A Quick Question About Fittings
I am almost positive Mc Master has something that would work.
Page doesnt show but product number is 5463K447
Comes in a pack of ten for $4.53
Oh ok, I was actually going to suggest that page to you, but was unsure as to what the "Pipe Size" meant and if it was in NPT or what...
Yeah the site is not too difficult to navigate, you can find almost any tubing fittings. I highly recommend this website to people who cant find what they are looking for at other stores, and theres extra comfort knowing that the stuff you order comes from the source :)
There is some good stuff at that site for computer hobbyists like vibration dampeners for pumps. Also I found melamine foam sheets there which is the same stuff they use in PC silencing kits although MC Master is way cheaper.
