A New BOXEN is born
W.Feather
[H]ard DCOTM x4 & [H]DCOTY x1
The guts- Q9450, DFI LanParty x38 T2R, SunBeam Core Contact Freezer, Antec Neo ECO 520w, PNY 9800GTX.
so far i've gotten the 9800GTX to its normal elvels(650/1998/900) for folding, though the GPU client is being a little bitch......
CPU is stock, getting ~14 TPF on a a 6701(my luck thats the 1st one i get), this is all on the board that ig ot that didnt post for the last owner, for $30......will work on an OC tomorrow.....NB is warmish, big black mosfets cooler is warm....CPU cooler is both(top cool bottom warm)...
well ya, farm is growing, i got the bug...
O ya, running Windows Server 2008 R2
edit: Also on a side note, my 1090T is folding nicely at 4.0 Ghz @ 43c ...... H50 FTW, and its been chugging the WU for ~2 hours, pretty sure its stable now, will know if i wake up to no PC folding goodness
still working out the kinks, got this error while i slept:
[12:30:58] CoreStatus = C0000029 (-1073741783)
[12:30:58] Client-core communications error: ERROR 0xc0000029
[12:30:58] Deleting current work unit & continuing...
Toit figures its probably memory related. in a bit ill be shutting her down for a min to put another 2gb mem in(only had 2 in for the install)
I'm not quite sure what it is. I only stated that the only time I saw this error in the past was on -bigadv boxen when memory starts getting low.
Mr. Pedantic had this happen to him a few months ago: http://hardforum.com/showthread.php?t=1530460
I had a similar error, it ended up being an unstable oc (consequently it was prime95 stable). I bumped the voltage a bit and walla, no more errors!
Yeah, this error is usually the result of a bad overclock, bad memory, or some other system instability issue. Unfortunately, Feather told me he is running at stock clock so it is a bit pesky to troubleshoot.
Ahh, I didn't catch that. That does make it a bit more troubling.
ya, i think it was the memory being run at 1.904v instead of rated 2.1v , changed it
amdgamer had a similar problem due to bad memory - http://hardforum.com/showthread.php?p=1036036724
It was actually do to bad ram slots for folding2. There is a thread over in the Mobo section of the forums, but there seems to be a LOT of x58 motherboards having lots of ram trouble right now. I glanced at it 2 days ago, and it appears the eVGA x58 boards are getting hit the hardest. Kyle mentioend in the thread that he seems to think that there are a bunch of bad dimm slots going around as no x58 motherboard manufacturer appears to be spared.
Since the rig was still new, Microcenter did some diagnostics on it and the ram slot ended up shorting out and taking out all 3 DIMMs with it when it blew during the tests.
