A really question about Abit IP35 Pro
Velocities
I been using this motherboard for a couple of months now, but there is something that keep bothering me. On the Motherboard there is a ATX4P1 where a 12V Connector go into it. It is required that this connection should be plug in? If I plug it in, it cover up my PCI Slots and don't even know what it is for. Without having it plug in, It still boot up fine and working like it should, but I'm getting paranoid about it. Can someone tell me what this slot is for and if it should be plug in or not?
Thank You!
I think it's optional. You can use the 12v or the other one... on it..
So does that mean I don't need to plug it in if I already plug in the ATX 24 Pin Connector and the ATX 8 Pin Power Connector? I plug it all in including the ATX4P! Auxiliary 12V Power Connector, but I would like not to use the AT4P1 Auxiliary 12V Power Connector if it's optional.
Thanks!
I think those optional ones are when the CPU needs more juice when overclocking. But don't quote me because I don't know. I plugged it all in since I'm only using the PCIe16x slot. I had some spare 4pin connectors anyway.
The ATX4P1 is there to bolster the PCI-E bus when it's being heavily drawn on (most often when there are 2 hungry gfx cards).
Yup, so if you've got a single card, no need to plug it in... unless that card is extremely power hungry, lol.
