A question regarding nVIDIA’s nforce chipset/driver stability
Nielo TM
Hey guys,
I am in the market for a new mobo and for some reason; I keep avoiding the ones with nforce chipset, primarily because I’ve always though of them as unstable. This may or may not be true which is why I made this thread.
I know I’m being a little paranoid here but I need a highly stable, and reliable system when I rejoin my UNI later this year. And if it’s anything like last year, I can’t afford to take the time out to fix issues that can be easily avoided.
Anyway, if guys could point me in the right direction, I’d be very grateful;).
If you're going Intel, it doesn't make much sense to go Nvidia unless you absolutely need SLI. If you don't, then a P35 or other Intel chipset would serve you well. On the AMD side, there hasn't been an Nvidia chipset since the 590 SLI, which is very stable and seems to have fewer issues than a lot of the 680i SLI boards.
Hey guys,
It depends. Do you want or need SLI? If not Intel chipsets are your best option. If you do want SLI, then an ASUS SLI compatible motherboard is probably your best choice.
Unless you need the fastest gaming performance available, it doesn't make sense to go with anything but an Intel chipset based board. A G33, P33, P35, X38 or X48 motherboard will likely serve you well for as long as you own the machine. Intel's own brand of motherboards are an excellent choice as is the usual brands, ASUS, Gigabyte etc.
The NVIDIA chipset based motherboards are far more stable than you might think and actually most of the 600 series is quite good. However they aren't quite as good as the Intel chipset based solutions are. The 680i SLI in particular is a mixed bag as they overclock very well and offer great performance but they have longevity issues. The non-reference designed 680i SLI motherboards are typically best but they often have memory compatibility issues and don't overclock as well as the reference designed boards do. The NVIDIA reference design boards are problematic when overclocking. Especially with quads. They've got great memory compatibility and are rock solid stable while they work. The drivers are actually pretty good now but they have a tendancy to fry memory modules and die often. I've been through a number of reference boards and I won't touch them anymore. I've yet to experience the 780i SLI boards but I hope to do so in the near future. I'm especially looking forward to the ASUS 780i SLI solutions in the form of the P5N-T and the Striker II Formula.
If you must go SLI now then the Striker Extreme or the P5N32-E SLI Deluxe are probably your best options. Also worthy of attention is the P5N32-E SLI Plus which uses a hybrid chipset that gives it the same total number of PCIe lanes as the higher end 680i SLI chipset using the same PCB as the P5N32-E SLI Deluxe and Striker Extreme.
I've had the Striker Extreme for over a year and at stock speeds the thing is solid as a rock. Never a lockup or a crash. However overclocking dual cores yields generally ok results but quad core overclocking has been pretty dismal on my board. I can get into Windows up to 3.0GHz but it locks up in minutes and lesser settings haven't yielded good results. Unfortunately the RAM I used to have when I first started using the Striker was sold off. That RAM wasn't rated to go above 900MHz which is around the speed the Striker starts having issues with memory. I can clock my RAM as high as 1143MHz on it now with BIOS 1303 but unfortunately it isn't entirely stable. Most people report much better results with the Striker Extreme than I've ever achieved. Clearly mine is a poor sample. It works well at stock speeds but everything else is up in the air. Mine was however one of the first run boards that went out the door. Apparently on BIOS 1303 with quad cores the Striker Extreme has found a new lease on life. There are also rumors that ASUS has a BIOS to allow for Wolfdale and Yorkfield cores to be supported properly, though this is unconfirmed.
OCZ actually made a custom BIOS that is supposed to improve memory stability and compatibility that I'll probably try out this weekend.
SLI compatible board recommendations:
ASUS P5N32-E SLI Deluxe
ASUS P5N32-E SLI Plus
ASUS Striker Extreme
Gigabyte N680SLI-DQ6
Non-SLI compatible/Crossfire compatible board recommendations:
ASUS Blitz Formula (DDR2) (P35)
ASUS Blitz Extreme (DDR3) (P35)
ASUS Maximus Formula (DDR2) (X38)
ASUS Maximus Extreme (DDR3) (X38)
If I didn't feel like I needed SLI compatibility then the Maximus Extreme or Formula would be the only board in my machine right now. Period, end of story, that's the way I'd go. The Maximus Formula is the best all around board I've experienced. The Blitz Formula is the best overclocker, and the Maximus Extreme is the most full featured board I've ever tested.
