A non-TN 22" Panel
Id be asking if a non tn/va panel exists since va sucks just as bad.
Tn only sucks if you do cad/photo/video editing. If all you do is game & watch movies TN is fine.
Lenovo L220x - Some sort of VA panel
EIZO CG221 - S-IPS panel, but costs $5000 and has a thick bezel
Those are the only ones currently available.
I have used TN (LG L204WQT) and a Viewsonic vx2025wm (P-MVA) side by side and the P-MVA is night and day.
Compared the LG there is very little colour shifting, colours are much more vibrant, significantly reduced backlight bleed (some VAs can be bad though), the blacks are much blacker, grey is actually grey.
Nevermind the fact that the majorty of VAs are 8 bit versus the TN's 6bit.
The only downside is that VA panels have that black area problem, however I rather have that then the TN's poor vertical viewing angles (colour shift).
TN panels are actually damn good these days, don't underestimate them. But I don't know of any non-TN 22in lcds.
VA panels are actually quite good, they have excellent black quality but the best panel I've used is IPS. All around great for everything, especially gaming.
Thx guys I would go for 24 but I cant see well up close so I need that higher dot pitch. I'v looked at the 27's but would be hard to fit that. Guess il have to play the waiting game a while longer :rolleyes:
Coming from a 20" IPS to a 24" VA its a downgrade, there is colorshifting and blacks are just wack on it.
Planar PX2611W is probably one of the better non TN for gaming. Or the cheaper version made by doublesight (Same thing, just cheaper, different company, ohh and no height adjustment.)
