A new Revit Build Feedback
FXDawg
Hello all,
I've put together a build and would like some feedback and maybe tweak it some.
· Intel Core i9-9900K 3.6 GHz 8-Core Processor
· Asus PRIME Z390-A ATX LGA1151 Motherboard
· Corsair Vengeance LPX 64 GB (4 x 16 GB) DDR4-3200 Memory
· Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive
· be quiet! Silent Base 601 ATX Mid Tower Case
· SeaSonic FOCUS Plus Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply
· Microsoft Windows 10 Pro OEM 64-bit
· NVIDIA GeForce RTX 2080 Ti 11 GB Founders Edition Video Card
· (2 x) be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler
This comes in around $2800
Thanks in advance!
Mostly Revit Modeling, AutoCad Modeling and Navisworks model reviews
about $2500 to $3000 all in
USA near a microcenter
USA a microcenter about an hour away
this will be a complete build. Case, PSU, MoBo, CPU, RAM, SSD & GPU. I think I'm all set with monitor, keyboard & mouse.
All new really
6) Will you be overclocking?
Maybe just a simple overclock during setup but no real playing around with it.
1 - 1920 x 1080 - 30" and 2- 24"
As soon as we put together a build.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I've put together a prelim build. Can we start with that?
Going to need a new OS. win 10 Pro
I saw your post a while ago but I didn't respond because I'm not an expert and I didn't want to throw you off with bad advice but I think your build looks great !
Enjoy it !
Pretty sure everyone is caught up in the amd 3950/60/70 craze right now. Which is likely what most people would have suggested for a workhorse. It may be worth looking into if your apps benefit from lots o threads.
Reactions: N4CR
Wouldn't a quadro/firepro be better for CAD?
Looks like you just built a generic 720p twitch FPS gaming rig.
the quadro is definitely a more stable set up but I couldn't bear spending the extra $3k on very little performance boost. All the benchmarks point to the gaming card for a lot less money you get comparable performance
anyway, thanks for the comments
And there she is! I was loading up Autodesk software all day! Well multitasking so, it was a little slow progress
