Progenitor
- Feb 14, 2005
Hello all.
Since my current motherboard died out on me and was more or less dated anyway, I've decided to go out and build a new PC. Since I plan on doing at least a moderate amount of gaming on the newer stuff, I wanted to get a good card for my machine.
I was thinking of spending upwards of 400 to 450ish, though I'd like to spend a little less if I can help it. I've spent the last few days reading a number of different bench tests and card reviews as well as comments from members in the forum. My understanding is more or less the following, but correct me if I'm wrong or if you disagree.
* Dollar for dollar, ATI seems to give the best output with the exception of OpenGL (Doom3 - anything else really heavily OGL based?).
* SLi is still more or less in the infancy stages and thus not terribly practical at the moment. From what I have seen from tests, 2xSLi cards yields far less than double the performance of a single card of the same type.
Now, I was initially planning on buying the ASUS A8N-SLi board, but it seems that a lot of what that board was built for may be squandered if I ultimately decide not to go with SLi (or NVidia at all for that matter). I'll discuss that more in the motherboard section, as I don't want to digress too much here. It looks like I'm definitely going A64, as it looks as though that has become highly dominant across the board (with the exception of multitasking?). Either way, I"m going 939-pin A64 and it can be assumed that I'll get a board that supports PCI-E.
So, any suggestiong on what is good to go with? For games, I'll be playing mostly HL2 and CS:S, and maybe some Doom3 as well (but less so). I was considering going with an X800 or X850 model, but as I understand it one of the primary downfalls with those right now is that they are difficult to impossible to find at anywhere near MSRP.
In terms of these ATI card, there are a few different models for each that seem to range in price pretty significantly. Dollar for dollar, are the upper end models more impractical for what they offer over their brethren versus the price jump?
What say you? Thanks in advance for any advice/comments.
