I have an idea for a watercooled htpc and would like your ideas.
My idea is this: To use an AMD XP-3200 cpu and downclock it as far as it'll go. And then use the Thermaltake Tidewater Plus to cool both the cpu and gpu. Thus lowering the case noise from the fans.
My trick here is to use a WC rig meant for a dual gpu/SLI to cool a cpu and a gpu. But I think that if the cpu is running cool to start with by downclocking it, I think the Tt rig should be able to handle it.
What are your thoughts and ideas?
Thank you.
Thank you.
