A question about Chieftec BA-01B-B-B
svkap
Hi, reading specs on Chieftec site it seems that Bravo Bigtower meets HD Audio specifications, but in the FAQ section the pin assignment of the internal Audio meets AC'97 specifications as follows:
Does anyone have this case and can confirm whether or not if is equipped with HD Audio?
Yes it does. If its anything like mine...which is the exact same case except with a mesh front panel, then it has an audio connector that terminates into an azalia HD audio connector BUT it also has an AC'97 connector branching off the very end for backwards compatibility.
