I am not quite sure who is the culprit but yesterday while I was gaming on my PC, my screen freezes. The restart button won't work and I had to hold down the power button. I try opening the computer again and I believe it does open but my monitor is not showing windows and is just flickering in a black screen with flashes of white(With check signal message).
My monitor is a Syncmaster 245BW 24in and my video card is a BFG 8800GTS 320mb, I wasn't quite sure how I should do this. Any suggesstions?
I was thinking of grabbing another monitor and hooking it up to my main, to see if it worked, if it worked then my monitor would be the problem? and if it didn't work then it would mean my video card might be the problem?
EDIT: Er...I removed the cable leading to the video card and had the monitor just plugged in by itself and it's still flashing, I am assuming it is the monitor then?
