can primarily run out of L1 cache and registers, it's there so that when the CPU is doing something but then has to pause the pipeline to wait for something like data from memory or the HDD the CPU can switch to a second thread internally and operate on a separate set of registers and use those CPU cycles that would otherwise be wasted waiting to do other work, without the overhead of pushing and popping to the stack or at a time that would otherwise be impossible to task switch from the view point of a single core.
    Basically you setup the worst possible conditions for HT and are probably trying to "prove" it's useless, where if you setup a different set of parameters, say a program that did a small memory read from some random place in RAM that you were sure wasn't in any of the CPU caches so it actually had to fetch RAM then did some processing on that data for the exact amount of time it took to fetch the data from RAM so the CPU spent 50% of the time waiting on data and 50% of the time processing, you'd see almost a 100% improvement from HT because while one thread was fetching from RAM the other could be processing.
    Admittedly few real tasks fit that usage pattern and more are closer to being pipeline bound like your test is, but even if the CPU averages around 20% idle CPU cycles due to IO waits and can convert 50% of them into useful cycles via HT then that's still a 10% performance gain over not having it, and the HT logic only takes up a few % of the die space (it was like 5% of the die space on the original P4's I imagine it's quite a bit less than that now), so spending a few % die space to improve average performance by quite a bit more than that is a good way to spend silicon space.
  19. cyclone3d
    cyclone3d [H]ardForum Junkie
    13,044
    Aug 16, 2004
    Depending on your program is set up and how it uses data, you can get about a 20-25% speed increase over not using hyperthreading. This is with all threads maxxed out 100% of the time while running said program.
    All you are proving is that Hyperthreading is not very useful in your specific code. You are probably purposely causing all kinds of cache thrashing because you are using too large of data sets which is going to kill extra performance that can be had from Hyperthreading.
    If you change your data set so that the size is adjustable by the user so that they can set it up for each thread to be able to fit the needed data in cachem you will see a large speed increase.
  20. Fort_Major
    425
    Apr 22, 2006
    First, Benchmarking applications with a stopwatch and not an actual professional profiling tool running and monitoring the application (for cpu time not actual execution time) is child's play.
    Second, Using managed code to attemp to measure efficiency of most things very hardware specific such as cache/hyper threading quite impossible due to the pure nature of the fact that managed code has so much going on. Managed code might only be 10x slower than Native C/ASM however it also will generally cost far more CPU time and will result in far weirder usage of things like CPU cache.
    Third 5 data samples is actually absolutely worthless and in no way construes any amount of data capable of performing any statistics on.
    Fourth, making a very generalized statement about a tiny sampling of a very hardware specific technology based upon one simple scenario is not very valid.
  21. Raghar
    Raghar Limp Gawd
    209
    Jun 23, 2012
    Actually, current Intel CPUs have a lot of virtual registers. Wouldn't these virtual registers make HT less relevant?
    Which brings here another question. Assume you have two threads, one interrupts a lot and reads a lot of RAM (that's the important one), and another that runs smooth as a silk and has nearly no RAM accesses and when they do they might be in cache (that's the much less important thread). It works well as long as they run at 1:1 ratio. When the first thread has only 1/10 running time, the results of the second threads are nearly useless. Would the second thread choke the first, when these threads would run on a single HT core?
    Really?
    This post is interesting... The poster before you claimed lot of RAM access is nice because it helps HT, and you are claiming I have too large dataset.
    So, not allowing a profiling application to interfere with tested application's timing is bad?
    10x slower, that's crazy. I thought a single threaded C implementation of similar algorithm finishes in 18 ms per iteration. However what can you do? C++ doesn't provide nano second timer, and <thread> is designed for people who received title, but are not able to use free time for self-education afterwards, which means it's simple and doesn't allow much creativity.
    But results show it stabilized fast, it took only two-three iterations.
    Well, the problem is I don't have 5 data samples yet. I still need desktop i5-2xxx/3xxx, and i7-3xxx (1155) samples.
    What I said about Intel extreme CPU is valid, and that matters. I could test few thousand (6-core 2011) CPUs, and I'd have the same measurements.
  22. Fort_Major
    425
    Apr 22, 2006
    A Profiling Application is far better tool at determining actual "CPU cost" because the execution time is not necessarily the most accurate measure. It is capable of monitoring a wide range of things from memory allocations, cpu cost and cpu time spent. The latter which are far more important in managed languages than non-managed languages
    There's tons of benchmarking done with far better tools and with a lot of varying scenarios that show what one would expect.
    For some things HyperThreading benefits, for some things there is no performance gain and for a few things it's slower.
    The reason why these things vary so much and being able to take advantage of the benefits Hyper threading generally requires you to be very low level C/C++ to have more control over when/how you take advantage of it.
