A quiet 120mm fan?
Tedium
I have a spare 120mm fan spot, and I'm having trouble finding a 120mm fan that isn't loud. Any suggestions?
papst 120mm fan from plycon. It's pricey though, but I thought it was worth it.
just about any 120 that you can coax into running at 7 volts will be quiet enough...
a rheostat, baybus or other fan controller will do the trick or you can just hardwire the fan to run at 7v.
