A question on running Dual Monitors
Shadowz
Is there anything special I need to do to run dual monitors? Do I just need a a video card with a vga port and a dvi port? My boss wants to start running dual monitors on his machine. His computer currently has the video built into the motherboard. I know he's running XP professional but thats about it. Thanks for any help.
Get a video card with dual video output. Usually the newer cards are 2 DVI outputs, but they come with DVI to VGA converters. If he won't be doing intense graphics, just get a cheap 5000 series Geforce or something, probably will run you $50 or so.
...or just get a second video card, and use it in conjunction with the onboard video. You can pick up any cheapo video card for $20 or less, and it'll give perfectly acceptable 2D performance.
Thanks guys. Just wanted to make sure I didn't have to do anything special.
You'll also want to download and install the latest drivers for your card - this is why just buying a single new card that will run both monitors will be less hassle. In the advanced display options, you simply need to tell it that you are running two displays (once you have both displays actually connected.) Tada, you are now kickin' it dual monitor style.
- John -
That second card will likely have to be a pci card, or else the onboard will stop working (unless it's a newer radeon Xpress chipset)
Good point. I don't recommend using the on-board at all. Even for 2d graphics it leeches your system RAM and performance, not to mention it isn't nearly as configurable and flexible. One card to do it all is well worth it.
Good input though, IanG - there is just too many disadvantages of running 2 seperate cards, not to mention it is a freakin' headache.
I ran four video cards for a while. Now I'm down to two double-headed ones. :p
My work box is fine with onboard intel 865 and a pci GF4 mx 4000. It's only used for desktop stuff, but I've never had a problem. My emplyer has about 30-40 boxes set up like this as well.
