Because you can get the same, and often better performance with a cheaper processor by overclocking it.
It's becoming pretty widely known that A64 procs beat the crap out of P4 systems now in games, but you lose HT, so multi-tasking isn't as smooth. If I were going to build a gaming system now I would look at a A64 3000+ and overclock it, like in the article.
WOObi:
The suggestion for a mobile 35 watt 2400+ and abit nf7 is really a good one. I know you don't like the idea of overclocking, but let me explain why you really wouldn't be overclocking anyway. The 35 Watt chips are the best of the best yield on the Athlon XP line, they are badge 35Watts because they are able to run at a much lower voltage stably at 2400+ speed and thus only produce the 35 Watts of heat. If they had not been tagged to become Mobile 2400XP's @ 1.4 or 1.5 or whatever very low voltage they are using, you would see them as 3200XP's @ 1.6~1.7 volts. The only difference between the Mobile 35watt 2400+ chip and the Athlon XP3200+ is the marking on the face of the chip and the batch number that they were produced from (and possibly the cuts of certain L1, L3, or L5 bridges but not even necessarily that). The actual processor at the silicon level is going to be identical, and the capability of the chip to run flawlessly at 3200+ speeds if given the same voltage (or possibly even a voltage lower than normal) as a regular 3200+ chip is absolutly there. The only thing you need to be aware of is if you run the mobile chip at 3200XP speeds, you will need a HSF unit that is capable of disipating normal 3200+ chip temperatures. I don't even know if the mobile chips come with HSF's but if you run a 35W 2400+ at its normal speed and don't overclock it, you probably could easily get away with just a mid sized heatsink and a well ventilated case. Overclocking the 35W 2400+ Mobiles to 3200+ speed and voltage will not damage the chip, but it will run at a higher wattage output and thus will need more active and capable cooling from a HSF.
Hope that clears some things up for you.
