i never really had good experience in getting USED harddrives to work... the only harddrives that ever worked for me were brand new ones.... other than that, it never boots....
now, i have several old used harddrives but in pretty good condition... i m pretty sure that most of them work.... they're mostly WD caviars, with small sizes like 3gb, 6gb, 10gb and another one or two drives
tomorrow morning, i am going to test it out by hooking it up to my main rig... i just want to hook it up and load a couple games on it to run... this includes installing windows xp on it, etc to make it work..... how do i do this?...i ve tried this before and it never worked for me..
one of the harddrives (3gb) has windows xp on it and stuff too and i wanna hook that up to see whats inside.. i know the stuff works because it was working when i took it out of my moms computer to put in a 7gb harddrive.... so i wanna try hooking this up first
correct me if im wrong
basically i hook up the drives to the primary IDE controller thru a 80wire IDE cable... then since it'll be the only drive in the computer then, i set the jumper to master right?... then i boot... but then what next?, what if it just doesnt boot?... do i have to go into BIOS to change anything?.... i need exact procedures... PLEASEEE
harddrives have always hated me... ive always tried to avoid them... but now, i wanna face this lil problem and just clear it up so i understand harddrive business
thanks
thanks
