Have any of you guys found a place to get one? I basically need a sheet of metal or other solid surface to put my computer on to keep it off of the carpet. One that matches my computer's dimensions as closely as possible (and is as close to the floor as possible) would be best.
I'm currently using a big CD storage case which is roughly the right length and depth... but has way more height than I'd like.
Well, actually, I have a metal mousepad that's exactly the correct dimensions, but that seems like a waste.
Edit:
And I just checked Amazon... They had another of that same mousepad (used) for $16. The pad is the Razer Manticor, and the case is the Fractal Design Core 500. Not bad for an exact match.
But I've also got a Hadron Air with a much smaller footprint, facing the same dilemma. I'm using a small block of particle board there, but I'd love to replace it with a thin metal pad
Edit:
